1.程序源码 下载地址:
#include <STC12c5a.H>
#include<intrins.h>
#include<math.h>
sbit RS=P1^0; //并行的指令/数据选择信号, H数据, L命令
sbit RW=P1^1; //并行读写选择信号, H读, L写
sbit E=P1^2; //并行使能端, H有效, L无效
sbit jiakey=P3^0;
sbit jiankey=P3^1;
#define LcdData P0
unsigned char dati=0;
unsigned char dat[100];
unsigned char over=0;
unsigned int temp=0;
unsigned char mode=0;
unsigned int delnop=0;
unsigned char Lcd_CheckBusy(void)
unsigned char Busy;
LcdData=0xff;
RS=0;
RW=1;
E=1;
_nop_();
Busy=LcdData&0x80;
E=0;
return Busy;
向LCD写入字节数据
void Lcd_WriteData(unsigned char Data)
while(Lcd_CheckBusy());
RS=1;
RW=0;
E=0;
_nop_();
_nop_();
LcdData=Data;
E=1;
_nop_();
_nop_();
E=0;
从LCD中读出数据
unsigned char Lcd_ReadData(void)
unsigned char Temp;
LcdData=0xff;
RS=1;
RW=1;
E=1;
_nop_();
Temp=LcdData;
E=0;
return Temp;
想LCD中写入指令代码
void Lcd_WriteCmd(unsigned char CmdCode)
RS=0;
RW=0;
E=0;
_nop_();
_nop_();
LcdData=CmdCode;
_nop_();
_nop_();
E=1;
_nop_();
_nop_();
E=0;
为加速逻辑运算而设置的掩码表,这是以牺牲空间而换取时间的办法
code unsigned int LcdMaskTab[]={0x0001,0x0002,0x0004,0x0008,0x0010,0x0020,0x0040,0x0080,0x0100,0x0200,0x0400,0x0800,0x1000,0x2000,0x4000,0x8000};
向LCD指定坐标写入一个象素,象素颜色有两种,0代表白(无显示),1代表黑(有显示)
void Lcd_PutPixel(unsigned char x,unsigned char y,unsigned char Color)
unsigned char z,w;
unsigned int Temp;
if(x>=128||y>=64)
return;
Color=Color%2;
w=15-x%16;//确定对这个字的第多少位进行操作
x=x/16;//确定为一行上的第几字
if(y<32) //如果为上页
z=0x80;
else //否则如果为下页
z=0x88;
y=y%32;
//EA=0;
Lcd_WriteCmd(0x36);
Lcd_WriteCmd(y+0x80); //行地址
Lcd_WriteCmd(x+z); //列地址
Temp=Lcd_ReadData();//先空读一次
Temp=(unsigned int)Lcd_ReadData()<<8;//再读出高8位
Temp|=(unsigned int)Lcd_ReadData();//再读出低8位
//EA=1;
if(Color==1) //如果写入颜色为1
Temp|=LcdMaskTab[w];//在此处查表实现加速
else //如果写入颜色为0
Temp&=~LcdMaskTab[w];//在此处查表实现加速
//EA=0;
Lcd_WriteData(Temp>>8);//先写入高8位,再写入低8位
Lcd_WriteData(Temp&0x00ff);
Lcd_WriteCmd(0x30);
//EA=1;
清除Lcd全屏,如果清除模式Mode为0,则为全屏清除为颜色0(无任何显示)
否则为全屏清除为颜色1(全屏填充显示)
void Lcd_Clear(unsigned char Mode)
unsigned char x,y,ii;
unsigned char Temp;
if(Mode%2==0)
Temp=0x00;
else
Temp=0xff;
Lcd_WriteCmd(0x36);//扩充指令 绘图显示
for(ii=0;ii<9;ii+=8)
for(y=0;y<0x20;y++)
for(x=0;x<8;x++)
//EA=0;
Lcd_WriteCmd(x+0x80+ii); //列地址
Lcd_WriteData(Temp); //写数据 D15-D8
Lcd_WriteData(Temp); //写数据 D7-D0
//EA=1;
Lcd_WriteCmd(0x30);
LCD初始化
void Lcd_Reset()
Lcd_WriteCmd(0x30); //选择基本指令集
Lcd_WriteCmd(0x0c); //开显示(无游标、不反白)
Lcd_WriteCmd(0x01); //清除显示,并且设定地址指针为00H
Lcd_WriteCmd(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位
void InitADC()
P1ASF=0X80;
ADC_RES=0;
ADC_CONTR=0xef;
EADC=1;
void adc_isr() interrupt 5 using 1
ADC_CONTR=0xef;
if(over==0)
temp=delnop;
while(temp)
temp--;
dat[dati]=ADC_RES;
dati++;
if(dati>100)
dati=0;
over=1;
void disp_0(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+1,1);
Lcd_PutPixel(x+1,y+2,1);
Lcd_PutPixel(x+1,y+3,1);
Lcd_PutPixel(x+2,y+0,1);
Lcd_PutPixel(x+2,y+4,1);
Lcd_PutPixel(x+3,y+1,1);
Lcd_PutPixel(x+3,y+2,1);
Lcd_PutPixel(x+3,y+3,1);
void disp_1(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+4,1);
Lcd_PutPixel(x+2,y+1,1);
Lcd_PutPixel(x+2,y+2,1);
Lcd_PutPixel(x+2,y+3,1);
Lcd_PutPixel(x+3,y+4,1);
void disp_2(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+0,1);
Lcd_PutPixel(x+3,y+0,1);
void disp_3(unsigned char x,unsigned char y)
void disp_4(unsigned char x,unsigned char y)
void disp_5(unsigned char x,unsigned char y)
