[STM32F1]
STM32的TIM1、2、3、4不能同时初始化
1652|5
zsc106|  楼主 | 2016-8-22 16:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位想做个四路PWM频率可调的发生器,可是发现只有TIM3能有PWM 输出。其余三路没有,请高手看看我的使能代码哪里有问题,好长时间不搞了,忘了。
void TIM_GPIO_Config(void)
  /* 设置TIMCLK 为 72MHZ */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM3 | RCC_APB1Periph_TIM4, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD, ENABLE);
  /*GPIOA Configuration: TIM2、TIM3、TIN1 channel 1 alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_6 | GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;           // 复用推挽输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*GPIOB Configuration: TIM4 channel 1 alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
void TIM1_Mode_Config(int freq1)
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
/* PWM信号电平跳变值 */
        u16 CCR1_Val = 40;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = freq1;       //当定时器从0计数到一个定时周期 ,此数值即是TIM1_ARR的值。
                                                //This parameter must be a number between 0x0000 and 0xFFFF.
  TIM_TimeBaseStructure.TIM_Prescaler = 1000;           //设置预分频:1000,即为72MHz/1000=72000  This parameter can be a number between 0x0000 and 0xFFFF
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV2;//TIM_CKD_DIV2 ;        //设置时钟分频系数:2分频
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数模式
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;//TIM_OCMode_PWM1;           //配置为PWM模式1
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;          //设置跳变值,当计数器计数到这个值时,电平发生跳变
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //当定时器计数值小于CCR1_Val时为高电平
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);        //使能通道1
  TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM1, ENABLE);        // 使能TIM1重载寄存器ARR
  /* TIM enable counter */
  TIM_Cmd(TIM1, ENABLE);                   //使能定时器1
void TIM2_Mode_Config(int freq2)
/* PWM信号电平跳变值 */
        u16 CCR1_Val = 40;
    TIM2 Channel1 duty cycle = (TIM2_CCR1/ TIM2_ARR+1)* 100% = 50%
  TIM_TimeBaseStructure.TIM_Period = freq2;       //当定时器从0计数到一个定时周期 ,此数值即是TIM2_ARR的值。
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_OC1Init(TIM2, &TIM_OCInitStructure);        //使能通道1
  TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE);        // 使能TIM2重载寄存器ARR
  TIM_Cmd(TIM2, ENABLE);                   //使能定时器2
void TIM3_Mode_Config(int freq3)
/* PWM信号电平跳变值 */
        u16 CCR1_Val = 4;
    TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR+1)* 100% = 50%
    TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR+1)* 100% = 37.5%
    TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR+1)* 100% = 25%
    TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR+1)* 100% = 12.5%
  TIM_TimeBaseStructure.TIM_Period = freq3;       //当定时器从0计数到一个定时周期 ,此数值即是TIM3_ARR的值。
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);        //使能通道1
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);        // 使能TIM3重载寄存器ARR
  TIM_Cmd(TIM3, ENABLE);                   //使能定时器3
void TIM4_Mode_Config(int freq4)
/* PWM信号电平跳变值 */
        u16 CCR1_Val = 4;
    TIM4 Channel1 duty cycle = (TIM4_CCR1/ TIM4_ARR+1)* 100% = 50%
  TIM_TimeBaseStructure.TIM_Period = freq4;       //当定时器从0计数到一个定时周期 ,此数值即是TIM4_ARR的值。
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_OC1Init(TIM4, &TIM_OCInitStructure);        //使能通道1
  TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4, ENABLE);        // 使能TIM4重载寄存器ARR
  TIM_Cmd(TIM4, ENABLE);                   //使能定时器4
shashaa| | 2016-8-22 17:00 | 只看该作者
zsc106|  楼主 | 2016-8-22 17:12 | 只看该作者
shashaa 发表于 2016-8-22 17:00
TIM_TimeBaseStructure.TIM_Period = freq3;       //当定时器从0计数到一个定时周期 ,此数值即是TIM3_ARR ...
这个我知道,现在TIM3 TIM4都没有问题,请问TIM1的初始化有没有问题?
boy1990| | 2016-8-22 17:33 | 只看该作者
mmuuss586| | 2016-8-22 17:41 | 只看该作者
谢谢分享;
zsc106|  楼主 | 2016-8-22 17:46 | 只看该作者
boy1990 发表于 2016-8-22 17:33
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;//TIM_OCMode_PWM1;           //配置为PWM模式1 ...
什么意思?我发现没有问题,是我板子没有弄出来好。不过TIM1需要设置PWM主输出。
