**具体见下面的链接~~~~~
3040|2
 楼主| Analog921 发表于 2008-6-3 13:09 | 显示全部楼层 |阅读模式
请看下面一段话“Understand Noise Sources: The three dominant sources of A/D noise are quantization, ac (phase noise, or jitter in sampling of ac signals), and wideband (white noise, digital feedthrough, etc.). The last one is the most amenable to dc histogram testing. Quantization noise is a large contributor to the signal's error power, but (in the absence of drift during the measurement) it does not cause multiple code "hits" to show up in a dc histogram. AC noise, resulting from aperture jitter, is also not a factor when the input signal is dc. The remaining source, wideband noise, is the major input-referred noise component measured by the histogram technique. ”
为什么在DC下面,量化噪声对DC测量的影响很小?
比如在重量,温度等的测试测量中我们主要精力在于减小White Noise,以提高无噪声编码分辨率~~~~~~~
 楼主| Analog921 发表于 2008-6-3 13:10 | 显示全部楼层
**具体见下面的链接~~~~~
http://www.analog.com/library/analogDialogue/archives/29-2/cnvtrnoise.html
dujb 发表于 2008-6-3 13:59 | 显示全部楼层
主要原因是平均效应
由于量化噪声是均匀的,而直流测量中通过平均值可以去掉这些噪声
这里的关键是有知道输入的直流量有随即噪声存在,不是理想的稳恒量
