PRT0DM是什么意思
825|5
ousj|  楼主 | 2016-11-19 23:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我定义io口是用#define Port0_2(b) (PRT0DR=(b==0)?(PRT0DR&0xFB):(PRT0DR|0x04))
PRT0DM是什么意思
morrisk| | 2016-11-19 23:02 | 只看该作者
PRT0DR和PRT0DM等就是寄存器名称,相应解释在datasheet可以找到
ousj|  楼主 | 2016-11-19 23:03 | 只看该作者
PRT0DM0     RT0DM1   设置模式
几个模式分别代表什么意义啊???????
zyf部长| | 2016-11-19 23:08 | 只看该作者
DM0,DM1,DM2,一起用于驱动模式
Bits 7 to 0: Drive Mode x[7:0]. In the PRTxDMx registers
there are eight possible drive modes for each port pin. Three
mode bits are required to select one of these modes, and
these three bits are spread into three different registers
(PRTxDM0, PRTxDM1, and PRTxDM2). The bit position of
the effected port pin (for example, Pin[2] in Port 0) is the
same as the bit position of each of the three drive mode register
bits that control the Drive mode for that pin (for example,
bit[2] in PRT0DM0, bit[2] in PRT0DM1, and bit[2] in
PRT0DM2). The three bits from the three registers are
treated as a group. These are referred to as DM2, DM1, and
DM0, or together as DM[2:0].
小小猫咪| | 2016-11-19 23:11 | 只看该作者
这些都是一些寄存器的简称……
ousj|  楼主 | 2016-11-19 23:15 | 只看该作者
唉,还是没有什么结果,算了,先结贴吧,多谢大家啦
