[STM32F7]
【NUCLEO144】简单熟悉F7,并建立模板
1091|1
9robot|  楼主 | 2016-8-1 18:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
拿到板子有几天了,今天开始学习STM32F767。不同以往,F7不在支持标准库开发,需要使用HAL。之前一直在用STM32F1,并没有尝试过HAL,这次也算是被逼上梁山了吧。F7在论坛里的资料还不像F1和F4那样多。不过开发的思路是差不多的,我是从ST的官网上下载所要用的资料。官网有现成的模板和程序示例可以参考。但是习惯了之前开发时所使用的模板,官网给出的感觉有点乱。决定自己建一个新的模板。不过NUCLEO144使用的是STLINK的MOC功能提供的时钟。因此在时钟设置上需要注意。
static void SystemClock_Config(void)
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  /* Enable HSE Oscillator and activate PLL with HSE as source */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
  RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 432;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 9;
  RCC_OscInitStruct.PLL.PLLR = 7;
  if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    while(1) {};
  /* Activate the OverDrive to reach the 216 Mhz Frequency */
  if(HAL_PWREx_EnableOverDrive() != HAL_OK)
    while(1) {};
  /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
     clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7) != HAL_OK)
    while(1) {};
并不能像开发STM32F1一样,直接在启动文件中已经设置好。需要在初始化时设置时钟来源和时钟频率。
Template.zip
1.03 MB
mmuuss586| | 2016-8-1 19:33 | 只看该作者
谢谢楼主分享;
