我想让2410进入掉电模式,然后通过中断唤醒,在2410datasheet上有这么一段:<br />"In Power_OFF mode, only VDDi and VDDiarm will be turned off, which is controlled by PWREN pin.<br />If PWREN signal is active(H), VDDi and VDDiarm are supplied by an external voltage regulator. If PWREN pin is<br />inactive (L), the VDDi and VDDiarm are turned off."<br /><br />还有这么一句:<br />"PWREN O 2.0V core power on-off control signal"--ver:1.0<br />"PWREN O 1.8V core power on-off control signal"--ver:1.2<br /><br />第一段是说:PWREN的高低可以控制2410的掉电模式;<br />第二段是说:PWREN的控制给内核供电的电压是1.8v还是2.0v;<br /><br />所以不明白在硬件上PEREN到底该怎么连了?<br /><br />请知道的指教一下!谢谢! |
