[开发工具]
MODBUS精简版对比!
2467|22
Diyer2015|  楼主 | 2018-12-17 12:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MODBUS精简版
#include <all.h>
void main()
   P5M0 = 0;
   P5M1 = 0;
   P3M0 = 0;
   P3M1 = 0;
   UartInit();           //9600bps@11.0592MHz
   Modbus_Init();  //利用定时器2来计算数据帧 定时1MS
   while(1)
           Modbus_data_Decode();
Diyer2015|  楼主 | 2018-12-17 12:34 | 只看该作者
#include <STC15.h>
#include "UART.h"
#include "MODBUS_Drive.h"
#ifndef UART
#define UART
extern void UartInit(void);                //9600bps@11.0592MHz
#endif
#ifndef MODBUS_Drive
#define        MODBUS_Drive
extern void Modbus_Init();
extern void Modbus_Read_Drive();
extern void Modbus_data_Decode();
extern unsigned char xdata Modbus_Read_Buffer[256];
extern unsigned char xdata Modbus_Write_Buffer[256];
extern unsigned char Modbus_Read_Complete;
extern unsigned int Modbus_Read_Value;
extern unsigned int Modbus_Write_Value;
#endif
#include <all.h>
void UartInit(void)                //9600bps@11.0592MHz
        SCON = 0x50;                //8位数据,可变波特率
        AUXR |= 0x40;                //定时器1时钟为Fosc,即1T
        AUXR &= 0xFE;                //串口1选择定时器1为波特率发生器
        TMOD &= 0x0F;                //设定定时器1为16位自动重装方式
        TL1 = 0xE0;                //设定定时初值
        TH1 = 0xFE;                //设定定时初值
        ET1 = 0;                //禁止定时器1中断
        TR1 = 1;                //启动定时器1
        EA = 1;
        ES = 1;
void UART1_Rountine(void) interrupt 4        //串口1
        if(RI)
                 RI = 0;
                Modbus_Read_Buffer[Modbus_Read_Value++] = SBUF;
        if(TI)
                TI = 0;
Diyer2015|  楼主 | 2018-12-17 12:35 | 只看该作者
#include <all.h>
unsigned char xdata Modbus_Read_Buffer[256] = 0;  //数据接收缓冲区
unsigned char xdata Modbus_Write_Buffer[256] = 0; //数据发送缓冲区
unsigned int Modbus_Read_Value = 0;        //接收字节计数
unsigned int Modbus_Write_Value = 0;  //发送字节计数
unsigned char Modbus_Read_Complete = 0; //帧接收完成标志位
unsigned int Modbus_CRC_Cecode(unsigned char *puchMsg, unsigned int usDataLen);        //CRC校验
void Modbus_Init();        //帧检测定时器
void Modbus_Init()//利用定时器2来计算数据帧 定时1MS
        AUXR |= 0x04;//定时器2用作定时,不分频
        IE2 |= 0x04;//允许定时器2中断
        T2L = 0xCD;                //设置定时初值
        T2H = 0xD4;                //设置定时初值
        EA = 1;  //开总中断
        AUXR |= 0x10;
         unsigned int i,j,CRC_Reg,Check;
         CRC_Reg = 0xFFFF;
         for(i=0;i<usDataLen;i++)
                CRC_Reg = CRC_Reg ^ (unsigned int)*(puchMsg + i);
                for(j=0;j<8;j++)
                        Check = CRC_Reg & 0x0001;
                        CRC_Reg >>= 1;
                        if(Check==0x0001)
                                CRC_Reg ^= 0xA001;
         return CRC_Reg;
         unsigned int CRC_Data,i;
         unsigned char CRC_H, CRC_L;
        if(Modbus_Read_Complete)
                 EA = 0;
                 CRC_Data = Modbus_CRC_Cecode(Modbus_Read_Buffer,Modbus_Read_Value-2);
                 CRC_H = CRC_Data >> 8;
                 CRC_L = CRC_Data & 0x00ff;
                 if((CRC_H == Modbus_Read_Buffer[Modbus_Read_Value-1]) && (CRC_L == Modbus_Read_Buffer[Modbus_Read_Value-2]))
                         //这里可以开始分析数据 程序进入这里就证明CRC检验已经通过了
                        Modbus_Write_Value = 0; //清除发送直接计数 ,调试用
                         for(i = 0; i < (Modbus_Read_Value-2); i++)         //调试用主要把接收的数据发送出去
                                Modbus_Write_Buffer[i] = Modbus_Read_Buffer[i];         //调试用
                                Modbus_Write_Value++;                                                    //调试用
                 Modbus_Write_Buffer[Modbus_Write_Value] = CRC_L;          //调试用
                 Modbus_Write_Buffer[Modbus_Write_Value] = CRC_H;           //调试用
                 Modbus_Read_Value = 0;                //接收直接数清零
                 EA = 1;
                 for(i = 0; i <= Modbus_Write_Value; i++)                 //调试用
                         SBUF = Modbus_Write_Buffer[i];                          //调试用
                        while(!TI);        //调试用
                 Modbus_Write_Value = 0;                                          //调试用
Diyer2015|  楼主 | 2018-12-17 12:36 | 只看该作者
/* 串口接收监控,由空闲时间判定帧结束,需在定时中断中调用,ms-定时间隔 */
void UartRxMonitor(unsigned char ms)
    static unsigned char cntbkp = 0;
    static unsigned char idletmr = 0;
    if (Modbus_Read_Value > 0)  //接收计数器大于零时,监控总线空闲时间
        if (cntbkp != Modbus_Read_Value)  //接收计数器改变,即刚接收到数据时,清零空闲计时
            cntbkp = Modbus_Read_Value;
            idletmr = 0;
        else                   //接收计数器未改变,即总线空闲时,累积空闲时间
            if (idletmr < 2)  //空闲计时小于30ms时,持续累加
                idletmr += ms;
                if (idletmr >= 2)  //空闲时间达到2ms时,即判定为一帧接收完毕
                                        Modbus_Read_Complete = 1;  //设置帧接收完成标志
    else
        cntbkp = 0;
void Timer2_Routine() interrupt 12
        UartRxMonitor(1);
#include <all.h>
        EA = 1;  //开总中断
        AUXR |= 0x10;
         CRC_Reg = 0xFFFF;
                for(j=0;j<8;j++)
                        CRC_Reg >>= 1;
                        if(Check==0x0001)
                                CRC_Reg ^= 0xA001;
         return CRC_Reg;
                 EA = 0;
                 EA = 1;
                        while(!TI);        //调试用
            idletmr = 0;
                idletmr += ms;
    else
        cntbkp = 0;
        UartRxMonitor(1);
Diyer2015|  楼主 | 2018-12-17 12:37 | 只看该作者
附件!
MODBUS调试.rar
46.66 KB
磨砂| | 2019-1-1 10:56 | 只看该作者
MODBUS是什么总线啊
晓伍| | 2019-1-1 11:03 | 只看该作者
MODBUS 是不是就是485通讯啊
八层楼| | 2019-1-1 11:10 | 只看该作者
非常感谢楼主分享
观海| | 2019-1-1 16:11 | 只看该作者
好详细 感谢分享
guanjiaer| | 2019-1-1 16:16 | 只看该作者
其实就是串口通讯吧
heimaojingzhang| | 2019-1-1 16:22 | 只看该作者
哪里精简了啊  不就是串口的通讯吗
keaibukelian| | 2019-1-1 16:27 | 只看该作者
非常感谢分享 很详细
Diyer2015|  楼主 | 2019-1-2 09:20 | 只看该作者
比起freemodbus 还是非常精简的!
