GD32F207 相关驱动
1852|25
chenqiang10|  楼主 | 2018-10-30 20:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
初始化用户Led设备
void EvbLedConfig(void)
    GPIO_InitPara GPIO_InitStructure;
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_GPIOD,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_11 | GPIO_PIN_12|GPIO_PIN_13;
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
    GPIO_Init(GPIOD,&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_11 | GPIO_PIN_12 |GPIO_PIN_13;
chenqiang10|  楼主 | 2018-10-30 20:37 | 只看该作者
控制Led的点亮和熄灭
void EvbLedControl(int index, int cmd)
    switch (index)
        case LED1:
            if (cmd == LED_ON)
                GPIO_SetBits(GPIOD,GPIO_PIN_11);  /*点亮Led1灯*/
            else
                GPIO_ResetBits(GPIOD,GPIO_PIN_11);  /*熄灭Led1灯*/
            break;
        case LED2:
            if (cmd == LED_ON)
                GPIO_SetBits(GPIOD,GPIO_PIN_12);  /*点亮Led2灯*/
            else
                GPIO_ResetBits(GPIOD,GPIO_PIN_12);  /*熄灭Led2灯*/
            break;
        case LED3:
            if (cmd == LED_ON)
                GPIO_SetBits(GPIOD,GPIO_PIN_13);  /*点亮Led3灯*/
            else
                GPIO_ResetBits(GPIOD,GPIO_PIN_13);  /*熄灭Led3灯*/
            break;
        default:
            if (cmd == LED_ON)
                GPIO_SetBits(GPIOD,GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13); /*点亮所有的灯*/
            else
                GPIO_ResetBits(GPIOD,GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13); /*熄灭所有的灯*/
            break;
chenqiang10|  楼主 | 2018-10-30 20:38 | 只看该作者
事件触发LED翻转
void EvbLedToggle(int index)
    BitState value;
    switch (index)
        case LED1:
            value =  (BitState)(1-GPIO_ReadOutputBit(GPIOD, GPIO_PIN_11));
            GPIO_WriteBit(GPIOD, GPIO_PIN_11, value);
            break;
        case LED2:
            value =  (BitState)(1-GPIO_ReadOutputBit(GPIOD, GPIO_PIN_12));
            GPIO_WriteBit(GPIOD, GPIO_PIN_12, value);
            break;
        case LED3:
            value =  (BitState)(1-GPIO_ReadOutputBit(GPIOD, GPIO_PIN_13));
            GPIO_WriteBit(GPIOD, GPIO_PIN_13, value);
            break;
        default:
            break;
chenqiang10|  楼主 | 2018-10-30 20:39 | 只看该作者
蜂鸣器初始化
void EVB_BuzzerConfig(void)
    /* 使能GPIOB时钟 */
    /* PD1用于控制蜂鸣器 */
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_1;
chenqiang10|  楼主 | 2018-10-30 20:40 | 只看该作者
蜂鸣器的开关操作
void EVB_BuzzerControl(int value)
    if (value)
        GPIO_SetBits(GPIOD, GPIO_PIN_1);
    else
        GPIO_ResetBits(GPIOD, GPIO_PIN_1);
chenqiang10|  楼主 | 2018-10-30 20:41 | 只看该作者
// 中配配置
static void NVIC_Configuration(void)
    NVIC_InitPara NVIC_InitStructure;
    /* Enable the USARTx Interrupt */
    NVIC_InitStructure.NVIC_IRQ = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQPreemptPriority = 0;
    NVIC_InitStructure.NVIC_IRQSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQEnable = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
串口初始化
oid EvbUart1Config(void)
    /* Configure the GPIO ports */
    USART_InitPara  USART_InitStructure;
    //NVIC_InitPara NVIC_InitStructure;
    /* Enable GPIOA clock */
    RCC_APB2PeriphClock_Enable( RCC_APB2PERIPH_GPIOB, ENABLE );
    /* Enable USART1 APB clock */
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_USART1, ENABLE );
