[STM32F4]
FSMC和UART4冲突
907|5
大笨象会跳舞|  楼主 | 2017-11-27 15:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
      最近在调试STM32F407,同时用到了FSMC功能和UART4功能,发现开启FSMC功能时,UART4无法使用,检查了一下,没有公用的引脚,哪位朋友有遇到同样的情况呢?麻烦指点一下!
大笨象会跳舞|  楼主 | 2017-11-28 14:04 | 只看该作者
哪位大神遇到过呀,都几天了找不出原因
huangcunxiake| | 2017-11-28 14:32 | 只看该作者
没用过串口4
大笨象会跳舞|  楼主 | 2017-11-28 15:17 | 只看该作者
这个是FSMC的初始化:
void FSMC_SRAM_Init(void)
        FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
        FSMC_NORSRAMTimingInitTypeDef FSMC_ReadWriteTimingStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOF | RCC_AHB1Periph_GPIOG,ENABLE); //ʹÄÜPD,PE,PF,PGʱÖÓ
        RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);
        GPIO_InitStructure.GPIO_Pin =( GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10 \
        |GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); //PD0,1,4,5,8,9,10,11,12,13,14,15
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;        //¸´ÓÃģʽ
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;  //100MʱÖÓ
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;      //ÍÆÍêģʽ
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;        //ÉÏÀ­
        GPIO_Init(GPIOD,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11 \
        |GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); //PE0,1,7,8,9,10,11,12,13,14,15
        GPIO_Init(GPIOE,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_12 \
        |GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); //PF0,1,2,3,4,5,12,13,14,15
        GPIO_Init(GPIOF,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_10 ; //PG0,1,2,3,4,5,10
        GPIO_Init(GPIOG,&GPIO_InitStructure);
        //GPIOD¸´ÓÃÅäÖÃ
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);  //PD0
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);  //PD1
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);  //PD4
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);  //PD5
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);  //PD8
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);  //PD9
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC); //PD10
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC); //PD11
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC); //PD12
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC); //PD13
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC); //PD14
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC); //PD15
        //GPIOE¸´ÓÃÅäÖÃ
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FSMC);  //PE0
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FSMC);  //PE1
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);  //PE7
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);  //PE8
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);  //PE9
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC); //PE10
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC); //PE11
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC); //PE12
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC); //PE13
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC); //PE14
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC); //PE15
        //GPIOF¸´ÓÃÅäÖÃ
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource0,GPIO_AF_FSMC);  //PF0
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource1,GPIO_AF_FSMC);  //PF1
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource2,GPIO_AF_FSMC);  //PF2
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource3,GPIO_AF_FSMC);  //PF3
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource4,GPIO_AF_FSMC);  //PF4
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource5,GPIO_AF_FSMC);  //PF5
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource12,GPIO_AF_FSMC); //PF12
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource13,GPIO_AF_FSMC); //PF13
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource14,GPIO_AF_FSMC); //PF14
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource15,GPIO_AF_FSMC); //PF15
        //GPIOG¸´ÓÃÅäÖÃ
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FSMC);  //PG0
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FSMC);  //PG1
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource2,GPIO_AF_FSMC);  //PG2
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource3,GPIO_AF_FSMC);  //PG3
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FSMC);  //PG4
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FSMC);  //PG5
