PIC16F886支持中断嵌套吗?
9416|32
 楼主| busdriver 发表于 2010-11-11 11:24 | 显示全部楼层
按键消抖程序
1.按键扫描程序
void key_scan(void)
        if(step == 0)//in the step of key scanning
                //key scanning
                if(FOUT_ON_OFF != on_off_flag)//if key FOUT_ON_OFF change
                        step = 1;//enter the step of delay
          else if(LED_SWITCH != led_switch_flag)//if key LED_SWITCH change
                else if(!FOUT_UP)//if key FOUT_UP touch
                else if(!FOUT_DOWN)
        else if(step == 1)//in the step of delay
                if(key_timer == 2)//delay timeout
                        step = 0;//reset to the step of key scanning
                        //get key value
                                of_off_flag = FOUT_ON_OFF;
                                key_change = 1;//set key change flag
                                led_switch_flag = LED_SWITCH;
                  else if(FOUT_UP == 0)//if key FOUT_UP touch
                                fout_up_flag = 0;
                        else if(FOUT_DOWN == 0)
                                fout_down_flag = 0;
2.timer 中断延时程序
                        key_timer = 0;//reset key timer
                        key_timer++;//key timet +1
帮忙看看这样消抖有问题吗?
最短延时10ms,最长取决于主循环时间。
 楼主| busdriver 发表于 2010-11-11 11:25 | 显示全部楼层
说明,此四键不会同时被按下,否则一个step变量处理不过来。谢谢
 楼主| busdriver 发表于 2010-11-11 14:32 | 显示全部楼层
1.按键扫描程序:
void key_scan(void)
if(key_step == 0)//in the step of key scanning
  //key scanning
  if(FOUT_ON_OFF != on_off_status)//if key FOUT_ON_OFF change
   key_step = 1;//enter the step of delay
   else if(LED_SWITCH != led_switch_status)//if key LED_SWITCH change
  else if(!FOUT_DOWN)
else if(key_step == 1)//in the step of delay
   key_step = 0;//reset to the step of key scanning
   //get key value
    key_val = KEY_ON_OFF;
    //on_off_swap = 1;//set ON/OFF swap flag
    on_off_status = ~on_off_status;//flip
    key_val = KEY_LED_SWITCH;
    //led_switch_swap = 1;//set LED_SWITCH flag
    led_switch_status = ~led_switch_status;//flip
    if(!on_off_status)//if ON,or else no actions
     up_down_active = 1;
     key_val = KEY_UP;
     //fout_up_flag = 0;
     up_down_active = 1;
     key_val = KEY_DOWN;
     //fout_down_flag = 0;
Function:key action routine
Input:none
Output:none
void key_action(void)
//unsigned char *set_EN_CLKout
unsigned char i;
//unsigned char SET_CLKout_DIV;
switch(key_val)
  case KEY_ON_OFF:
   if(!on_off_status)//ON
    lmk04031_set_word = SET_EN_CLKout;//LMK04031 set word
    lmk04031_set_flag = 1;
    led_decode(led,*fout);
    led_display(led);//refresh LEDs
   else if(on_off_status)//OFF
    lmk04031_set_word = RESET_EN_CLKout;//LMK04031 set word
    for(i=0;i<=4;i++)
     led=10;
    led_display(led);//all off
    break;
  case KEY_LED_SWITCH:
   if(led_switch_status)//channel 0
    //set_EN_CLKout = &SET_EN_CLKout0
    SET_CLKout_DIV = SET_CLKout0_DIV;
    CLKout_DIV = &CLKout0_DIV;
    fout = &fout0;
   else if(!led_switch_status)//channel 3
    //set_EN_CLKout = &SET_EN_CLKout3
    SET_CLKout_DIV = SET_CLKout3_DIV;
    CLKout_DIV = &CLKout3_DIV;
    fout = &fout3;
   break;
  case KEY_UP:
   if(*CLKout_DIV == 32)
    *CLKout_DIV = 1;
   else if((*CLKout_DIV == 12) || (*CLKout_DIV == 16) || (*CLKout_DIV == 20))
    *CLKout_DIV += 4;
   else if(*CLKout_DIV == 24)
    *CLKout_DIV += 6;
   else
    *CLKout_DIV += 2;
   lmk04031_set_word = SET_CLKout_DIV;//LMK04031 set word
   //led_decode(led,*fout);
   //led_display(led);//refresh LEDs
   break;
  case KEY_DOWN:
   if(*CLKout_DIV == 1)
    *CLKout_DIV = 32;
   else if((*CLKout_DIV == 16) || (*CLKout_DIV == 20) || (*CLKout_DIV == 24))
    *CLKout_DIV -= 4;
   else if(*CLKout_DIV == 30)
    *CLKout_DIV -= 6;
   else
    *CLKout_DIV -= 2;
   break;
  default:
   break;
2.中断程序
 楼主| busdriver 发表于 2010-11-11 14:44 | 显示全部楼层
Memory Summary:
    Program space        used  1EE1h (  7905) of  2000h words   ( 96.5%)
    Data space           used    E4h (   228) of   170h bytes   ( 62.0%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    Configuration bits   used     0h (     0) of     2h words   (  0.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
code flash快被装满了,有问题吗?