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_AF, ENABLE);
    GPIO_InitStructure.GPIO_Pin     = GPIO_PIN_6 ;
    GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_AF_PP;
    GPIO_Init( GPIOB , &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin     = GPIO_PIN_7;
    GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_IN_FLOATING;;
    GPIO_PinRemapConfig(GPIO_REMAP_USART1, ENABLE);
    //USART_DeInit(USART1 );
    USART_InitStructure.USART_BRR                 = 115200;
    USART_InitStructure.USART_WL                  = USART_WL_8B;
    USART_InitStructure.USART_STBits              = USART_STBITS_1;
    USART_InitStructure.USART_Parity              = USART_PARITY_RESET;
    USART_InitStructure.USART_HardwareFlowControl = USART_HARDWAREFLOWCONTROL_NONE;
    USART_InitStructure.USART_RxorTx              = USART_RXORTX_RX | USART_RXORTX_TX;
    USART_Init(USART1, &USART_InitStructure);
    /* USART enable */
    USART_Enable(USART1, ENABLE);
#if 0
    /* Enable the USART1 Receive interrupt */
    USART_INT_Set(USART1, USART_INT_RBNE, ENABLE );
        USART_INT_Set(USART1, USART_INT_IDLEF, ENABLE );
#endif
chenqiang10|  楼主 | 2018-10-30 20:42 | 只看该作者
向串口1发送一个字符
void EvbUart1WriteByte(char c)
    USART_DataSend(USART1, c);
    while (USART_GetBitState(USART1, USART_FLAG_TBE) == RESET)
chenqiang10|  楼主 | 2018-10-30 20:43 | 只看该作者
void EvbUart1WriteByte2(char c)
向串口1发送一个字符串
void EvbUart1WriteStr(const char* str)
    while (*str)
        USART_DataSend(USART1, * str++);
chenqiang10|  楼主 | 2018-10-30 20:44 | 只看该作者
从串口1接收一个字符
void EvbUart1ReadByte(char* c)
    while (USART_GetBitState(USART1, USART_FLAG_RBNE) == RESET)
    *c = (USART_DataReceive(USART1));
static char _buffer[256];
void EvbUart1Printf(char* fmt, ...)
    int i;
    va_list ap;
    va_start(ap, fmt);
    vsprintf(_buffer, fmt, ap);
    va_end(ap);
    for (i = 0; _buffer[i] != '\0'; i++)
        EvbUart1WriteByte(_buffer[i]);
void EvbUart1EnableRxInt(void)
    USART_INT_Set( USART1, USART_INT_RBNE, ENABLE );
void EvbUart1EnableTxInt(void)
    /* Enable the USART1 Transmoit interrupt */
    USART_INT_Set( USART1, USART_INT_TBE, ENABLE );
chenqiang10|  楼主 | 2018-10-30 20:47 | 只看该作者
ADC
void GPIO_Configuration(void)
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_9;
    GPIO_Init( GPIOA , &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin  = GPIO_PIN_10;
chenqiang10|  楼主 | 2018-10-30 20:48 | 只看该作者
Configure ADC Configuration.
void ADC_Configuration(void)
    /* Config ADC1 --------------------------------------------------------------*/
    ADC_InitStructure.ADC_Mode_Scan = DISABLE;
    ADC_InitStructure.ADC_Mode_Continuous = DISABLE;
    ADC_InitStructure.ADC_Trig_External = ADC_EXTERNAL_TRIGGER_MODE_NONE;
    ADC_InitStructure.ADC_Data_Align = ADC_DATAALIGN_RIGHT;
    ADC_InitStructure.ADC_Mode = ADC_MODE_INDEPENDENT;
    ADC_InitStructure.ADC_Channel_Number = 1;
    ADC_Init(ADC1,&ADC_InitStructure);
    /* ADC1 regular channels configuration */
    ADC_RegularChannel_Config(ADC1,ADC_CHANNEL_16, 1, ADC_SAMPLETIME_239POINT5);
    ADC_ExternalTrigConv_Enable(ADC1,ENABLE);
    ADC_TempSensorVrefint_Enable(ENABLE);
    /* Enable ADC1 */
    ADC_Enable(ADC1,ENABLE);
    ADC_Calibration(ADC1);
    /* Start ADC1 Software Conversion */
    ADC_SoftwareStartConv_Enable(ADC1,ENABLE);
Configure system clocks.
