[技术问答]
新塘M451单片机ADC采集输出不能为0
2797|21
delven|  楼主 | 2017-2-17 15:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠,最近用新塘M451做ADC采集,在IO口接地时ADC输出最小只能为9,采集不能为0,不知是何原因,一下是我初始化ADC的代码,各位大侠帮忙看看。
//时钟配置
/* EADC clock source is 72MHz, set divider to 8, ADC clock is 72/6 MHz */
CLK->CLKDIV0  = ((CLK->CLKDIV0 & ~CLK_CLKDIV0_EADCDIV_Msk) | (((6) - 1) << CLK_CLKDIV0_EADCDIV_Pos));
//I/O口配置
SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB1MFP_Msk | SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk | SYS_GPB_MFPL_PB4MFP_Msk);
SYS->GPB_MFPL |= SYS_GPB_MFPL_PB1MFP_EADC_CH1 | SYS_GPB_MFPL_PB2MFP_EADC_CH2 | SYS_GPB_MFPL_PB3MFP_EADC_CH3 | SYS_GPB_MFPL_PB4MFP_EADC_CH4;
GPIO_DISABLE_DIGITAL_PATH(PB,0x1F);
//ADC配置
void ADC_Init(void)
        /* Reset EADC module */
    SYS->IPRST1 |= SYS_IPRST1_EADCRST_Msk ;
    SYS->IPRST1 &= ~SYS_IPRST1_EADCRST_Msk ;
    EADC->CTL &= ~(EADC_CTL_DIFFEN_Msk);
    EADC->CTL |= (EADC_CTL_DIFFEN_SINGLE_END | EADC_CTL_ADCEN_Msk);
    EADC->CTL &= ~EADC_CTL_SMPTSEL_Msk;
    EADC->CTL |= (6 - 1) << EADC_CTL_SMPTSEL_Pos;//(6 - 1) << EADC_CTL_SMPTSEL_Pos;
        EADC->SCTL[4] &= ~(EADC_SCTL_TRGSEL_Msk | EADC_SCTL_CHSEL_Msk);
    EADC->SCTL[4] |= (EADC_SOFTWARE_TRIGGER | EADC_SCTL_CHSEL(4));
        EADC->SCTL[3] &= ~(EADC_SCTL_TRGSEL_Msk | EADC_SCTL_CHSEL_Msk);
    EADC->SCTL[3] |= (EADC_SOFTWARE_TRIGGER | EADC_SCTL_CHSEL(3));
        EADC->SCTL[2] &= ~(EADC_SCTL_TRGSEL_Msk | EADC_SCTL_CHSEL_Msk);
    EADC->SCTL[2] |= (EADC_SOFTWARE_TRIGGER | EADC_SCTL_CHSEL(2));
        EADC->SCTL[0] &= ~(EADC_SCTL_TRGSEL_Msk | EADC_SCTL_CHSEL_Msk);
    EADC->SCTL[0] |= (EADC_SOFTWARE_TRIGGER | EADC_SCTL_CHSEL(1));
delven|  楼主 | 2017-2-17 15:56 | 只看该作者
更加奇怪的是通道1的ADC在外部加了1K电阻接地,这个IO口测量时有50mV电压,导致采样输出在70左右,这个50mV电压不知怎么消除。
wahahaheihei| | 2017-2-17 20:24 | 只看该作者
跑官方例程序试试看。
wahahaheihei| | 2017-2-17 20:35 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 6 $
* $Date: 15/09/02 10:04a $
* @brief
*           Monitor the conversion result of channel 2 by the digital compare function.
