Dear all.
Kernel version 3.10.53 使用yocto编译的 for mfgtool zimage.
使用mfgtool烧录的时候. EMMC模式
mfgtool显示 write system.img的时候.
kernel carsh
信息如下.
谁有遇到过.
UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk3p7.
utp_poll: pass returned.
UTP: received command 'pipe dd of=/dev/mmcblk3p5 bs=512'
pid is 165, UTP: executing "dd of=/dev/mmcblk3p5 bs=512"
UTP: sending Success to kernel for command pipe dd of=/dev/mmcblk3p5 bs=512.
------------[ cut here ]------------
WARNING: at mm/vmalloc.c:126 vmap_page_range_noflush+0x174/0x1b8()
Modules linked in:
CPU: 0 PID: 121 Comm: file-storage Not tainted 3.10.53-1.1.0_ga-mfgtool+g496fbe0 #31
[<80013b84>] (unwind_backtrace+0x0/0xf4) from [<80011584>] (show_stack+0x10/0x14)
[<80011584>] (show_stack+0x10/0x14) from [<8002c1d0>] (warn_slowpath_common+0x54/0x6c)
[<8002c1d0>] (warn_slowpath_common+0x54/0x6c) from [<8002c284>] (warn_slowpath_null+0x1c/0x24)
[<8002c284>] (warn_slowpath_null+0x1c/0x24) from [<800b8574>] (vmap_page_range_noflush+0x174/0x1b8)
[<800b8574>] (vmap_page_range_noflush+0x174/0x1b8) from [<800b9a3c>] (map_vm_area+0x2c/0x7c)
[<800b9a3c>] (map_vm_area+0x2c/0x7c) from [<800ba188>] (__vmalloc_node_range+0x100/0x210)
[<800ba188>] (__vmalloc_node_range+0x100/0x210) from [<800ba534>] (vmalloc+0x54/0x5c)
[<800ba534>] (vmalloc+0x54/0x5c) from [<803e2c4c>] (utp_user_data_alloc+0x14/0x48)
[<803e2c4c>] (utp_user_data_alloc+0x14/0x48) from [<803e596c>] (fsg_main_thread+0xa18/0x1fec)
[<803e596c>] (fsg_main_thread+0xa18/0x1fec) from [<8004a10c>] (kthread+0xb4/0xb8)
[<8004a10c>] (kthread+0xb4/0xb8) from [<8000e018>] (ret_from_fork+0x14/0x3c)
---[ end trace cbd7264739d6f55e ]---
vmalloc: allocation failure, allocated 69632 of 73728 bytes
file-storage: page allocation failure: order:0, mode:0xd2
CPU: 0 PID: 121 Comm: file-storage Tainted: G W 3.10.53-1.1.0_ga-mfgtool+g496fbe0 #31
[<80011584>] (show_stack+0x10/0x14) from [<80094808>] (warn_alloc_failed+0xe0/0x118)
[<80094808>] (warn_alloc_failed+0xe0/0x118) from [<800ba264>] (__vmalloc_node_range+0x1dc/0x210)
[<800ba264>] (__vmalloc_node_range+0x1dc/0x210) from [<800ba534>] (vmalloc+0x54/0x5c)
Mem-info:
DMA per-cpu:
CPU 0: hi: 186, btch: 31 usd: 9
CPU 1: hi: 186, btch: 31 usd: 123
CPU 2: hi: 186, btch: 31 usd: 22
CPU 3: hi: 186, btch: 31 usd: 154
active_anon:84 inactive_anon:0 isolated_anon:0
active_file:788 inactive_file:15971 isolated_file:0
unevictable:0 dirty:11985 writeback:0 unstable:0
free:393731 slab_reclaimable:1940 slab_unreclaimable:983
mapped:315 shmem:0 pagetables:15 bounce:0
free_cma:47648
DMA free:1574924kB min:4836kB low:6044kB high:7252kB active_anon:336kB inactive_anon:0kB active_file:3152kB inactive_file:63884kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:1826816kB managed:1461764kB mlocked:0kB dirty:47940kB writeback:0kB mapped:1260kB shmem:0kB slab_reclaimable:7760kB slab_unreclaimable:3932kB kernel_stack:536kB pagetables:60kB unstable:0kB bounce:0kB free_cma:190592kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
lowmem_reserve[]: 0 0 0
DMA: 31*4kB (UEMC) 22*8kB (UMC) 18*16kB (UEMC) 4*32kB (MC) 7*64kB (UMC) 1*128kB (M) 5*256kB (UEM) 5*512kB (MC) 7*1024kB (UMC) 5*2048kB (M) 5*4096kB (UM) 5*8192kB (EMC) 5*16384kB (UEMC) 43*32768kB (UMRC) = 1574924kB
16777 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
456704 pages of RAM
394124 free pages
7469 reserved pages
2433 slab pages
12500 pages shared
0 pages swap cached
g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage |
