【试用】+GD32F207ZE的PWM测试应用
1586|2
看了一下应用手册和开发板原理图发现可以利用开发板上的LED中的2个做呼吸灯效果。通过开发板硬件手册可以看到,LD5和LD6两个LED占用PD12和PD13引脚。通过GD32用户手册我们可以看到,TIME4的通道1和通道2通过引脚映射正好也占用了PD12和PD13,因此产生了利用TIME4的通道1和通道2产生PWM可调占空比输出驱动LED灯,产生呼吸灯效果。
程序已GD32的例程为基础,添加TIME4的初始化,PWM输出初始化,输出占空比动态调整函数接口。
*  ¹¦ÄÜ£º³õʼ»¯Óû§LedÉ豸        *
*  ²ÎÊý£ºÎÞ        *
*  ·µ»Ø£ºÎÞ        *
*  ËµÃ÷£º        *
void EvbLed1Config(void)
    GPIO_InitPara GPIO_InitStructure;
    TIMER2 Configuration: generate 3 PWM signals with 3 different duty cycles:
    TIMER2CLK = SystemCoreClock / 120 = 1MHz
    TIMER2 frequency = 10000/1M = 10ms
    TIMER2 Channel2 duty cycle = (2500/ 10000)* 100 = 25%
    TIMER2 Channel3 duty cycle = (5000/ 10000)* 100 = 50%
    TIMER2 Channel4 duty cycle = (7500/ 10000)* 100 = 75%
    TIMER_BaseInitPara TIMER_TimeBaseStructure;
    TIMER_OCInitPara   TIMER_OCInitStructure;
                RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_GPIOD,ENABLE);
                GPIO_PinRemapConfig(GPIO_REMAP_TIMER4, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_12|GPIO_PIN_13;
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
    GPIO_Init(GPIOD,&GPIO_InitStructure);
                /* TIMER2 clock enable */
    RCC_APB1PeriphClock_Enable(RCC_APB1PERIPH_TIMER4,ENABLE);
    /* TIMER2  configuration */
    TIMER_DeInit(TIMER4);
    TIMER_TimeBaseStructure.TIMER_Prescaler     = 119;
    TIMER_TimeBaseStructure.TIMER_CounterMode   = TIMER_COUNTER_UP;
    TIMER_TimeBaseStructure.TIMER_Period        = 9999;
    TIMER_TimeBaseStructure.TIMER_ClockDivision = TIMER_CDIV_DIV1;
    TIMER_BaseInit(TIMER4,&TIMER_TimeBaseStructure);
    /* CH2,CH3 and CH4 Configuration in PWM mode */
    TIMER_OCInitStructure.TIMER_OCMode      = TIMER_OC_MODE_PWM1;
    TIMER_OCInitStructure.TIMER_OCPolarity  = TIMER_OC_POLARITY_HIGH;
    TIMER_OCInitStructure.TIMER_OutputState = TIMER_OUTPUT_STATE_ENABLE;
    TIMER_OCInitStructure.TIMER_OCIdleState = TIMER_OC_IDLE_STATE_RESET;
    TIMER_OCInitStructure.TIMER_Pulse = 0;
    TIMER_OC1_Init(TIMER4, &TIMER_OCInitStructure);
    TIMER_OC1_Preload(TIMER4,TIMER_OC_PRELOAD_DISABLE);
    TIMER_OCInitStructure.TIMER_Pulse = 9999;
    TIMER_OC2_Init(TIMER4, &TIMER_OCInitStructure);
    TIMER_OC2_Preload(TIMER4,TIMER_OC_PRELOAD_DISABLE);
    /* Auto-reload preload enable */
    TIMER_CARLPreloadConfig(TIMER4,ENABLE);
    /* TIMER enable counter*/
    TIMER_Enable( TIMER4, ENABLE );
*  ¹¦ÄÜ£º¿ØÖÆLedµÄµãÁÁºÍϨÃð        *
*  ²ÎÊý£º(1) index LedµÆ±àºÅ        *
*        (2) cmd   LedµÆµãÁÁ»òÕßϨÃðµÄÃüÁî                                                      *
*  ·µ»Ø£ºÎÞ        *
*  ËµÃ÷£º        *
void EvbLed1Control(int index, int cmd)
    TIMER_OCInitStructure.TIMER_Pulse = cmd%10000;
                if(index==1)
                else
主程序测试代码
#include "example.h"
#if (EVB_EXAMPLE == LED1_EXAMPLE)
/* Óû§Ó¦ÓóÌÐòÈë¿Úº¯Êý */
static int count;
static char flag=0;
int main(void)
    int i;
    /* ÅäÖÃʹÄÜÆÀ¹À°åÉϵÄÉ豸 */
    EvbSetupBoard();
                count = 0;
    PRINTF("¸ÐлʹÓÃColibri¿ª·¢°å\r\n");
    PRINTF("\r\n");
    PRINTF("##### LED ʵÑé #####\r\n");
    PRINTF("\r\n");
    while(1)
        for (i = 0; i< 0x2ffff; i++);
                                EvbLed1Control(1,count);
                                EvbLed1Control(0,9999-count);
                                if(flag ==0)
                                        count+=100;
                                        if(count >= 9999)
                                                flag = 1;
                                                count = 9999;
                                else
                                        count-=100;
                                        if(count <= 0)
                                                flag = 0;
                                                count = 0;
#endif
源代码就不上传整个工程了,把修改的部分上传上来。
time4-pwm-led.rar (1.4 KB)
最后附上视频显示执行效果
http://v.youku.com/v_show/id_XMTUyNTczMjg4OA==.html
mainch| | 2016-5-27 16:50 | 只看该作者
请问用户手册在哪里下载?
coslight|  楼主 | 2016-5-27 23:17 | 只看该作者
可以在论坛里找找
