[STM32F1] 【转】IA32 MMU paging初始化代码
642|0
 楼主| 人丑没人疼 发表于 2016-11-27 13:32 | 显示全部楼层 |阅读模式
写了一段IA32 paging通用构造代码,有需要的,可以拿去
[cpp] view plain copy
  • #define PDE_**_RW (1<<1)
  • #define PDE_**_US (1<<2)
  • #define PDE_**_RWT (1<<3)
  • #define PDE_**_PCD (1<<4)
  • * initialize to be zero for page directory and page table
  • static __SECTION_ZERO_INIT("PAGE_DIR") __align(4096) U32 paging_pde[1<<10];
  • static __SECTION_ZERO_INIT("PAGE_TABLE") __align(4096) U32 paging_pte_4k[1<<10][1<<10];
  • * viraddr: virtual address/linear address (must be 4KB align)
  • * phyaddr: physical address (must be 4KB align)
  • * size: in bytes
  • static void paging_4k(U32 viraddr, U32 phyaddr, U32 flags)
  •     U32 viraddr_pd = viraddr>>22;
  •     U32 viraddr_pt = (viraddr>>12) & 0x3FF;
  •     /*page directory*/
  •     paging_pde[viraddr_pd] = (U32)(&(paging_pte_4k[viraddr_pd][viraddr_pt])) & 0xFFFFF000;
  •     paging_pde[viraddr_pd] |= flags;
  •     paging_pde[viraddr_pd] |= 1;
  •     paging_pde[viraddr_pd] &= (~(1<<7));
  •     /*page table*/
  •     paging_pte_4k[viraddr_pd][viraddr_pt] = phyaddr & 0xFFFFF000;
  •     paging_pte_4k[viraddr_pd][viraddr_pt] |= flags;
  •     paging_pte_4k[viraddr_pd][viraddr_pt] |= 1;
  • static void paging_4k_frames(U32 viraddr, U32 phyaddr, U32 size, U32 flags)
  •     U32 i, count = size >> 12;
  •     for(i=0; i<count; i++)
  •         paging_4k(viraddr+((1<<12)*i), phyaddr+((1<<12)*i), flags);
  • * viraddr: virtual address/linear address (must be 4MB align)
  • * phyaddr: physical address (must be 4MB align)
  • * size: in bytes
  • static void paging_4m(U32 viraddr, U32 phyaddr, U32 flags)
  •     paging_pde[viraddr_pd] = phyaddr & 0xFFC00000;
  •     paging_pde[viraddr_pd] |= (1<<7);
  • static void paging_4m_frames(U32 viraddr, U32 phyaddr, U32 size, U32 flags)
  •     U32 i, count = size >> 22;
  •         paging_4m(viraddr+((1<<22)*i), phyaddr+((1<<22)*i), flags);
  • static void paging_frames(U32 viraddr, U32 phyaddr, U32 size, U32 flags)
  •     /* direct mapping */
  •     if(size & 0x3FFFFF)
  •         paging_4k_frames(phyaddr, phyaddr, size, flags);
  •     else
  •         paging_4m_frames(phyaddr, phyaddr, size, flags);
  • void paging_uncache(U32 phyaddr, U32 size)
  •     paging_frames(phyaddr, phyaddr, size, PDE_**_PCD|PDE_**_US|PDE_**_RW);
  • void paging_code(U32 phyaddr, U32 size)
  •     paging_frames(phyaddr, phyaddr, size, PDE_**_US);
  • void paging_data(U32 phyaddr, U32 size)
  •     paging_frames(phyaddr, phyaddr, size, PDE_**_US|PDE_**_RW);
  • void * paging_pde_addr()
  •     return (void *)paging_pde;
  • void paging_enable(void)
  •     U32 cr0;
  •     asm volatile("mov %%cr0, %0": "=r"(cr0));
  •     cr0 |= (1<<31);
  •     asm volatile("mov %0, %%cr0":: "r"(cr0));
  • void paging_setup()
  •     /* peripherial registers */
  •     paging_uncache(0xE0000000, 0x20000000);
  •     /* code & data areas */
  •     paging_uncache(0x00000000, 0x40000000);
  •     paging_enable();
