[应用相关]
emWin_Menu标题菜单控件使用方法
1348|3
因为emWin的GUIBuilder比较弱智,我们只能用变通的方法创建MENU控件,然后生成C文件之后再做配置修改
(1)用GUIBuilder创建4个MENU控件,第1个横放,另外3个画成竖放形状(但GUIBuilder不能改成竖放,只能生成C文件之后再修改):
天灵灵地灵灵|  楼主 | 2017-8-10 17:03 | 只看该作者
(2)保存为C文件FramewinDLG.c,然后添加到脱机模拟仿真平台CodeBlocks的emwin工程,并且编译运行,修改C文件前的显示效果如下:
(3)修改MENU①②③为竖向:
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
{ FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 320, 240, 0, 0x64, 0 },
{ MENU_CreateIndirect, "Menu", ID_MENU_0, 10, 10, 280, 20, 0, 0x0, 0 },
{ MENU_CreateIndirect, "Menu", ID_MENU_1, 10, 45, 60, 150, MENU_CF_VERTICAL, 0x0, 0 },
{ MENU_CreateIndirect, "Menu", ID_MENU_2, 85, 45, 60, 150, MENU_CF_VERTICAL, 0x0, 0 },
{ MENU_CreateIndirect, "Menu", ID_MENU_3, 160, 45, 60, 150, MENU_CF_VERTICAL, 0x0, 0 },
(4)修改所有Item的ID:
#define ID_MENU_00  (GUI_ID_USER + 10)
#define ID_MENU_01  (GUI_ID_USER + 11)
#define ID_MENU_02  (GUI_ID_USER + 12)
#define ID_MENU_10  (GUI_ID_USER + 13)
#define ID_MENU_11  (GUI_ID_USER + 14)
#define ID_MENU_12  (GUI_ID_USER + 15)
#define ID_MENU_20  (GUI_ID_USER + 16)
#define ID_MENU_21  (GUI_ID_USER + 17)
#define ID_MENU_22  (GUI_ID_USER + 18)
#define ID_MENU_23  (GUI_ID_USER + 19)
#define ID_MENU_24  (GUI_ID_USER + 20)
#define ID_MENU_30  (GUI_ID_USER + 21)
(5)在WM_INIT_DIALOG初始化消息中加入初始化代码,将MENU①加入到主MENU中:
hItem = WM_GetDialogItem(pMsg->hWin, ID_MENU_0);
ItemData.Flags    = 0;
ItemData.hSubmenu = WM_GetDialogItem(pMsg->hWin, ID_MENU_1);
ItemData.Id       = ID_MENU_00;
ItemData.pText    = "File";
MENU_SetItem(hItem, ID_MENU_00, &ItemData);
(6)用同样的代码将MENU②③加入到主MENU中:
ItemData.Flags    = 0;
ItemData.hSubmenu = WM_GetDialogItem(pMsg->hWin, ID_MENU_2);
ItemData.Id       = ID_MENU_01;
ItemData.pText    = "New";
MENU_SetItem(hItem, ID_MENU_01, &ItemData);
ItemData.Flags    = 0;
ItemData.hSubmenu = WM_GetDialogItem(pMsg->hWin, ID_MENU_3);
ItemData.Id       = ID_MENU_02;
ItemData.pText    = "About";
MENU_SetItem(hItem, ID_MENU_02, &ItemData);
(7)用FRAMEWIN_AddMenu()函数将MENU附贴到Framewin顶部:
FRAMEWIN_AddMenu(pMsg->hWin, WM_GetDialogItem(pMsg->hWin, ID_MENU_0));
(8)修改MENU①②③的高度,否则将出现以下显示现象:
(9)在WM_NOTIFY_PARENT消息中(操作屏幕时程序跑到这里)加入代码:
case WM_MENU: //MENU控件触发消息(操作MENU后到这里)
     p_data = (MENU_MSG_DATA*)pMsg->Data.p;
     switch (p_data->MsgType) {
     case MENU_ON_ITEMPRESSED:
         break;
     case MENU_ON_ITEMACTIVATE:
         break;
     case MENU_ON_ITEMSELECT:
         MENU_GetItem(pMsg->hWinSrc, p_data->ItemId, &data);
         if (data.Flags & MENU_IF_DISABLED) break;
         EDIT_SetValue(WM_GetDialogItem(pMsg->hWin, ID_EDIT_0), data.Id);
         break;
     WM_DefaultProc(pMsg);
     break;
天灵灵地灵灵|  楼主 | 2017-8-10 19:02 | 只看该作者
工程文件下载地址。 SeggerEval_WIN32_MSVC_MinGW_GUI_V528_010Menu标题菜单控件使用方法.rar (4.26 MB)