        GPIO_PinAFConfig(GPIOG,GPIO_PinSource10,GPIO_AF_FSMC); //PG10
        FSMC_ReadWriteTimingStructure.FSMC_AddressSetupTime = 0x01; //µØÖ·½¨Á¢Ê±¼ä0¸öHCLK 0ns
        FSMC_ReadWriteTimingStructure.FSMC_AddressHoldTime = 0x01;  //µØÖ·±£³Öʱ¼ä,ģʽAδÓõ½
        FSMC_ReadWriteTimingStructure.FSMC_DataSetupTime = 0x0f;    //Êý¾Ý±£³Öʱ¼ä,15¸öHCLK£¬6*15=90ns
        FSMC_ReadWriteTimingStructure.FSMC_BusTurnAroundDuration = 0x01;
        FSMC_ReadWriteTimingStructure.FSMC_CLKDivision = 0x00;
        FSMC_ReadWriteTimingStructure.FSMC_DataLatency = 0x00;
        FSMC_ReadWriteTimingStructure.FSMC_AccessMode = FSMC_AccessMode_A; //ģʽA
        FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;                       //NOR/SRAMµÄBank3
        FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;     //Êý¾ÝºÍµØÖ·Ïß²»¸´ÓÃ
        FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;                //SRAM´æ´¢Ä£Ê½
        FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;       //16λÊý¾Ý¿í¶È
        FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;   //FLASHʹÓõÄ,SRAMδʹÓÃ
        FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable; //ÊÇ·ñʹÄÜͬ²½´«ÊäģʽϵĵȴýÐźÅ,´Ë´¦Î´Óõ½
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; //µÈ´ýÐźŵļ«ÐÔ,½öÔÚÍ»·¢Ä£Ê½·ÃÎÊÏÂÓÐÓÃ
        FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;                 //ÊÇ·ñʹÄÜ»·Â·Í»·¢Ä£Ê½,´Ë´¦Î´Óõ½
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; //´æ´¢Æ÷ÊÇÔڵȴýÖÜÆÚ֮ǰµÄÒ»¸öʱÖÓÖÜÆÚ»¹ÊǵȴýÖÜÆÚÆÚ¼äʹÄÜNWAIT
        FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //´æ´¢Æ÷дʹÄÜ
        FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;        //µÈ´ýʹÄÜλ,´Ë´¦Î´Óõ½
        FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;    //¶ÁдʹÓÃÏàͬµÄʱÐò
        FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;        //Òì²½´«ÊäÆÚ¼äµÄµÈ´ýÐźÅ
        FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &FSMC_ReadWriteTimingStructure;
        FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &FSMC_ReadWriteTimingStructure;
        FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //FSMC_SRAM³õʼ»¯
        FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3,ENABLE);   //ʹÄÜNOR/SRAM¹¦ÄÜ
大笨象会跳舞|  楼主 | 2017-11-28 15:18 | 只看该作者
这个是UART4的初始化:
void uart4_init(uint32_t bound)
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);     //ʹÄÜGPIOAʱÖÓ
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4,ENABLE);     //ʹÄÜUART4ʱÖÓ
        //´®¿Ú3¶ÔÓ¦Òý½Å¸´ÓÃÓ³Éä
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource0,GPIO_AF_UART4); //GPIOA0¸´ÓÃΪUART4
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource1,GPIO_AF_UART4); //GPIOA1¸´ÓÃΪUART4
        USART_DeInit(UART4);  //¸´Î»´®¿Ú4
        //UART4¶Ë¿ÚÅäÖÃ
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ;         //GPIOA0ÓëGPIOA1
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;       //¸´Óù¦ÄÜ
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //ËÙ¶È50MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;     //ÍÆÍ츴ÓÃÊä³ö
        GPIO_Init(GPIOA,&GPIO_InitStructure);              //³õʼ»¯PA0£¬PA1
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
   //USART4 ³õʼ»¯ÉèÖÃ
        USART_InitStructure.USART_BaudRate = bound;        //²¨ÌØÂÊÉèÖÃ
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//×Ö³¤Îª8λÊý¾Ý¸ñʽ
        USART_InitStructure.USART_StopBits = USART_StopBits_1;     //Ò»¸öֹͣλ
        USART_InitStructure.USART_Parity = USART_Parity_No;        //ÎÞÆæÅ¼Ð£Ñéλ
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//ÎÞÓ²¼þÊý¾ÝÁ÷¿ØÖÆ
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                       //ÊÕ·¢Ä£Ê½
  USART_Init(UART4, &USART_InitStructure);                                       //³õʼ»¯´®¿Ú4
        USART_ClearFlag(UART4, USART_FLAG_TC);
  NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;      //´®¿Ú1ÖжÏͨµÀ
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//ÇÀÕ¼ÓÅÏȼ¶3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =3;                   //×ÓÓÅÏȼ¶3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                           //IRQͨµÀʹÄÜ
        NVIC_Init(&NVIC_InitStructure);                               //¸ù¾ÝÖ¸¶¨µÄ²ÎÊý³õʼ»¯VIC¼Ä´æÆ÷
        USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);         //¿ªÆôÏà¹ØÖжÏ
        USART_Cmd(UART4, ENABLE);                             //ʹÄÜ´®¿Ú4
大笨象会跳舞|  楼主 | 2017-11-28 15:20 | 只看该作者
FSMC初始化过后UAR4就不能用了,不管使用不使用SRAM
