GD32F103PWM最高分辨率
1692|7
GD32F103PWM的最高分辨率是多少?
目前我测试情况是(1/4)*108=27M,大约为37ns。不论我把Timer0的分频设置为TIMER_CKDIV_DIV1或者是设置为TIMER_CKDIV_DIV4,结果都是一样的,代码如下:
void PWM0_Configuration(void)
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    timer_break_parameter_struct timer_breakpara;
    rcu_periph_clock_enable(RCU_TIMER0);
    timer_deinit(TIMER0);
    /* TIMER0 configuration */
    timer_initpara.prescaler         = 0;  //
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 349;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER0,&timer_initpara);
    /* CH0/CH0N configuration in PWM mode0 */
    timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
    timer_ocintpara.outputnstate = TIMER_CCXN_ENABLE;
    timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;
    timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
    timer_channel_output_config(TIMER0,TIMER_CH_0,&timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_0,175);
    timer_channel_output_mode_config(TIMER0,TIMER_CH_0,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER0,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
    /* automatic output enable, break, dead time and lock configuration*/
    timer_breakpara.runoffstate      = TIMER_ROS_STATE_DISABLE;
    timer_breakpara.ideloffstate     = TIMER_IOS_STATE_DISABLE ;
    timer_breakpara.deadtime         = 10;
    timer_breakpara.breakpolarity    = TIMER_BREAK_POLARITY_LOW;
    timer_breakpara.outputautostate  = TIMER_OUTAUTO_ENABLE;
    timer_breakpara.protectmode      = TIMER_CCHP_PROT_OFF;
    timer_breakpara.breakstate       = TIMER_BREAK_ENABLE;
    timer_break_config(TIMER0,&timer_breakpara);
    /* TIMER0 primary output function enable */
    timer_primary_output_config(TIMER0,ENABLE);
    timer_auto_reload_shadow_enable(TIMER0);
    timer_enable(TIMER0);
zeshoufx| | 2019-6-20 11:35 | 只看该作者
GD32f103的IO速度最大只能达到50MHz,
davidgdg|  楼主 | 2019-6-20 13:52 | 只看该作者
能达到50MHZ也可以,为什么我设置TIMER_CKDIV_DIV1或者是设置为TIMER_CKDIV_DIV4,结果是一样的?
楼上,你是原厂技术支持吗?
梦麟yy| | 2019-6-20 16:06 | 只看该作者
楼上,你 ...
这个时钟分频是和死区时间有关系的,所以改变这个值,只会导致死区时间不一样,不会对PWM波频率产生影响
zeshoufx| | 2019-6-20 16:17 | 只看该作者
你看一下用户手册
davidgdg|  楼主 | 2019-6-27 11:46 | 只看该作者
梦麟yy 发表于 2019-6-20 16:06
这个时钟分频是和死区时间有关系的,所以改变这个值,只会导致死区时间不一样,不会对PWM波频率产生影响 ...
你的回复对我有帮助,谢谢你!
Puremr| | 2019-6-29 18:13 | 只看该作者
我怀疑实际可以达到这么高的分辨率吗?
kxsi| | 2019-7-10 10:03 | 只看该作者
数据手册上有些  敢写就能达到
