[市场活动] “美光抢楼大行动——2G U盘免费拿,结果公布啦
55570|490
supperpippo 发表于 2011-3-26 21:19 | 显示全部楼层
祝赛Micron生意兴隆!
5zhong10 发表于 2011-3-26 21:40 | 显示全部楼层
祝贺Micron新的一年出多多的新品,为社会多做贡献!
357482894 发表于 2011-3-26 22:12 | 显示全部楼层
祝贺Micron新的一年更上一层楼!
wdzfd 发表于 2011-3-27 07:39 | 显示全部楼层
祝贺Micron新的一年更上一层楼,市场份额更大!
shjact 发表于 2011-3-27 11:09 | 显示全部楼层
祝贺Micron新的一年更上一层楼,市场更广泛,加油!
357482894 发表于 2011-3-27 11:34 | 显示全部楼层
祝贺Micron新的一年更上一层楼!
yirongfu 发表于 2011-3-27 14:11 | 显示全部楼层
大话存储之美光的创新技术--FLCOS技术
美光不仅有存储产品的创新技术,其FLCOS微显技术也独占鳌头。(以下摘自美光官网)
Micron’s FLCOS family of microdisplays provides full 24-bit color images at 60 frames per second and resolutions as high as SVGA (800 x 600). These reflective microdisplays manipulate light using an incredibly fast type of liquid crystal technology. And because they’re built on a CMOS process, the display panel, image processing, memory, and LED controllers are integrated on a single chip.
In addition to their diminutive size, these displays draw less than 100mW of power—making them perfect for mobile applications like camera viewfinders, heads-up displays, and miniature projectors for cell phones and handhelds. Our FLCOS microdisplays also offer the most compelling combination of clarity, brightness, and color fidelity for this market. All of this advanced functionality is the result of several key patents in fields ranging from liquid crystal chemistry to pixel size. Read on to learn more about the ferroelectric liquid crystal on silicon (FLCOS) technology that makes the speed and image clarity of our microdisplay product line possible.
357482894 发表于 2011-3-27 16:34 | 显示全部楼层
祝贺Micron新的一年更上一层楼!
shjact 发表于 2011-3-27 22:22 | 显示全部楼层
grandnie 发表于 2011-3-27 23:17 | 显示全部楼层
祝贺Micron在新一年里业绩越来越好!
grandnie 发表于 2011-3-27 23:20 | 显示全部楼层
大话存储之美系存储器大厂美光(Micron)2010年全球NAND Flash市占率大跃进,已挤下海力士(Hynix)坐稳全球三哥宝座,在扩产速度上,美光在2011年也不会缺席,与英特尔(Intel)合资的新加坡厂也将在2011年第2季开始投产,对于三星电子(Samsung Electronics)和东芝(Toshiba)2011年也有扩产计画,美光表示不担心供过于求,在产能增加的同时,平板计算机等应用也大幅崛起,预计2011年NAND Flash市场供需可维持健康的状态。
lixiaoxu2meng 发表于 2011-3-28 07:57 | 显示全部楼层
祝贺Micron越来越强大!
hanqi1236 发表于 2011-3-28 10:57 | 显示全部楼层
呃,好复杂的规定啊,顶一下下
grandnie 发表于 2011-3-28 11:08 | 显示全部楼层
祝贺Micron在新一年里,一元复始山河美,万象更新锦绣春。
grandnie 发表于 2011-3-28 11:09 | 显示全部楼层
大话存储之美光科技 (Micron Technology Inc.) 近日宣布推出高容量闪存产品组合,其将在未来延长数年NAND产品的生命周期。通过在同一个 NAND 封装内整合错误管理技术, 新的 Micron® ClearNAND™ 装置解决了 NAND 在传统上面临的由工艺微缩方面所带来的问题。Micron 的 ClearNAND 产品组合为更先进的NAND工艺世代带来新的机遇,使其可用于企业服务器、平板电脑、便携式媒体播放器和其他多种电子消费品。
kallyhu 发表于 2011-3-28 11:13 | 显示全部楼层
大话存储之美光科技 (Micron Technology Inc.) 宣布针对消费性视频与手机应用市场,推出首款兼具精巧体积与高画质效能的 V100 微型投影引擎 (V100 pico projector engine) 。V100采用美光创新的六边型像素相乘技术 (HPX) , 可达到视频输入讯号使用的最佳效率,满足微型显示所需,为微型投影仪与新的使用模式开启无限可能。美光也于10月 13 -16 日在香港举办的国际电子组件与生产技术展 (electronicAsia) 中展示此款产品。
kallyhu 发表于 2011-3-28 11:16 | 显示全部楼层
祝贺Micron新一年企业越办越好!业绩也越来越好!
hengheng1217 发表于 2011-3-28 12:57 | 显示全部楼层
祝贺Micron越来越好! 1# 欧阳小炫
grandnie 发表于 2011-3-28 15:32 | 显示全部楼层
祝贺Micron年年顺景,业绩倍增!
shjact 发表于 2011-3-28 15:33 | 显示全部楼层
祝贺Micron越来越强大