void disp_p(unsigned char x,unsigned char y)
Lcd_PutPixel(x+0,y+0,1);
Lcd_PutPixel(x+4,y+0,1);
void disp_k(unsigned char x,unsigned char y)
Lcd_PutPixel(x+0,y+1,1);
Lcd_PutPixel(x+0,y+2,1);
Lcd_PutPixel(x+0,y+3,1);
Lcd_PutPixel(x+0,y+4,1);
void disp_hz(unsigned char x,unsigned char y)
Lcd_PutPixel(x+4,y+1,1);
Lcd_PutPixel(x+4,y+3,1);
Lcd_PutPixel(x+4,y+4,1);
Lcd_PutPixel(x+5,y+1,1);
Lcd_PutPixel(x+5,y+2,1);
Lcd_PutPixel(x+5,y+4,1);
void clr(unsigned char starx,unsigned char stary,unsigned char endx,unsigned char endy)
char x=0;
char y=0;
for(x=starx;x<endx;x++)
for(y=stary;y<endy;y++)
Lcd_PutPixel(x,y,0);
void disp_bj(void)
unsigned char x=0;
unsigned char y=0;
for(x=13;x<114;x++)
Lcd_PutPixel(x,52,1);
for(y=0;y<52;y++)
Lcd_PutPixel(13,y,1);
for(y=0;y<52;y++)
Lcd_PutPixel(114,y,1);
Lcd_PutPixel(13,51,0);
Lcd_PutPixel(13,41,0);
Lcd_PutPixel(13,31,0);
Lcd_PutPixel(13,21,0);
Lcd_PutPixel(13,11,0);
Lcd_PutPixel(13,1,0);
Lcd_PutPixel(114,51,0);
Lcd_PutPixel(114,41,0);
Lcd_PutPixel(114,31,0);
Lcd_PutPixel(114,21,0);
Lcd_PutPixel(114,11,0);
Lcd_PutPixel(114,1,0);
disp_0(5,50);
disp_1(5,40);
disp_2(5,30);
disp_3(5,20);
disp_4(5,10);
disp_5(5,0);
disp_0(117,50);
disp_1(117,40);
disp_2(117,30);
disp_3(117,20);
disp_4(117,10);
disp_5(117,0);
disp_2(13,58);
disp_hz(18,58);
disp_2(38,58);
disp_0(43,58);
disp_hz(48,58);
disp_2(63,58);
disp_0(68,58);
disp_0(73,58);
disp_hz(78,58);
disp_2(88,58);
disp_k(93,58);
disp_hz(98,58);
void line(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1)
int i,dx,dy,e,x,y;
Lcd_PutPixel(x0,y0,1);
Lcd_PutPixel(x1,y1,1);
dx=x1-x0;
dy=y1-y0;
x=x0;
y=y0;
if(dx>0&&dy>0)
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
Lcd_PutPixel(x,y,1);
x++;
e=e+2*dy;
if(e>=0)
y++;
e=e-2*dx;
else
e=-dy;
x=x0;
y=y0;
for(i=0;i<dy;i++)
y++;
e=e+2*dx;
if(e>=0)
x++;
e=e-2*dy;
if(dx<0&&dy<0)
dx=x0-x1;
dy=y0-y1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
x--;
e=e+2*dy;
if(e>=0)
y--;
e=e-2*dx;
else
e=-dy;
for(i=0;i<dy;i++)
y--;
e=e+2*dx;
if(e>=0)
x--;
e=e-2*dy;
if(dx>0&&dy<0)
dy=y0-y1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
x++;
e=e+2*dy;
if(e>=0)
y--;
e=e-2*dx;
else
e=-dy;
for(i=0;i<dy;i++)
y--;
e=e+2*dx;
if(e>=0)
x++;
e=e-2*dy;
if(dx<0&&dy>0)
dx=x0-x1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
x--;
e=e+2*dy;
if(e>=0)
y++;
e=e-2*dx;
else
e=-dy;
for(i=0;i<dy;i++)
y++;
e=e+2*dx;
if(e>=0)
x--;
e=e-2*dy;
if(dx!=0&&dy==0)
if(dx>0)
for(i=0;i<dx;i++)
x++;
else
dx=x0-x1;
for(i=0;i<dx;i++)
x--;
if(dx==0&&dy!=0)
if(dy>0)
for(i=0;i<dy;i++)
y++;
else
dy=y0-y1;
for(i=0;i<dy;i++)
y--;
void disp_ware()
unsigned char x=0;
unsigned char y=0;
clr(14,0,15,52);
for(x=1;x<100;x++)
clr(x+14,0,x+15,52);
line(x+13,51-(dat[x-1]/5),x+14,51-(dat[x]/5));
main()
Lcd_Reset();
Lcd_Clear(0);
InitADC();
disp_bj();
EA=1;
while(1)
if(over)
disp_ware();
if(jiakey==0)
if(mode<3)
mode++;
// while(!jiakey);
if(jiankey==0)
if(mode>0)
mode--;
// while(!jiankey);
switch(mode)
case 0:
delnop=1;
disp_p(91,54);
clr(66,54,71,57);
clr(41,54,46,57);
clr(16,54,21,57);
break;
case 1:
delnop=40;
disp_p(66,54);
clr(91,54,96,57);
clr(41,54,46,57);
clr(16,54,21,57);
break;
case 2:
delnop=440;
disp_p(41,54);
clr(91,54,96,57);
clr(66,54,71,57);
clr(16,54,21,57);
break;
case 3:
delnop=4440;
disp_p(16,54);
clr(91,54,96,57);
clr(41,54,46,57);
clr(66,54,71,57);
break;
default:
break;
over=0;
