[DemoCode下载]
看门狗复位
982|6
gejigeji521|  楼主 | 2019-6-30 22:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 Watch Dog as pure timer with interrupt demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
*    WDT interrupt sub-routine
void WDT_ISR (void)   interrupt 10
                                        //---------toggle GPIO1---------
                                                clr_GPIO1;
                                                Timer2_Delay500us(5);
                                                set_GPIO1;
                                                clr_GPIO1;
                                                set_GPIO1;
                                        //---------end toggle GPIO2--------
                clr_WDTF;
                set_WDCLR;
*    Main function
void main (void)
/* Note
  WDT timer base is LIRC 10Khz
  Set_All_GPIO_Quasi_Mode;
                                                clr_GPIO1;
                                                Timer0_Delay1ms(500);
                                                set_GPIO1;
                                                clr_GPIO1;
                                                set_GPIO1;
//WDT init
//Warning:
//Pleaes always check CONFIG WDT disable first
//only when WDT reset disable, WDT use as pure timer
          TA=0xAA;TA=0x55;WDCON=0x07;                  //Setting WDT prescale
                set_WDTR;                       //WDT run
                set_WDCLR;        //Clear WDT timer
                set_EWDT;
                EA =1;
#if 0
    while(1);
#else
                set_WIDPD;        //WDT run in POWER DOWM mode setting if needed
                while (1)
                        set_PD;
                                                clr_P04;
                                                Timer1_Delay10ms(5);
                                                set_P04;
                                                clr_P04;
                                                set_P04;
                                        //---------end toggle GPIO1---------
#endif
发现BSP里面有两个例子,一个名字是看门狗定时器中断,一个是看门狗中断。
gejigeji521|  楼主 | 2019-6-30 23:01 | 只看该作者
本来是要上面的问题的,我又仔细看了一下, 是我看错了。。。
不过不删帖了,讨论一下看门狗复位
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Date   : May/02/2018
//  File Function: N76E003 Watch Dog reste functiondemo code
#include "Common.h"
#include "Delay.h"
        WDT CONFIG enable
        warning : this macro is only when ICP not enable CONFIG WDT function
        copy this marco code to you code to enable WDT reset.
void Check_WDT_Reset_Config(void)
                set_IAPEN;
                IAPAL = 0x04;
                IAPAH = 0x00;
                IAPFD = 0xFF;
                IAPCN = 0xC0;                                                //Read config command
                set_IAPGO;
                if ((IAPFD&0xF0)==0xF0)
                                IAPFD = 0x0F;
                                IAPCN = 0xE1;
        set_IAPGO;        //trigger IAP
                                while((CHPCON&SET_BIT6)==SET_BIT6);          //check IAPFF (CHPCON.6)
                                clr_CFUEN;
                                clr_IAPEN;
                                EA = 0;
                                TA = 0xAA;
                                TA = 0x55;
                                CHPCON &= 0xFD;
                                TA = 0xAA;
                                TA = 0x55;
                                CHPCON |= 0x80;
                clr_IAPEN;
*    Main function
void main (void)
//        CKDIV = 0X01;
        clr_GPIO1;
//        Timer0_Delay1ms(1);                                        //toggle I/O to show MCU Reset
        set_GPIO1;
// WDT Init !!! ENABLE CONFIG WDT FIRST !!!
// Warning:
// Always check CONFIG WDT enable first, CONFIG not enable, SFR can't enable WDT reset
// Please call Enable_WDT_Reset_Config() function to enable CONFIG WDT reset
                Check_WDT_Reset_Config();
          TA=0xAA;TA=0x55;WDCON|=0x07;                                                //Setting WDT prescale
                while((WDCON|~SET_BIT6)==0xFF);                                //confirm WDT clear is ok before into power down mode
//                EA = 1;
                set_WDTR;        //WDT run
    while(1)
                        clr_P05;
                        Timer0_Delay1ms(1);
                        set_P05;
                        Timer0_Delay1ms(1);
                        clr_P05;
                        Timer0_Delay1ms(1);
                        set_P05;
                        Timer0_Delay1ms(1);
                        clr_P05;
                        set_PD;
zhuomuniao110| | 2019-7-22 13:31 | 只看该作者
看门狗复位,是超时吗
zhuomuniao110| | 2019-7-22 13:33 | 只看该作者
看门狗定时器也可以独立用
xuanhuanzi| | 2019-7-23 11:33 | 只看该作者
确实可以,跑一个试试
xinxianshi| | 2019-7-23 21:56 | 只看该作者
比较好用。
