[STM32F0]
F0C8T6 RTC时间,时,分,秒可以正常累加,但是day不累加
1102|2
hxb20122012|  楼主 | 2018-6-12 10:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
u8 RTC_Set(u16 syear,u8 smon,u8 sday,u8 hour,u8 min,u8 sec)
  //RTC_InitTypeDef RTC_InitStructure;
  RTC_DateTimeTypeDef RTC_DateTimeStructure;
if(syear<1970||syear>2099)return 1;
  RTC_DateTimeStructure.Year = (uint8_t)(syear-2000);
    RTC_DateTimeStructure.Month = smon;
    RTC_DateTimeStructure.Date = sday;
    RTC_DateTimeStructure.Week = 3;
    RTC_DateTimeStructure.Hour = hour;
    RTC_DateTimeStructure.Minute = min;
    RTC_DateTimeStructure.Second = sec;
    RTC_SetDateTime(RTC_DateTimeStructure);      //Ê״γõʼ»¯RTC(2016Äê6ÔÂ5ÈÕ ÖÜÆß 12:00:00)
    RTC_WriteBackupRegister(RTC_BKP_DR0, RTC_FLAG_BKP);
return 0;
u8 RTC_Get(void)
RTC_GetDateTime(&RTC_DateTimeStructure);
  calendar.w_year = (u16)RTC_DateTimeStructure.Year+2000;
  calendar.w_month = RTC_DateTimeStructure.Month;
  calendar.w_date = RTC_DateTimeStructure.Date;
  calendar.week = RTC_DateTimeStructure.Week;
  calendar.hour = RTC_DateTimeStructure.Hour;
  calendar.min = RTC_DateTimeStructure.Minute;
  calendar.sec = RTC_DateTimeStructure.Second;
return 0;
问题: 比如  2018-06-12 23:59:50       ,10秒之后, 变成 2018-06-12 0:0:0  ,日期没有变化
程序开启了: ALARM
void RTC_SetAlarm_main(void)
   RTC_AlarmTypeDef RTC_AlarmStructure_main;
   EXTI_InitTypeDef EXTI_InitStructure;
    RTC_Get();
    RTC_AlarmCmd(RTC_Alarm_A,DISABLE);
    RTC_AlarmStructure_main.RTC_AlarmTime.RTC_H12     = 0x00;
    RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Hours   = calendar.hour;
    RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Minutes = calendar.min;
    RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Seconds = calendar.sec;
   if(calendar.sec+ALARM_TIME_SEC>=60)
    RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Seconds =  (calendar.sec+ALARM_TIME_SEC)-60;
    if((calendar.min+1)>=60)
      RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Minutes = (calendar.min+1)-60;
      if((calendar.hour+1)>=24)
       RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Hours   = (calendar.hour+1)-24;
      else
       RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Hours   = calendar.hour+1;
    else
     RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Minutes = calendar.min+1;
   else
    RTC_AlarmStructure_main.RTC_AlarmTime.RTC_Seconds =  calendar.sec+ALARM_TIME_SEC;
//   RTC_AlarmStructure_main.RTC_AlarmDateWeekDay = 0x31;
//   RTC_AlarmStructure_main.RTC_AlarmDateWeekDaySel = RTC_AlarmDateWeekDaySel_Date;
//   RTC_AlarmStructure_main.RTC_AlarmMask = RTC_AlarmMask_DateWeekDay;
  // RTC_SetAlarm(RTC_Format_BCD, RTC_Alarm_A, &RTC_AlarmStructure_main);
    RTC_SetAlarm(RTC_Format_BIN, RTC_Alarm_A, &RTC_AlarmStructure_main);
    RTC_ITConfig(RTC_IT_ALRA, ENABLE);
    /* Enable the alarm */
    RTC_AlarmCmd(RTC_Alarm_A, ENABLE);
   RTC_WaitForSynchro();
void RTC_IRQHandler(void)
  if(RTC_GetITStatus(RTC_IT_ALRA) != RESET)
    RTC_TimeTypeDef RTC_TimeStructure;
   RTC_AlarmTypeDef RTC_AlarmStructure;
    RTC_ClearITPendingBit(RTC_IT_ALRA);
    EXTI_ClearITPendingBit(EXTI_Line17);
好像是ALARM影响了
mmuuss586| | 2018-6-12 13:53 | 只看该作者
应该是你程序日期没更新,跟踪下程序就知道了呀;
你把时间设置为23:59:50
hxb20122012|  楼主 | 2018-6-12 20:23 | 只看该作者
你把时间设置为23:59:50
有这么测试了,就是开启了ALARM 导致无法更新日期,只是我的RTC必须要开启ALARM,因为我需要不断唤醒MCU.