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include "stdio.h"
#include "M451Series.h"
#define PLLCTL_SETTING      CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK           72000000
/* Define global variables and constants        */
volatile uint32_t g_u32AdcCmp0IntFlag;
volatile uint32_t g_u32AdcCmp1IntFlag;
/* Define functions prototype        */
int32_t main(void);
void EADC_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set PLL to Power-down mode and PLLSTB bit in CLK_STATUS register will be cleared by hardware.*/
    CLK_DisablePLL();
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Enable EADC module clock */
    CLK_EnableModuleClock(EADC_MODULE);
    /* EADC clock source is 72MHz, set divider to 8, ADC clock is 72/8 MHz */
    CLK_SetModuleClock(EADC_MODULE, 0, CLK_CLKDIV0_EADC(8));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Configure the GPB0 - GPB3 ADC analog input pins.  */
    SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB0MFP_Msk | SYS_GPB_MFPL_PB1MFP_Msk |
                       SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk);
    SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB0MFP_EADC_CH0 | SYS_GPB_MFPL_PB1MFP_EADC_CH1 |
                      SYS_GPB_MFPL_PB2MFP_EADC_CH2 | SYS_GPB_MFPL_PB3MFP_EADC_CH3);
    /* Disable the GPB0 - GPB3 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PB, 0xF);
void UART0_Init()
    /* Init UART        */
    /* Reset UART IP */
    SYS->IPRST1 |=  SYS_IPRST1_UART0RST_Msk;
    SYS->IPRST1 &= ~SYS_IPRST1_UART0RST_Msk;
    /* Configure UART0 and set UART0 baud rate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
    UART0->LINE = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
/* EADC function test        */
void EADC_FunctionTest()
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|           EADC compare function (result monitor) sample code         |\n");
    printf("\nIn this test, software will compare the conversion result of channel 2.\n");
    /* Set the ADC internal sampling time, input mode as single-end and enable the A/D converter */
    EADC_Open(EADC, EADC_CTL_DIFFEN_SINGLE_END);
    EADC_SetInternalSampleTime(EADC, 6);
    /* Configure the sample module 0 for analog input channel 2 and ADINT0 trigger source */
    EADC_ConfigSampleModule(EADC, 0, EADC_ADINT0_TRIGGER, 2);
    /* Enable EADC comparator 0. Compare condition: conversion result < 0x800; match Count=5 */
    printf("   Set the compare condition of comparator 0: channel 2 is less than 0x800; match count is 5.\n");
    EADC_ENABLE_CMP0(EADC, 0, EADC_CMP_CMPCOND_LESS_THAN, 0x800, 0x5);
    /* Enable EADC comparator 1. Compare condition: conversion result >= 0x800; match Count=5 */
    printf("   Set the compare condition of comparator 1 : channel 2 is greater than or equal to 0x800; match count is 5.\n");
    EADC_ENABLE_CMP1(EADC, 0, EADC_CMP_CMPCOND_GREATER_OR_EQUAL, 0x800, 0x5);
    /* Enable sample module 0 interrupt */
    EADC_ENABLE_SAMPLE_MODULE_INT(EADC, 0, 0x1);
