我对ADC比较感兴趣,发现了点新情况:
根据ST出的新的数据手册 Rev 6,其中可以看出AD精度很高,请看,第65页:
Table 46. ADC accuracy - limited test conditions Symbol Parameter Typ Max Unit ET Total unadjusted error ±1.3 ±2 LSB
关键是,Test conditions为: fPCLK2 = 56 MHz, fADC = 14 MHz, RAIN < 10 kΩ, VDDA = 3 V to 3.6 VTA = 25 °C Measurements made after ADC calibration VREF+ = VDDA
而这符合多数人的使用实际情况:VDDA = 3 V to 3.6 |