void RCC_Configuration(void)
    /* ADCCLK = PCLK2/6 */
    RCC_ADCCLKConfig(RCC_ADCCLK_APB2_DIV6);
    /* Enable DMA1 and GPIOC clock */
    RCC_APB2PeriphClock_Enable( RCC_APB2PERIPH_GPIOA|RCC_APB2PERIPH_AF , ENABLE);
    RCC_APB2PeriphClock_Enable( RCC_APB2PERIPH_USART1 , ENABLE );
    /* Enable ADC1 clock */
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_ADC1, ENABLE);
chenqiang10|  楼主 | 2018-10-30 20:49 | 只看该作者
void CAN_Config(void)
    /* CAN register init */
    CAN_DeInit(CANX);
    CAN_StructInit(&CAN_InitStructure);
#if (1 == USE_CAN_NUM)
    RCC_APB1PeriphClock_Enable(RCC_APB1PERIPH_CAN1, ENABLE);
#else /*__CAN2_USED__*/
    RCC_APB1PeriphClock_Enable(RCC_APB1PERIPH_CAN2, ENABLE);
#endif /* __CAN1_USED__ */
    /* CAN cell init */
    CAN_InitStructure.CAN_TTC = DISABLE;
    CAN_InitStructure.CAN_ABOR = DISABLE;
    CAN_InitStructure.CAN_AWK = DISABLE;
    CAN_InitStructure.CAN_ARD = DISABLE;
    CAN_InitStructure.CAN_RFOD = DISABLE;
    CAN_InitStructure.CAN_TFO = DISABLE;
    CAN_InitStructure.CAN_Mode = CAN_MODE_NORMAL;
    /* CAN Baudrate = 1MBps*/
    CAN_InitStructure.CAN_SJW = CAN_SJW_1TQ;
    CAN_InitStructure.CAN_BS1 = CAN_BS1_2TQ;
    CAN_InitStructure.CAN_BS2 = CAN_BS2_1TQ;
    CAN_InitStructure.CAN_Prescaler = 15;
    CAN_Init(CANX, &CAN_InitStructure);
    /* CAN filter init */
    CAN_FilterInitStructure.CAN_FilterNumber = 0;
#else /* USE_CAN2 */
    CAN_FilterInitStructure.CAN_FilterNumber = 14;
#endif /* USE_CAN_NUM */
    CAN_FilterInitStructure.CAN_FilterMode = CAN_FILTERMODE_MASK;
    CAN_FilterInitStructure.CAN_FilterScale = CAN_FILTERSCALE_32BIT;
    CAN_FilterInitStructure.CAN_FilterListHigh = 0x0000;
    CAN_FilterInitStructure.CAN_FilterListLow = 0x0000;
    CAN_FilterInitStructure.CAN_FilterMaskListHigh = 0x0000;
    CAN_FilterInitStructure.CAN_FilterMaskListLow = 0x0000;
    CAN_FilterInitStructure.CAN_FilterFIFOAssociation = CAN_FIFO0;
    CAN_FilterInitStructure.CAN_FilterWork = ENABLE;
    CAN_FilterInit(&CAN_FilterInitStructure);
chenqiang10|  楼主 | 2018-10-30 20:50 | 只看该作者
void NVIC_Config(void)
    NVIC_PRIGroup_Enable(NVIC_PRIGROUP_0);
    NVIC_InitStructure.NVIC_IRQ = CAN1_RX0_IRQn;
    NVIC_InitStructure.NVIC_IRQ = CAN2_RX0_IRQn;
#endif /*__CAN1_USED__*/
    NVIC_InitStructure.NVIC_IRQPreemptPriority = 0x0;
    NVIC_InitStructure.NVIC_IRQSubPriority = 0x0;
void Init_RxMes(CanRxMessage *RxMessage)
    uint8_t i = 0;
    RxMessage->StdId = 0x00;
    RxMessage->ExtId = 0x00;
    RxMessage->FF = CAN_FF_STANDARD;
    RxMessage->DLC = 0;
    RxMessage->FI = 0;
    for (i = 0;i < 8;i++)
        RxMessage->Data[i] = 0x00;
void GPIO_Config(void)
    /* GPIO clock enable */
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_AF |
                               RCC_APB2PERIPH_GPIOB|
                               RCC_APB2PERIPH_GPIOC, ENABLE);
    GPIO_PinRemapConfig(GPIO_REMAPPING_CAN , ENABLE);
    /* Configure USART1 TX pin */
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* Configure USART1 RX pin */
    /* Configure User Key Button pin */
    GPIO_InitStructure.GPIO_Pin = KEY_GPIO_PIN;
    GPIO_Init(KEY_GPIO_PORT, &GPIO_InitStructure);
    /* Configure CAN pin: RX */
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_CAN_RX;
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_IPU;
    GPIO_Init(GPIO_CAN, &GPIO_InitStructure);
    /* Configure CAN pin: TX */
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_CAN_TX;
