[DemoCode下载]
新唐MINI51 ADC模块初始化设置及应用实例
1196|2
奥德赛|  楼主 | 2016-3-7 17:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "Register_Bit.h"   //包含位定义文件
//ADC通道号定义
#define     ADC_Chanel0         (uint8_t)CHEN0
#define     ADC_Chanel1         (uint8_t)CHEN1
#define     ADC_Chanel2         (uint8_t)CHEN2
#define     ADC_Chanel3         (uint8_t)CHEN3
#define     ADC_Chanel4         (uint8_t)CHEN4
#define     ADC_Chanel5         (uint8_t)CHEN5
#define     ADC_Chanel6         (uint8_t)CHEN6
#define     ADC_Chanel7         (uint8_t)CHEN7
#define     ADC_IEN_ENB         ADCR |= ADIE; NVIC_ISER |= ADC_INT
#define     ADC_IEN_DIS         ADCR &= ~ADIE; NVIC_ISER &= ~ADC_INT
// 函数名称:Init_Adc
// 函数功能:adc初始化
// 入口参数:无
// 出口参数:无
void Init_Adc(void)
//ADC输入时钟除频    器分频 12M/2 = 6M  ADC最大频率为6M
    uint8_t Tmp = 2 ;
    /* Reset ADC IP */
    IPRSTC2 |= ADC_RST;
    IPRSTC2 &= ~ADC_RST;
    /* ADC engine clock enable */
    APBCLK |= ADC_CLKEN;
    CLKSEL1 = CLKSEL1 & (~ADC_CLK) | ADC_12M_32K;
    /* Set ADC divisor */
//    CLKDIV |= 0x00050000;
    Tmp = Tmp - 1 ;
    CLKDIV = (CLKDIV & (~(255<<16))) | (Tmp<<16) ;
    /* ADC enable */
    ADCR |= ADEN;
    /* Set the ADC channel */
//    ADCHER |= CHEN0;
    /* Clear the A/D interrupt flags for safe */
    ADSR |= ADF;     //写1清除AD转换结束标志
    ADC_IEN_DIS ; //AD中断不使能
//  ADC_IEN_ENB ;
// 函数名称:ADC_IoInit
// 函数功能:ADC IO 初始化
// 入口参数:无
// 出口参数:无
void ADC_AN0IoInit(void)
    /* Configure P5.3 as analog input pin */
    P5_MFP = (P5_MFP & (~P53_MFSEL)) | P53_AIN0;
    /* Disable P5.3 digital input path */
    P5_OFFD |= OFFD3;
    /* Configure P5.3 as input mode */
    P5_PMD = P5_PMD & (~Px3_PMD) | Px3_IN;
//=====通道1 IO ============
void ADC_AN1IoInit(void)
    /* Configure P1.0 as analog input pin */
    P1_MFP = (P1_MFP & (~P10_MFSEL)) | P10_AIN1;
    /* Disable P1.0 digital input path */
    P1_OFFD |= OFFD0;
    /* Configure P1.0 as input mode */
    P1_PMD = P1_PMD & (~Px0_PMD) | Px0_IN;
// 函数名称:ADC_Switch
// 函数功能:ADC 通道转换使能
// 入口参数:无
// 出口参数:无
uint16_t ADC_Switch(uint8_t Chanel)
    uint16_t   u16Tmp = 0 ;
    ADCR &= ~ADST;    //清启动位
    ADCHER = (ADCHER & (~(255))) | Chanel ;
    /* StartADC */
    ADCR |= ADST;
//      P00_ON ;
    while((ADSR & ADF)==0) ; //等待AD转换结束
//      P00_OFF ;
    ADSR |= ADF ;   //写1清除AD转换结束标志
    u16Tmp = (uint16_t)(ADDR0 & 0x000003FF);
    return  u16Tmp ;
//----实例应用-----
    Init_Adc() ; //ADC初始化设置
    ADC_AN0IoInit() ; //通道0 IO设置
    ADC_AN1IoInit() ; //通道1 IO设置
//---主程序-----
void main(void)
    while(1)
        while(!F_10MS); //10MS跑一次主程序
        F_10MS = 0 ;
        g_u16Tmp = ADC_Switch(ADC_Chanel0) ; //转换通道0
李香兰| | 2016-3-8 20:46 | 只看该作者
这个新唐mini51的adc也是12位的吧
