VLSI Solution Oy 推出支持多种格式解码和OGG格式编码的芯片
4055|3
aivenk|  楼主 | 2007-9-17 20:58 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
VS1053 – A multi- format high performance audio codec
Tampere, Finland, 13th of September 2007 - VLSI Solution announced today the
VS1053 audio decoder/encoder IC.
VS1053 is the most advanced slave audio circuit of VLSI Solution's product family. In
addition to being able to decode MP1, MP2, MP3, WMA, WAV, IMA ADPCM,
General Midi 1, Ogg Vorbis, LC- AAC and HE- AAC file formats, it can also record in
IMA ADPCM and Ogg Vorbis file formats.
The device features low power and high performance. The integrated DAC has 100
dB SNR, thus it can accurately reproduce all industry standard formats. The
sophisticated HE- AAC decoder is able to provide high quality sound for low bit rate
internet streaming files.
The on- chip stereo ADC features over 90 dB SNR, thus providing high- quality
recording from the line out or headphone connectors of external music devices. For
recording, Ogg Vorbis encoder can be loaded into the customization RAM of the
device to achive near CD quality stereo sound at medium bit rates (100 kbit/s), or
speech- quality mono sound at bitrates lower than 20 kbit/s. The Ogg Vorbis encoder
will be available for free download in October 2007.
The device has 16 KiB of customization program RAM memory which is more than
three times the memory of VLSI's earlier audio codecs. The program RAM broadens
the capabilities of VS1053 to include new audio applications such as echo
cancellation for mobile phone or VOIP.
VS1053 contains VLSI Solution's proprietary EarSpeaker Spatial Processing
technology. This emulates a listening room to move music outside the listener's head
as if it would come from real loudspeakers.
The device runs with any external clock
between 12 and 13 MHz. This makes it
possible to use the USB or GSM clock
domains of an existing application.
VS1053 is offered in LQFP- 48
7x7x1.4mm RoHS compatible package.
Engineering samples and evaluation kit
are immediately available. Volume
production is expected to start
Q1/2008.
www.vlsi.fi
索取样片:www.megadiy.com
相关链接:http://www.megadiy.com
