[DemoCode下载]
N76E003的GPIO使用
2512|11
xixi2017|  楼主 | 2018-10-29 18:10 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Jan/21/2017
//  File Function: N76E003 GPIO demo code
#include "N76E885.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
////------------------- Define Port as Quasi mode  -------------------
//#define P00_Quasi_Mode                                P0M1&=~SET_BIT0;P0M2&=~SET_BIT0
//#define P01_Quasi_Mode                                P0M1&=~SET_BIT1;P0M2&=~SET_BIT1
//#define P02_Quasi_Mode                                P0M1&=~SET_BIT2;P0M2&=~SET_BIT2
//#define P03_Quasi_Mode                                P0M1&=~SET_BIT3;P0M2&=~SET_BIT3
//#define P04_Quasi_Mode                                P0M1&=~SET_BIT4;P0M2&=~SET_BIT4
//#define P05_Quasi_Mode                                P0M1&=~SET_BIT5;P0M2&=~SET_BIT5
//#define P06_Quasi_Mode                                P0M1&=~SET_BIT6;P0M2&=~SET_BIT6
//#define P07_Quasi_Mode                                P0M1&=~SET_BIT7;P0M2&=~SET_BIT7
//#define P10_Quasi_Mode                                P1M1&=~SET_BIT0;P1M2&=~SET_BIT0
//#define P11_Quasi_Mode                                P1M1&=~SET_BIT1;P1M2&=~SET_BIT1
//#define P12_Quasi_Mode                                P1M1&=~SET_BIT2;P1M2&=~SET_BIT2
//#define P13_Quasi_Mode                                P1M1&=~SET_BIT3;P1M2&=~SET_BIT3
//#define P14_Quasi_Mode                                P1M1&=~SET_BIT4;P1M2&=~SET_BIT4
//#define P15_Quasi_Mode                                P1M1&=~SET_BIT5;P1M2&=~SET_BIT5
//#define P16_Quasi_Mode                                P1M1&=~SET_BIT6;P1M2&=~SET_BIT6
//#define P17_Quasi_Mode                                P1M1&=~SET_BIT7;P1M2&=~SET_BIT7
//#define P20_Quasi_Mode                                P2M1&=~SET_BIT0;P2M2&=~SET_BIT0
//#define P30_Quasi_Mode                                P3M1&=~SET_BIT0;P3M2&=~SET_BIT0
////------------------- Define Port as Push Pull mode -------------------
//#define P00_PushPull_Mode                        P0M1|=SET_BIT0;P0M2&=~SET_BIT0
//#define P01_PushPull_Mode                        P0M1|=SET_BIT1;P0M2&=~SET_BIT1
//#define P02_PushPull_Mode                        P0M1&=~SET_BIT2;P0M2|=SET_BIT2
//#define P03_PushPull_Mode                        P0M1&=~SET_BIT3;P0M2|=SET_BIT3
//#define P04_PushPull_Mode                        P0M1&=~SET_BIT4;P0M2|=SET_BIT4
//#define P05_PushPull_Mode                        P0M1&=~SET_BIT5;P0M2|=SET_BIT5
//#define P06_PushPull_Mode                        P0M1&=~SET_BIT6;P0M2|=SET_BIT6
//#define P07_PushPull_Mode                        P0M1&=~SET_BIT7;P0M2|=SET_BIT7
//#define P10_PushPull_Mode                        P1M1&=~SET_BIT0;P1M2|=SET_BIT0
//#define P11_PushPull_Mode                        P1M1&=~SET_BIT1;P1M2|=SET_BIT1
//#define P12_PushPull_Mode                        P1M1&=~SET_BIT2;P1M2|=SET_BIT2
//#define P13_PushPull_Mode                        P1M1&=~SET_BIT3;P1M2|=SET_BIT3
//#define P14_PushPull_Mode                        P1M1&=~SET_BIT4;P1M2|=SET_BIT4
//#define P15_PushPull_Mode                        P1M1&=~SET_BIT5;P1M2|=SET_BIT5
//#define P16_PushPull_Mode                        P1M1&=~SET_BIT6;P1M2|=SET_BIT6
//#define P17_PushPull_Mode                        P1M1&=~SET_BIT7;P1M2|=SET_BIT7
//#define P20_PushPull_Mode                        P2M1&=~SET_BIT0;P2M2|=SET_BIT0
//#define P30_PushPull_Mode                        P3M1&=~SET_BIT0;P3M2|=SET_BIT0
////------------------- Define Port as Input Only mode -------------------
//#define P00_Input_Mode                                P0M1|=SET_BIT0;P0M2&=~SET_BIT0
//#define P01_Input_Mode                                P0M1|=SET_BIT1;P0M2&=~SET_BIT1
//#define P02_Input_Mode                                P0M1|=SET_BIT2;P0M2&=~SET_BIT2
//#define P03_Input_Mode                                P0M1|=SET_BIT3;P0M2&=~SET_BIT3
//#define P04_Input_Mode                                P0M1|=SET_BIT4;P0M2&=~SET_BIT4
//#define P05_Input_Mode                                P0M1|=SET_BIT5;P0M2&=~SET_BIT5
//#define P06_Input_Mode                                P0M1|=SET_BIT6;P0M2&=~SET_BIT6
//#define P07_Input_Mode                                P0M1|=SET_BIT7;P0M2&=~SET_BIT7
//#define P10_Input_Mode                                P1M1|=SET_BIT0;P1M2&=~SET_BIT0
//#define P11_Input_Mode                                P1M1|=SET_BIT1;P1M2&=~SET_BIT1
