[技术问答]
头文件定义
1141|3
dragonjun|  楼主 | 2016-5-27 17:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#define UART_FCR_RFITL_1BYTE        (0x0 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 1 byte */
#define UART_FCR_RFITL_4BYTES       (0x1 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 4 bytes */
#define UART_FCR_RFITL_8BYTES       (0x2 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 8 bytes */
#define UART_FCR_RFITL_14BYTES      (0x3 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 14 bytes */
#define UART_FCR_RTS_TRI_LEV_1BYTE        (0x0 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 1 byte */
#define UART_FCR_RTS_TRI_LEV_4BYTES       (0x1 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 4 bytes */
#define UART_FCR_RTS_TRI_LEV_8BYTES       (0x2 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 8 bytes */
#define UART_FCR_RTS_TRI_LEV_14BYTES      (0x3 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 14 bytes */
这个是UART.H头文件中的一部分定义,看不懂。都 是什么意思? 相关资料在哪看
wahahaheihei| | 2016-5-27 20:58 | 只看该作者
看备注啊,
就是设置在FIFO模式下接收数据的触发方式,是多少个字节才触发,
734774645| | 2016-5-28 00:05 | 只看该作者
看后面的注释啊,不认识用谷歌百度一下就知道了。
liuyimao485812| | 2016-5-28 07:56 | 只看该作者
不用全部读懂。
