Cirrus Logic最新ARM9芯片EP9608
 楼主| fanzs0929 发表于 2009-4-18 10:23 | 显示全部楼层 |阅读模式
ARM926&nbsp;with&nbsp;USB&nbsp;2.0&nbsp;HS,&nbsp;SD/SDIO,2D&nbsp;Graphics&nbsp;with&nbsp;Touch,&nbsp;NAND,SRAM,SmartCard,&nbsp;Ethernet&nbsp;and&nbsp;Low&nbsp;Power.<br />FEATURES&nbsp;<br /><br />.&nbsp;200-MHz&nbsp;ARM926EJ&nbsp;Processor&nbsp;<br />.&nbsp;16-kbyte&nbsp;Instruction&nbsp;and&nbsp;16-kbyte&nbsp;Data&nbsp;Caches&nbsp;<br />.&nbsp;DSP&nbsp;Extensions&nbsp;and&nbsp;Java&nbsp;enabled&nbsp;<br />.&nbsp;Linux.<br />,&nbsp;Microsoft.&nbsp;Windows&nbsp;CE.-enabled&nbsp;MMU&nbsp;<br />.&nbsp;Integrated&nbsp;Peripheral&nbsp;Interfaces:&nbsp;<br />.&nbsp;SD&nbsp;Card&nbsp;2.0&nbsp;Host&nbsp;Controller&nbsp;with&nbsp;legacy&nbsp;MMC&nbsp;and&nbsp;SPI&nbsp;<br />support.&nbsp;Supports&nbsp;high-speed&nbsp;and&nbsp;high&nbsp;capacity&nbsp;cards&nbsp;<br />.&nbsp;Two&nbsp;USB&nbsp;2.0&nbsp;High-speed&nbsp;Host&nbsp;or&nbsp;Device&nbsp;Ports&nbsp;<br />.&nbsp;One&nbsp;USB&nbsp;2.0&nbsp;Full-speed&nbsp;Host&nbsp;or&nbsp;Device&nbsp;Port&nbsp;<br />.&nbsp;Five&nbsp;8&nbsp;or&nbsp;9&nbsp;data&nbsp;bit&nbsp;UARTs&nbsp;with&nbsp;optional&nbsp;hardware&nbsp;flow&nbsp;<br />control.&nbsp;UART0&nbsp;has&nbsp;modem&nbsp;control&nbsp;signaling&nbsp;<br />.&nbsp;24-bit&nbsp;LCD&nbsp;and&nbsp;Raster&nbsp;Interface&nbsp;(RGB&nbsp;8:8:8,5:6:5,&nbsp;5:5:5&nbsp;<br />and&nbsp;24-bit&nbsp;YCbCr&nbsp;4:4:4,&nbsp;16-bit&nbsp;YCbCr&nbsp;4:2:2,&nbsp;ITU656compliant&nbsp;<br />8-bit&nbsp;YCbCr&nbsp;4:2:2)&nbsp;with&nbsp;Genlock&nbsp;support&nbsp;<br />.&nbsp;2D&nbsp;Graphics&nbsp;Accelerator&nbsp;<br />.&nbsp;8-bit&nbsp;NAND&nbsp;FLASH&nbsp;interface&nbsp;(512B&nbsp;or&nbsp;2KB&nbsp;page&nbsp;sizes)&nbsp;<br />.&nbsp;32-bit&nbsp;wide&nbsp;SDRAM&nbsp;Interface&nbsp;(up&nbsp;to&nbsp;4&nbsp;banks),&nbsp;<br />compatible&nbsp;with&nbsp;Mobile&nbsp;SDRAM&nbsp;devices<br />.&nbsp;32/16-bit&nbsp;wide&nbsp;NOR&nbsp;FLASH&nbsp;and&nbsp;SRAM&nbsp;Interface&nbsp;<br />.&nbsp;Hardware-Controlled&nbsp;Master/Slave&nbsp;I2C.&nbsp;Interface&nbsp;<br />.&nbsp;1/10/100&nbsp;Mbps&nbsp;Ethernet&nbsp;MAC&nbsp;<br />.&nbsp;4-,&nbsp;5-,&nbsp;7-,&nbsp;8-Wire&nbsp;Touchscreen&nbsp;Interface&nbsp;with&nbsp;16-bit&nbsp;ADC&nbsp;<br />.&nbsp;8&nbsp;x&nbsp;8&nbsp;Matrix&nbsp;Keypad&nbsp;Scanner&nbsp;<br />.&nbsp;Multimode&nbsp;SPI&nbsp;Port&nbsp;running&nbsp;up&nbsp;to&nbsp;25&nbsp;Mbps&nbsp;<br />.&nbsp;Highly&nbsp;configurable&nbsp;I2S&nbsp;Interface&nbsp;supports&nbsp;up&nbsp;to&nbsp;6channel&nbsp;<br />audio&nbsp;with&nbsp;independent&nbsp;clock&nbsp;domains&nbsp;<br />.&nbsp;PWM&nbsp;Interface&nbsp;<br /><br />手机:13816698198&nbsp;<br />QQ:16951849&nbsp;<br />MSN:diegofanzs@hotmail.com
avr32 发表于 2009-4-18 10:42 | 显示全部楼层
cirrus终于聪明了
资源不错,听说这个ARM是给中国市场定做的?
 楼主| fanzs0929 发表于 2009-4-25 12:22 | 显示全部楼层
对的。是专对中国市场的
zchong 发表于 2009-4-26 07:47 | 显示全部楼层
不是说要全线停产吗
不是说&nbsp;Cirrus&nbsp;Logic的ARM处理器要全线停产了吗
 楼主| fanzs0929 发表于 2009-4-28 17:03 | 显示全部楼层
没有的。一直可以供货
arm4u 发表于 2009-4-29 15:01 | 显示全部楼层
多少钱一颗啊?性价比很重要,不然人家都用S3C2440了
 楼主| fanzs0929 发表于 2009-5-7 21:25 | 显示全部楼层
9608我不做。我主要卖9302、9307、9312和9315