//#define P12_Input_Mode                                P1M1|=SET_BIT2;P1M2&=~SET_BIT2
//#define P13_Input_Mode                                P1M1|=SET_BIT3;P1M2&=~SET_BIT3
//#define P14_Input_Mode                                P1M1|=SET_BIT4;P1M2&=~SET_BIT4
//#define P15_Input_Mode                                P1M1|=SET_BIT5;P1M2&=~SET_BIT5
//#define P16_Input_Mode                                P1M1|=SET_BIT6;P1M2&=~SET_BIT6
//#define P17_Input_Mode                                P1M1|=SET_BIT7;P1M2&=~SET_BIT7
//#define P20_Input_Mode                                P2M1|=SET_BIT0;P2M2&=~SET_BIT0
//#define P30_Input_Mode                                P3M1|=SET_BIT0;P3M2&=~SET_BIT0
////-------------------Define Port as Open Drain mode -------------------
//#define P00_OpenDrain_Mode                P0M1|=SET_BIT0;P0M2|=SET_BIT0
//#define P01_OpenDrain_Mode                P0M1|=SET_BIT1;P0M2|=SET_BIT1
//#define P02_OpenDrain_Mode                P0M1|=SET_BIT2;P0M2|=SET_BIT2
//#define P03_OpenDrain_Mode                P0M1|=SET_BIT3;P0M2|=SET_BIT3
//#define P04_OpenDrain_Mode                P0M1|=SET_BIT4;P0M2|=SET_BIT4
//#define P05_OpenDrain_Mode                P0M1|=SET_BIT5;P0M2|=SET_BIT5
//#define P06_OpenDrain_Mode                P0M1|=SET_BIT6;P0M2|=SET_BIT6
//#define P07_OpenDrain_Mode                P0M1|=SET_BIT7;P0M2|=SET_BIT7
//#define P10_OpenDrain_Mode                P1M1|=SET_BIT0;P1M2|=SET_BIT0
//#define P11_OpenDrain_Mode                P1M1|=SET_BIT1;P1M2|=SET_BIT1
//#define P12_OpenDrain_Mode                P1M1|=SET_BIT2;P1M2|=SET_BIT2
//#define P13_OpenDrain_Mode                P1M1|=SET_BIT3;P1M2|=SET_BIT3
//#define P14_OpenDrain_Mode                P1M1|=SET_BIT4;P1M2|=SET_BIT4
//#define P15_OpenDrain_Mode                P1M1|=SET_BIT5;P1M2|=SET_BIT5
//#define P16_OpenDrain_Mode                P1M1|=SET_BIT6;P1M2|=SET_BIT6
//#define P17_OpenDrain_Mode                P1M1|=SET_BIT7;P1M2|=SET_BIT7
//#define P20_OpenDrain_Mode                P2M1|=SET_BIT0;P2M2|=SET_BIT0
//#define P30_OpenDrain_Mode                P3M1|=SET_BIT0;P3M2|=SET_BIT0
////--------- Define all port as quasi mode ---------
//#define Set_All_GPIO_Quasi_Mode                        P0M1=0;P0M1=0;P1M1=0;P1M2=0;P2M1=0;P2M2=0;P3M1=0;P3M2=0
#endif
The main C function.  Program execution starts
here after stack initialization.
//void PinInterrupt_ISR (void) interrupt 7
//        if (PIF == 0x80)
//                        clr_GPIO1;
//                        Timer1_Delay10ms(10);
//                        set_GPIO1;
//                        clr_GPIO1;
//                        set_GPIO1;
//                        clr_GPIO1;
//                        set_GPIO1;
//                        clr_GPIO1;
//                        set_GPIO1;
sfr PORDIS        = 0xFD;
void LED_DATA0(void)
        P10 = 1 ;
        P10 = 0;
        P10 = 0;
void LED_DATA1(void)
        P10 = 1 ;
        P10 = 1;
        P10 = 1;
                P10 = 1;
                P10 = 1;
        P10 = 0;
void main (void)
        Set_All_GPIO_Quasi_Mode;                                        // Define in Function_define.h
        P10_PushPull_Mode;
P1SR = 0x01;
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                LED_DATA0();
                LED_DATA1();
                                LED_DATA0();
                LED_DATA1();
                                LED_DATA0();
                LED_DATA1();
while(1);
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#if 0
#endif
void main (void)
//        unsigned char temp;
#if 0
        InitialUART0_Timer3(115200);
//        set_CLOEN;        // For clock out from P1.1
  while(1)
                clr_GPIO1;        // Tiny board GPIO1 LED define
                P0 = 0x00;
                P2 = 0x00;
                P1 = 0x00;
                Timer0_Delay1ms(30);
                P0 = 0xff;
                P2 = 0xff;
                P1 = 0xff;
                set_GPIO1;
                Send_Data_To_UART0(0x35);                                        //UART0 send ascii "U"
                temp = 0x31 + P0;
                Send_Data_To_UART0(temp);
                temp = 0x31 + P1;
#endif
#if 1
  while(1)
                P0 = 0x00;
                P2 = 0x00;
                P1 = 0x00;
                P0 = 0xff;
                P2 = 0xff;
                P1 = 0xff;
                set_GPIO1;
#endif
Lchen1990 2018-11-20 09:48 回复TA
使用P20时,编译显示P2M1和P2M2未定义,是为什么呢?
