关学于MCC18编译问题
3904|2
499767|  楼主 | 2007-9-5 10:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                 SIGN       0x000041       data     extern C:\MCC18\SRC\TRADIT~\MATH\cmath18.asm
            __FPFLAGSbits
                            0x000042       data     extern C:\MCC18\SRC\TRADIT~1\MATH\cmath18.asm
                __FPFLAGS   0x000042       data     extern C:\MCC18\SRC\TRADIT~1\MATH\cmath18.asm
                  __REMB3   0x000043       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB7   0x000043       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                  __REMB2   0x000044       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB6   0x000044       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                  __REMB1   0x000045       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB5   0x000045       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                  __REMB0   0x000046       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB4   0x000046       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB3   0x000047       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB2   0x000048       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB1   0x000049       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __AARGB0   0x00004a       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                   __AEXP   0x00004b       data     extern C:\MCC18\SRC\TRADIT~1\MATH\aarg.asm
                 __BARGB3   0x00004c       data     extern C:\MCC18\SRC\TRADIT~1\MATH\barg.asm
                 __BARGB2   0x00004d       data     extern C:\MCC18\SRC\TRADIT~1\MATH\barg.asm
                 __BARGB1   0x00004e       data     extern C:\MCC18\SRC\TRADIT~1\MATH\barg.asm
                 __BARGB0   0x00004f       data     extern C:\MCC18\SRC\TRADIT~1\MATH\barg.asm
                   __BEXP   0x000050       data     extern C:\MCC18\SRC\TRADIT~1\MATH\barg.asm
                 __TEMPB3   0x000051       data     extern C:\MCC18\SRC\TRADIT~1\MATH\temparg.asm
        __TEMPB2   0x000052       data     extern C:\MCC1\SRC\TRADIT~1\MATH\temparg.asm
                 __TEMPB1   0x000053       data     extern C:\MCC18\SRC\TRADIT~1\MATH\temparg.asm
                 __TEMPB0   0x000054       data     extern C:\MCC18\SRC\TRADIT~1\MATH\temparg.asm
                   __TEMP   0x000054       data     extern C:\MCC18\SRC\TRADIT~1\MATH\temparg.asm
                  __tmp_0   0x000055       data     static D:\dzr-100c\dzr-100c.c
            DelayCounter2   0x00005e       data     extern C:\MCC18\SRC\TRADIT~1\DELAYS\delayd2.asm
            DelayCounter1   0x00005f       data     extern C:\MCC18\SRC\TRADIT~1\DELAYS\delayd1.asm
由于一些原因我需要把一些全局变量放入快速存储取中也就是00-0x5f中,可是却发现40-5f被这些东西占用了出现下面的错误,为什么呢,如果我希望使用这些地址该怎么做呢?
MPLINK 4.13, Linker
Copyright (c) 2007 Microchip Technology Inc.
Error - section '.tmpdata' can not fit the section. Section '.tmpdata' length=0x00000009
Errors    : 1
richardsen| | 2007-9-5 22:07 | 只看该作者
改.lkr文件
499767|  楼主 | 2007-9-6 07:59 | 只看该作者
如何修改呢?能麻烦老哥你详细说下么
