[应用相关] STM32的USB实际速度问题
12294|25
hanzhen654 发表于 2019-3-27 23:18 | 显示全部楼层
也就是几百k 用带USB主设备的芯片
hanzhen654 发表于 2019-3-27 23:19 | 显示全部楼层
zhanzr21 发表于 2016-11-12 20:58
CDC的速度最高, F1系列没有测量过极限, 本论坛有人做F4系列的USB3.0, 用外部PHY, 速度达到过30几MB/s,
F1的 ...
F4 USB3.0 有多快?很牛啊
oyhprince 发表于 2019-4-4 13:37 | 显示全部楼层
F4 USB3.0 有多快?很牛啊
目前stm32 全系不外接phy的情况下,都不支持 usb2.0 hs ,stm32主频太慢 是不可能支持 usb3.0的
zhanzr21 发表于 2019-4-11 21:53 | 显示全部楼层
确实STM32F4, F7, H7都是USB 2.0, 本人之前看文档有疏漏.
感谢 @oyhprince 提醒.
F7 Datasheet:
• Advanced connectivity
– USB 2.0 full-speed device/host/OTG
controller with on-chip PHY
– USB 2.0 high-speed/full-speed
device/host/OTG controller with dedicated
DMA, on-chip full-speed PHY and ULPI
H7 Datasheet:
The devices embed two USB OTG high-speed (up to 480 Mbit/s) device/host/OTG
peripheral. OTG-HS1 supports both full-speed and high-speed operations, while OTG-HS2
supports only full-speed operations. They both integrate the transceivers for full-speed
operation (12 Mbit/s). OTG-HS1 features a UTMI low-pin interface (ULPI) for high-speed
operation (480 Mbit/s). When using the USB OTG-HS1 in HS mode, an external PHY
device connected to the ULPI is required.
The USB OTG HS peripherals are compliant with the USB 2.0 specification and with the
OTG 2.0 specification. They have software-configurable endpoint setting and supports
suspend/resume. The USB OTG controllers require a dedicated 48 MHz clock that is
generated by a PLL connected to the HSE oscillator.
oyhprince 发表于 2019-5-9 10:44 | 显示全部楼层
感谢 @oyhprince 提醒.
你可以往下看文档的具体那一章节,他都说如果需要hs
,必须外接扩展ic
