[STM32F7]
【STM32F769I-DISCO评测】2.板卡硬件概述
1180|8
此贴大概介绍下板卡的硬件吧
Key Features
  • STM32F769NIH6 microcontroller featuring 2 Mbytes of Flash memory and 512+16+4 Kbytes of RAM, in BGA216 package
  • On-board ST-LINK/V2-1 supporting USB reenumeration capability
  • USB ST-LINK functions: virtual COM port, mass storage, debug port
  • 4" capacitive touch LCD display with MIPI® DSI connector (on STM32F769I-DISCO only)
  • SAI audio codec
  • Two audio line jacks, one for input and one for output
  • Stereo speaker outputs
  • Four ST MEMS microphones on DFSDM inputs
  • Two SPDIF RCA input and output connectors
  • Two push-buttons (user and reset)
  • 512-Mbit Quad-SPI Flash memory
  • 128-Mbit SDRAM
  • Connector for microSD card
  • Wi-Fi or Ext-EEP daughterboard connector
  • USB OTG HS with Micro-AB connector
  • Ethernet connector compliant with IEEE-802.3-2002
  • Five power supply options:
    • ST LINK/V2-1
    • USB HS connector
    • 5 V from RJ45 (Power Over Ethernet)
    • 5 V from Arduino or external connector
    • USB charger
  • Power Over Ethernet based on IEEE 802.3af (Powered Device, 48 V to 5 V, 3 W)
  • Power supply output for external applications: 3.3 V or 5 V
  • Arduino Uno V3 connectors
  • Comprehensive free software including a variety of examples, part of the STM32Cube package
  • Supported by a wide choice of integrated development environments
做个简单的翻译:
STM32F769NIH6微控器有2MFlash,RAM空间为512+16+4Kb,封装类型为BGA216
。板载ST_LINK/V2-1,支持USB调试器
。USB ST_LINK功能:虚拟串口,大数据存贮,调试接口
。4寸电容触摸屏LCD带有MIPI DSI接口(只在STM32F769I-DISCO板卡)
。SAI音频编码
。两个音频线接口,输入以及输出
。立体声输出
。四个ST的MEMS麦克风负责DFSDM输入
。两个SPDIF RCA 输入和输出连接器
。两个按钮(复用和复位)
。512M的Quad-SPI,flash
。128M的SDRAM
。MicroSD Card的卡槽
。WIFI和Ext-EEP模块接口
。USB OTG HS带有micro-AB接口
以太网接口IEEE 802.3-2002
。5种供电选择:
   ST LINK/V2-1
   USB HS接头
   。RJ45的5V(以太网供电)
   。Arduino™的5V或者外置的接头
   。USB充电器
基于IEEE 802.3af的以太网供电(供电设备从48V到5V,3W)
。支持3V到5V的外扩展输出
。Arduino Uno V3接口
。整合免费的固件库包括多样化的实例,封装在STM32Cube软件中
。支持多种IDE环境
这里主要介绍下MCU吧,其他器件都是很常用的,这个板卡的主控是STM32F769NIH6,封装是BGA216,主频能到达216MHz。
主控内核和外设框图:
板卡功能框图如下:
板卡的外设器件标注图,本来想学其他试用达人自己PS标注的,现在发现user manual里面有现成的,那么直接截图来给大家分享一下:
                  正面
                                 背面
板卡的BOM表如下: mb1225-B02.rar (22.12 KB)
板卡的原理图如下: en.stm32f769i-disco_sch.zip (1.63 MB)
板卡的gerber如下: en.stm32f769i-disco_gerber.zip (3.48 MB)
主要IC相关DataSheet:
74LVC1G04.pdf (498.15 KB)
128mb_x32_sdram.pdf (4.49 MB)
HMHA2801.pdf (611.13 KB)
LAN8742A-CZ-TR.pdf (1.57 MB)
LD1117S18TR.pdf (1.6 MB)
LD3985M33R.pdf (421.43 KB)
LD39050PU33R.pdf (637.71 KB)
MP34DT01.pdf (747.89 KB)
MT25Q_QLKT_L_512_ABB_0.pdf (989.5 KB)
MX25L51245G, 3V, 512Mb, v1.5.pdf (1.73 MB)
PM8800A.pdf (547.76 KB)
ST890CDR.pdf (935.59 KB)
STM32F103CBT6.pdf (1.91 MB)
STM32F769NIH6.pdf (3.3 MB)
STMPS2151STR.pdf (2.6 MB)
TS431AILT.pdf (431.31 KB)
USB3320C-EZK.pdf (1.28 MB)
WM8994_ProductBrief_v4.1.pdf (651.57 KB)
了解了相关硬件,接下来会测评相关工作状态下的功耗数据,分享给坛友,期待下吧~
捉虫天师| | 2016-12-16 17:28 | 只看该作者
资料太全面了,MARK一下,留着谁给我个板子了,我弄着玩。
heisexingqisi| | 2016-12-16 21:22 | 只看该作者
一直不明白,那个接口兼容Arduino的接口,但是软件上什么时候可以兼容啊。
cooldog123pp|  楼主 | 2016-12-16 23:19 | 只看该作者
这个不清楚啊 arduino很少玩
cooldog123pp|  楼主 | 2016-12-16 23:20 | 只看该作者
我只是个搬运工 方便大家 省的再去查了 基本全了
zhanzr21| | 2016-12-16 23:26 | 只看该作者
好, 不错!
cooldog123pp|  楼主 | 2016-12-19 08:58 | 只看该作者
多谢 版主点评
heisexingqisi| | 2016-12-21 18:30 | 只看该作者
cooldog123pp 发表于 2016-12-16 23:19
这个不清楚啊 arduino很少玩
ST其实应该提供支持Arduino的开发包就行了,以前我见高手自己移植过。。
dongnanxibei| | 2016-12-21 20:39 | 只看该作者
那个喇叭的芯片是解码IIS的吗
