[STM32F1]
CAN接收中断问题
1254|12
huangchui|  楼主 | 2016-10-26 22:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用以STM32F103ZET6 为MCU的一块板子调试CAN的收发,外围器件是SN65HVD230D(VP230),用的一款USB-CAN的Adapter连接的电脑,通过PC端配套的Cantools 来进行收发。现在的问题是板子可以发数据到电脑上,也就是发送好用,但是接收数据的时候,只有PC上发送AB AA AA AA AA AA AA AA 的时候能进中断
spark周| | 2016-10-26 22:09 | 只看该作者
AB 后面AA的个数任意?
huangchui|  楼主 | 2016-10-26 22:10 | 只看该作者
嗯,发送其它数据,例如11 22 33 44 55 66 77 88  就进不来中断。
zhaoxqi| | 2016-10-26 22:12 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
huangchui|  楼主 | 2016-10-26 22:13 | 只看该作者
void CAN_GPIO_Config(void)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
     /* Configure CAN pin: RX */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
     /* Configure CAN pin: TX */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;                          //定义外部高速晶体启动状态枚举变量
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* ADCCLK = PCLK2/4=18MHZ */
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1 , RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Configure the NVIC Preemption Priority Bits */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  #ifdef VECT_TAB_RAM
                NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  #else
                NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  #endif
   /* Enable the USART2 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable the CAN Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
void CAN_Configuration(void)
        CAN_InitTypeDef        CAN_InitStructure;
        CAN_FilterInitTypeDef  CAN_FilterInitStructure;
   /* CAN Periph clock enable */
        CAN_DeInit(CAN1);
        CAN_StructInit(&CAN_InitStructure);
        CAN_InitStructure.CAN_TTCM = DISABLE;                                        //失能时间触发通信模式
        CAN_InitStructure.CAN_ABOM = DISABLE;                                        //失能自动离线管理
        CAN_InitStructure.CAN_AWUM = DISABLE;                                        //失能自动唤醒模式
        CAN_InitStructure.CAN_NART = DISABLE;                                        //失能非自动重传输模式
        CAN_InitStructure.CAN_RFLM = DISABLE;                                        //失能接收FIFO锁定模式
        CAN_InitStructure.CAN_TXFP = DISABLE;                                        //失能发送FIFO优先级
        CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;                        //CAN硬件工作在普通模式
        /* 200K的波特率 */
        CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;                                        //重新同步跳跃宽度1个时间单位
        CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq;                                                //时间段1为9个时间单位
        CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;                                                //时间段2为8个时间单位
        CAN_InitStructure.CAN_Prescaler = 10;                                                        //时间单位的长度
        CAN_Init(CAN1, &CAN_InitStructure);                                                        //200K=36M/(1+9+8)*10
        CAN_FilterInitStructure.CAN_FilterNumber = 0;                                                //待初始化的过滤器0
        CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;                //标识符屏蔽位模式
        CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;                //1个32位过滤器
        CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;                                        //用来设定过滤器标识符高段位
        CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;                                        //用来设定过滤器标识符低段位
        CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;                                //设定过滤器屏蔽标识符高段位
        CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;                                //设定过滤器屏蔽标识符低段位
        CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_FIFO0;
        CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;                                //使能过滤器
        CAN_FilterInit(&CAN_FilterInitStructure);
下面是中断服务函数
void USB_LP_CAN1_RX0_IRQHandler(void)
        u8 i ;
        CanRxMsg RxMessage;
        RxMessage.StdId=0x00;
        RxMessage.ExtId=0x00;
        RxMessage.IDE=0;
        RxMessage.DLC=0;
        RxMessage.FMI=0;
        RxMessage.Data[0]=0x00;
        RxMessage.Data[1]=0x00;
        RxMessage.Data[2]=0x00;
        RxMessage.Data[3]=0x00;
        RxMessage.Data[4]=0x00;
        RxMessage.Data[5]=0x00;
        RxMessage.Data[6]=0x00;
        RxMessage.Data[7]=0x00;
        CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
        for(i=0; i<8; i++)                                                       //通过串口将CAN收到的数据发出来到串口助手上
                USART_ClearFlag(USART2, USART_FLAG_TC);
                USART_SendData(USART2,RxMessage.Data);
                while(USART_GetFlagStatus(USART2, USART_FLAG_TC)==RESET);
        CAN_FIFORelease(CAN1,CAN_FIFO0);//释放邮箱
最后是主函数
int main(void)
          RCC_Configuration();
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_TIM1 , ENABLE);
        NVIC_Configuration();
        TIM_Configuration();
                CAN_GPIO_Config();
        CAN_Configuration();
        CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);  //CAN中断
        USART_GPIO_Config();
        USART2_Config();
       while(1)                 {
wyjie| | 2016-10-26 22:16 | 只看该作者
你从PC发送过来的数据格式跟接收端设置一直吗?
dengdc| | 2016-10-26 22:18 | 只看该作者
板子上CAN接收到的数据都是通过USART2,发出来的,检测下USART2发送函数是否正确,包括波特率
huangchui|  楼主 | 2016-10-26 22:20 | 只看该作者
串口发送是在CAN接收中断里面的,就是收到AB AA AA ...的时候能进中断,然后串口能发出来,其它时候都进不来中断,也就没法通过串口发出去。。。
huangchui|  楼主 | 2016-10-26 22:22 | 只看该作者
刚才看了下配置也一样啊还有可能是哪里的问题呢?想好几天了想不通啊。。。
wuhany| | 2016-10-26 22:24 | 只看该作者
然后呢?你是怎么应对这个的呢
huangchui|  楼主 | 2016-10-26 22:26 | 只看该作者
jiahy| | 2016-10-26 22:27 | 只看该作者
CanRxMsg RxMessage; 这个应该放在外部定义
huangchui|  楼主 | 2016-10-26 22:28 | 只看该作者
好的,我明天去单位试一下,多谢各位大侠了哈,结贴了先