    /* Clear the A/D ADINT3 interrupt flag for safe */
    EADC_CLR_INT_FLAG(EADC, (0x1 << 3));
    /* Enable ADINT3 interrupt */
    EADC_ENABLE_INT(EADC, (0x1 << 3));
    NVIC_EnableIRQ(ADC03_IRQn);
    /* Clear the EADC comparator 0 interrupt flag for safe */
    EADC_CLR_INT_FLAG(EADC, (0x1 << 4));
    /* Enable ADC comparator 0 interrupt */
    EADC_ENABLE_CMP_INT(EADC, 0);
    /* Clear the EADC comparator 1 interrupt flag for safe */
    EADC_CLR_INT_FLAG(EADC, (0x1 << 5));
    /* Enable ADC comparator 1 interrupt */
    EADC_ENABLE_CMP_INT(EADC, 1);
    /* Reset the EADC interrupt indicator and trigger sample module 0 to start A/D conversion */
    g_u32AdcCmp0IntFlag = 0;
    g_u32AdcCmp1IntFlag = 0;
    EADC_START_CONV(EADC, 0x1);
    /* Wait EADC compare interrupt */
    while((g_u32AdcCmp0IntFlag == 0) && (g_u32AdcCmp1IntFlag == 0));
    /* Disable the sample module 0 interrupt */
    EADC_DISABLE_SAMPLE_MODULE_INT(EADC, 0, 0x1);
    /* Disable ADC comparator interrupt */
    EADC_DISABLE_CMP_INT(EADC, 0);
    EADC_DISABLE_CMP_INT(EADC, 1);
    /* Disable compare function */
    EADC_DISABLE_CMP0(EADC);
    EADC_DISABLE_CMP1(EADC);
    if(g_u32AdcCmp0IntFlag == 1)
        printf("Comparator 0 interrupt occurs.\nThe conversion result of channel 2 is less than 0x800\n");
    else
        printf("Comparator 1 interrupt occurs.\nThe conversion result of channel 2 is greater than or equal to 0x800\n");
/* EADC interrupt handler        */
void ADC03_IRQHandler(void)
    if(EADC_GET_INT_FLAG(EADC, (0x1 << 4)))
        g_u32AdcCmp0IntFlag = 1;
        EADC_CLR_INT_FLAG(EADC, (0x1 << 4));/* Clear the A/D compare flag 0 */
    if(EADC_GET_INT_FLAG(EADC, (0x1 << 5)))
        g_u32AdcCmp1IntFlag = 1;
        EADC_CLR_INT_FLAG(EADC, (0x1 << 5));/* Clear the A/D compare flag 1 */
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    EADC_FunctionTest();
    SYS_ResetModule(EADC_RST);
    /* Disable EADC IP clock */
    CLK_DisableModuleClock(EADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC00_IRQn);
    printf("Exit EADC sample code\n");
    while(1);
yiyigirl2014| | 2017-2-17 21:09 | 只看该作者
选择的什么参考?
玛尼玛尼哄| | 2017-2-17 21:22 | 只看该作者
用库函数试试。用寄存器容易漏。
robter| | 2017-2-18 07:21 | 只看该作者
这个没有注意到
戈卫东| | 2017-2-18 09:07 | 只看该作者
有这种问题?关注。。。
734774645| | 2017-2-19 18:46 | 只看该作者
第一次遇到ADC这种问题,以前都是可以输出到0的。
734774645| | 2017-2-19 18:47 | 只看该作者
我记得以前做,都是接地后就是0
delven|  楼主 | 2017-2-20 14:47 | 只看该作者
yiyigirl2014 发表于 2017-2-17 21:09
选择的什么参考?
是用外部输入5V参考电压
delven|  楼主 | 2017-2-20 14:49 | 只看该作者
wahahaheihei 发表于 2017-2-17 20:24
跑官方例程序试试看。
用官方例程下载到官方DEMO板,串口读取出来数据也不为0
稳稳の幸福| | 2017-2-20 16:04 | 只看该作者
好奇怪。
643757107| | 2017-2-20 19:12 | 只看该作者
谁有M451开发板跑一下官方例程试试看。
St小菜鸟| | 2017-2-21 09:37 | 只看该作者
wahahaheihei| | 2017-2-21 20:10 | 只看该作者
换个芯片试试看,是不是这个有问题。
delven|  楼主 | 2017-2-22 22:01 | 只看该作者
用官方的例程下载到官方的DEMO板,还会有这样的问题,很纠结啊!
delven|  楼主 | 2017-2-22 22:03 | 只看该作者
delven|  楼主 | 2017-2-25 23:44 | 只看该作者
总结一下,问题的原因找到了,在ADC口有个输入超过5V的,大概在5.7V,结果这个ADC口影响到了其他的AD口数据读取。
Harvard| | 2017-2-26 10:46 | 只看该作者
放心吧 .新唐的adc还是非常给力的
