The stack pointer for stack 'Stack' is outside the stack range
 楼主| cym_anhui 发表于 2015-3-26 14:50 | 显示全部楼层 |阅读模式
The stack pointer for stack 'Stack' (currently Memory:0x7B) is outside the stack range (Memory:0x3728 to Memory:0x4400)
IAR在仿真430F5247时,经常出现这个提示,为什么?不能断点运行
dirtwillfly 发表于 2015-3-29 21:06 | 显示全部楼层
堆栈超出了指定范围,可以右击工程\options\general options\stack/heap中设置堆栈空间大小
