用万利的板子学M3,环境是MDK3.24,用NVIC,EXIT做两个按键分别控制两个LED的实验:KEY2控制LD1亮灭,KEY3控制LD3亮灭 <br /><br />一开始开了level 3的优化,结果只有KEY2控制LD1亮灭可以起作用,KEY3不起作用。 <br />调了半天没有发现问题在哪里,两个按键,两个LED的设置是一模一样的。后来把优化给关了,就都正常了 <br />哪位高手可以解释下吗? <br /><br />程序中没有使用自己定义的变量<br /><br />工程在这里:<br />http://www.**.cn/bbs/bbs_upload540590/files_11/**_503054.rar<br /><br /><br />EXTI的配置 <br />void EXTI_Configuration(void) <br />{ <br /> EXTI_InitTypeDef EXTI_InitStructure; <br /><br /> /* Connect (Key Button EXTI Line to Key Button) GPIO Pin */ <br /> GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource3); <br /> /* Configure Key Button EXTI Line to generate an interrupt on falling edge*/ <br /> EXTI_InitStructure.EXTI_Line = EXTI_Line3; <br /> EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; <br /> EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; <br /> EXTI_InitStructure.EXTI_LineCmd = ENABLE; <br /> EXTI_Init(&EXTI_InitStructure); <br /><br /> /* Connect (Key Button EXTI Line to Key Button) GPIO Pin */ <br /> GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource4); <br /> /* Configure Key Button EXTI Line to generate an interrupt on falling edge */ <br /> EXTI_InitStructure.EXTI_Line = EXTI_Line4; <br /> EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; <br /> EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; <br /> EXTI_InitStructure.EXTI_LineCmd = ENABLE; <br /> EXTI_Init(&EXTI_InitStructure); <br />} <br /><br /><br />NVIC的配置 <br />void NVIC_Configuration(void) <br />{ <br /> NVIC_InitTypeDef NVIC_InitStructure; <br /> <br />#ifdef VECT_TAB_RAM <br /> /* Set the Vector Table base location at 0x20000000 */ <br /> NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); <br />#else /* VECT_TAB_FLASH */ <br /> /* Set the Vector Table base location at 0x08000000 */ <br /> NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); <br />#endif <br /><br /> /* Configure one bit for preemption priority */ <br /> NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); <br /> <br /> /* Enable the EXTI3 Interrupt*/ <br /> NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQChannel; <br /> NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; <br /> NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; <br /> NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; <br /> NVIC_Init(&NVIC_InitStructure); <br /> <br /> /* Enable the EXTI4 Interrupt */ <br /> NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQChannel; <br /> NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; <br /> NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; <br /> NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; <br /> NVIC_Init(&NVIC_InitStructure); <br />} <br /><br />GPIO的配置 <br />void GPIO_Configuration(void) <br />{ <br /> GPIO_InitTypeDef GPIO_InitStructure; <br /><br /> /* Configure (PC.04 -- PC.11) as (Output push-pull) */ <br /> GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 |GPIO_Pin_6 | GPIO_Pin_7; <br /> GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; <br /> GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; <br /> GPIO_Init(GPIOC, &GPIO_InitStructure); <br /><br /> /* Configure (PD.03, PC.04, PC.11 -- PC.15 as input floating) */ <br /> GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_11 | GPIO_Pin_12 | <br /> GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; <br /> GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; <br /> GPIO_Init(GPIOD, &GPIO_InitStructure); <br />} <br /><br /><br />下面是两个中断处理 <br />void EXTI3_IRQHandler(void) <br />{ <br /> GPIO_WriteBit(GPIOC, GPIO_Pin_7, (BitAction)((1-GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_7)))); <br /><br /> /* Clear the Key Button EXTI line pending bit */ <br /> EXTI_ClearITPendingBit(EXTI_Line3); <br />} <br /><br />void EXTI4_IRQHandler(void) <br />{ <br /> GPIO_WriteBit(GPIOC, GPIO_Pin_5, (BitAction)((1-GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_5)))); <br /><br /> /* Clear the Key Button EXTI line pending bit */ <br /> EXTI_ClearITPendingBit(EXTI_Line4); <br />} |
