问题已给我解决了. 估计ZLG的USB driver installer实在太烂了.
1. INF档桉没有定义"SourceDisksFiles/SourceDisksNames", 因此Windows唯有假定所有须要的档桉都在驱动目录的root path (DriverStore).
自动默认 ZLGUSB.sys在 DriverStore 在以下位置
C:\Windows\System32\DriverStore\FileRepository\zlgusb.inf_x86_neutral_0d269258bd5a6c7f
2. 估计你们的installer没有将ZLGUSB.sys正确抄写到DriverStore的目录上, 所以找不到ZLGUSB.sys, 发生错误码"Error 2: The system cannot find the file specified.", 最后导致安装失败.
Solution: 手工将ZLGUSB.sys 抄写到C:\Windows\System32\DriverStore\FileRepository\zlgusb.inf_x86_neutral_0d269258bd5a6c7f
问题立即解决.
ZLG工程师, 你们好好分析一下你们驱动安装log. 看来你们不太符合Windows的规范, 容易有隐患, 今次就是最佳例子.
QueueSingleCopy...
Inf : 'c:\windows\system32\driverstore\filerepository\zlgusb.inf_x86_neutral_0d269258bd5a6c7f\zlgusb.inf'
Missing SourceDisksFiles/SourceDisksNames information from INF.
Source root path based on Main INF
SourceRootPath: 'C:\Windows\System32\DriverStore\FileRepository\zlgusb.inf_x86_neutral_0d269258bd5a6c7f'
{FILE_QUEUE_COPY}
CopyStyle - 0x00000000
{FILE_QUEUE_COPY}
SourceRootPath - 'C:\Windows\System32\DriverStore\FileRepository\zlgusb.inf_x86_neutral_0d269258bd5a6c7f'
SourceFilename - 'ZLGUSB.sys'
TargetDirectory- 'C:\Windows\System32\Drivers'
TargetFilename - 'ZLGUSB.sys'
{FILE_QUEUE_COPY exit(0x00000000)}
source media:
SourcePath - [C:\Windows\System32\DriverStore\FileRepository\zlgusb.inf_x86_neutral_0d269258bd5a6c7f]
SourceFile - [ZLGUSB.sys]
Flags - 0x00000000
{SPFQNOTIFY_NEEDMEDIA}
{SPFILENOTIFY_NEEDMEDIA}
{SPFILENOTIFY_NEEDMEDIA - exit(0x00000000)}
{SPFQNOTIFY_NEEDMEDIA - returned 0x00000000}
source media: SPFQOPERATION_ABORT.
Error 2: The system cannot find the file specified. |
