[STM32F0]
STM32F042F4P6 CAN出现初始化不成功
5415|8
用的CubeMx配置的CAN模块,自动生存的代码。发现代码在如下位置,过不去,求助。
HAL_StatusTypeDef HAL_CAN_Init(CAN_HandleTypeDef* hcan)
  uint32_t status = CAN_INITSTATUS_FAILED;  /* Default init status */
  uint32_t tickstart = 0U;
  /* Check CAN handle */
  if(hcan == NULL)
     return HAL_ERROR;
  /* Check the parameters */
  assert_param(IS_CAN_ALL_INSTANCE(hcan->Instance));
  assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TTCM));
  assert_param(IS_FUNCTIONAL_STATE(hcan->Init.ABOM));
  assert_param(IS_FUNCTIONAL_STATE(hcan->Init.AWUM));
  assert_param(IS_FUNCTIONAL_STATE(hcan->Init.NART));
  assert_param(IS_FUNCTIONAL_STATE(hcan->Init.RFLM));
  assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TXFP));
  assert_param(IS_CAN_MODE(hcan->Init.Mode));
  assert_param(IS_CAN_SJW(hcan->Init.SJW));
  assert_param(IS_CAN_BS1(hcan->Init.BS1));
  assert_param(IS_CAN_BS2(hcan->Init.BS2));
  assert_param(IS_CAN_PRESCALER(hcan->Init.Prescaler));
  if(hcan->State == HAL_CAN_STATE_RESET)
    /* Allocate lock resource and initialize it */
    hcan->Lock = HAL_UNLOCKED;
    /* Init the low level hardware */
    HAL_CAN_MspInit(hcan);
  /* Initialize the CAN state*/
  hcan->State = HAL_CAN_STATE_BUSY;
  /* Exit from sleep mode */
  CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_SLEEP);
  /* Request initialisation */
  SET_BIT(hcan->Instance->MCR, CAN_MCR_INRQ);
  /* Get tick */
  tickstart = HAL_GetTick();
  /* Wait the acknowledge */
  while(HAL_IS_BIT_CLR(hcan->Instance->MSR, CAN_MSR_INAK))
  {代码一直在这里执行,跳不出去。感觉是硬件没应答,在其他帖子中有看到说是电源不稳,会造成这种情况,我测了电源,确认电源没问题。不知道还有其他什么情况会导致这样。。。
    if((HAL_GetTick()-tickstart) > CAN_TIMEOUT_VALUE)
      hcan->State= HAL_CAN_STATE_TIMEOUT;
      /* Process unlocked */
      __HAL_UNLOCK(hcan);
      return HAL_TIMEOUT;
  /* Check acknowledge */
  if (HAL_IS_BIT_SET(hcan->Instance->MSR, CAN_MSR_INAK))
    /* Set the time triggered communication mode */
    if (hcan->Init.TTCM == ENABLE)
      SET_BIT(hcan->Instance->MCR, CAN_MCR_TTCM);
    else
      CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_TTCM);
    /* Set the automatic bus-off management */
    if (hcan->Init.ABOM == ENABLE)
      SET_BIT(hcan->Instance->MCR, CAN_MCR_ABOM);
    else
      CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_ABOM);
    /* Set the automatic wake-up mode */
    if (hcan->Init.AWUM == ENABLE)
      SET_BIT(hcan->Instance->MCR, CAN_MCR_AWUM);
    else
      CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_AWUM);
    /* Set the no automatic retransmission */
    if (hcan->Init.NART == ENABLE)
      SET_BIT(hcan->Instance->MCR, CAN_MCR_NART);
    else
      CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_NART);
    /* Set the receive FIFO locked mode */
    if (hcan->Init.RFLM == ENABLE)
      SET_BIT(hcan->Instance->MCR, CAN_MCR_RFLM);
    else
      CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_RFLM);
    /* Set the transmit FIFO priority */
    if (hcan->Init.TXFP == ENABLE)
      SET_BIT(hcan->Instance->MCR, CAN_MCR_TXFP);
    else
      CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_TXFP);
    /* Set the bit timing register */
    WRITE_REG(hcan->Instance->BTR, (uint32_t)(hcan->Init.Mode           |
                                              hcan->Init.SJW            |
                                              hcan->Init.BS1            |
                                              hcan->Init.BS2            |
                                              (hcan->Init.Prescaler - 1U) ));
    /* Request leave initialisation */
    CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_INRQ);
    /* Get tick */
    while(HAL_IS_BIT_SET(hcan->Instance->MSR, CAN_MSR_INAK))
       __HAL_UNLOCK(hcan);
       return HAL_TIMEOUT;
    /* Check acknowledged */
    if(HAL_IS_BIT_CLR(hcan->Instance->MSR, CAN_MSR_INAK))
      status = CAN_INITSTATUS_SUCCESS;
  if(status == CAN_INITSTATUS_SUCCESS)
    /* Set CAN error code to none */
    hcan->ErrorCode = HAL_CAN_ERROR_NONE;
    /* Initialize the CAN state */
    hcan->State = HAL_CAN_STATE_READY;
    /* Return function status */
    return HAL_OK;
  else
    hcan->State = HAL_CAN_STATE_ERROR;
    return HAL_ERROR;
dengrj_2008|  楼主 | 2018-5-6 16:52 | 只看该作者
补充下:端口的配置:
void HAL_CAN_MspInit(CAN_HandleTypeDef* canHandle)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(canHandle->Instance==CAN)
  /* USER CODE BEGIN CAN_MspInit 0 */
  /* USER CODE END CAN_MspInit 0 */
    /* CAN clock enable */
    __HAL_RCC_CAN1_CLK_ENABLE();
    /**CAN GPIO Configuration
    PA11     ------> CAN_RX
    PA12     ------> CAN_TX
    GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF4_CAN;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /* USER CODE BEGIN CAN_MspInit 1 */
  /* USER CODE END CAN_MspInit 1 */
eurphan| | 2018-7-12 11:09 | 只看该作者
请问解决了吗
一路向北lm| | 2018-7-12 13:33 | 只看该作者
先测试下CAN的回环,通的话在机对机发送
一路向北lm| | 2018-7-12 13:34 | 只看该作者
也可以使用CAN分析仪来检测,看下报文
木木guainv| | 2018-7-17 13:23 | 只看该作者
我也遇到过这个问题 后来发现是晶振没有起振
gplus302| | 2018-8-21 14:13 | 只看该作者
楼主的问题解决了么?我也遇到一样的问题,用的是STM32F413的芯片
dengrj_2008|  楼主 | 2020-6-11 20:23 | 只看该作者
单片机BOOT0引脚接个10K电阻到地,解决问题。