shizaigaole 发表于 2010-11-11 21:14 | 显示全部楼层
一般情况下,如果不考虑多次按键同时按下的情况,
按键扫描子程序设计可以简化一点,
扫描阶段可以不取具体键盘值,
认为延时到的时候的值就是键盘值。
                //key scanning
                else if(!FOUT_DOWN)
如果键值输入口线都在一组IO口中话,
能否改为
               if( (PORTA&0xab) !=  0x00)             //类似于此
shizaigaole 发表于 2010-11-11 21:30 | 显示全部楼层
你的程序是否还有别的部分,
否则的话就这么一点程序,占用这么大内存不正常。
当然不能使用过期的试用版的Lite 模式的PICC编译器,这样会产生很多垃圾代码。
yewuyi 发表于 2010-11-12 09:59 | 显示全部楼层
这个方案完全用不到什么中断嵌套,甚至连16F57那样没有中断向量的MCU都能轻松完成LED动态扫描显示+KEY识别+UART收发的工作。
当然,现在MCU资源都比较丰富了,我们也没必要那么变态的做设计,假设以一个普通16F88X为例,
LZ至少要弄明白以下一些知识点:
1、前后台的程序主框应该如何搞!?
2、按键如何通过查询的方式进行识别!?
3、如何在不长时间独占CPU的情况下完成LED动态扫描!?
4、UART的收发缓冲能起到什么样的作用!?
5、简单的状态处理
 楼主| busdriver 发表于 2010-11-12 15:29 | 显示全部楼层
1、前后台的程序主框应该如何搞!?
贴出main和中断程序流程图
2、按键如何通过查询的方式进行识别!?
贴出按键扫描和服务程序流程图。
LED用的是静态扫描。
只用到接收缓冲,因为只开了接收中断
5、简单的状态处理
是这样做的,参见主程序流程图
 楼主| busdriver 发表于 2010-11-12 15:32 | 显示全部楼层
回shizaigaole:
1.一般情况下,如果不考虑多次按键同时按下的情况,
按键扫描子程序设计可以简化一点,
扫描阶段可以不取具体键盘值,
认为延时到的时候的值就是键盘值。
十分好的建议!但是很遗憾,不在一个口线上面,且其中两个非轻触按键。
2.你的程序是否还有别的部分,
还有别的程序,请参见上面程序流程图,是指Microchip网站下载的最新MPLAB和PICC,应该没过期。
 楼主| busdriver 发表于 2010-11-12 15:49 | 显示全部楼层
真理越辩越明,开此一贴,收回颇丰,谢谢大家!
 楼主| busdriver 发表于 2010-11-12 17:07 | 显示全部楼层
按键程序更新。见23楼
e掾木 发表于 2010-11-13 23:24 | 显示全部楼层
N年前我贴过一个键盘程序,可惜过了三年才有个家伙看出了门道。有兴趣的去www.picpic.cn
 楼主| busdriver 发表于 2010-11-30 22:50 | 显示全部楼层
那个家伙是谁?
