[应用相关] u-boot网络固件还原功能
1870|46
 楼主| xiaoqizi 发表于 2019-7-9 10:51 | 显示全部楼层
U_BOOT_CMD(
        query,        3,        1,        do_query,
        "Whether there is server alive and get inifile form server",
        "query [filetype]"
 楼主| xiaoqizi 发表于 2019-7-9 10:52 | 显示全部楼层
2、udp接收到的包交给net/udp.c处理:
#include <common.h>
#include <command.h>
#include <net.h>
#include <environment.h>
#include <linux/ctype.h>
#include <linux/string.h>
#include <netdev.h>
#include "tftp.h"
#include "bootp.h"
#include "udp.h"
#define TIMEOUT                 20000UL                /* Seconds to timeout for a lost pkt        */
#ifndef        CONFIG_NET_RETRY_COUNT
# define TIMEOUT_COUNT        10                /* # of timeouts before giving up  */
#else
# define TIMEOUT_COUNT  (CONFIG_NET_RETRY_COUNT * 2)
#endif
static ulong UdpTimeoutMSecs = TIMEOUT;
static int UdpTimeoutCountMax = TIMEOUT_COUNT;
#define MAX_LINE 200
#define MAX_SECTION 100
#define MAX_NAME 100
static IPaddr_t UdpServerIP;
static int        UdpServerPort;                /* The UDP port at their end                */
static int        UdpOurPort;                /* The UDP port at our end                */
static int        UdpTimeoutCount;
static void UdpSend (void);
static void UdpTimeout (void);
static void
UdpSend (void)
        volatile uchar *        pkt;
        int                        len = 0;
         *        We will always be sending some sort of packet, so
         *        cobble together the packet headers now.
        pkt = NetTxPacket + NetEthHdrSize() + IP_HDR_SIZE;
        len = strlen(pkt_data);
        memcpy(pkt, pkt_data, len);
        NetSendUDPPacket(NetServerEther, UdpServerIP, UdpServerPort, UdpOurPort, len);
 楼主| xiaoqizi 发表于 2019-7-9 10:53 | 显示全部楼层
static int inifile_handler(void *user, char *section, char *name, char *value)
        char *requested_section = (char *)user;
        int i;
         if ( *name == 's' || *name == 'b' || *name == 't') {
                 if ( *name == 't' ){
                        if(run_command(value, 0) == -1){
                                return 0;
                        return 1;
                for(i=0; i<10; i++){
                                if ( *name == 'b' ) {
                                        printf("bootm kernel and rootfs failure!\n");
                                        return 1;
                                printf("error, try again After 1 seconds\n");
                                udelay(1000000);
                                if ((i==9) || ctrlc()) {
                                        puts ("\nAbort\n");
                                        return 0;
                                continue;
                        break;
        else{
                setenv(name, value);
        /* success */
        return 1;
static void
UdpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len)
        ushort proto;
        char line[MAX_LINE];
        char section[MAX_SECTION] = "";
        char prev_name[MAX_NAME] = "";
        char *start;
        char *end;
        char *name;
        char *value;
        int i, linelen;
        int newline = 1;
        int lineno = 0;
        int error = 0;
        int flag = 1;
        char *udpkt;
        char *udppkt;
        udpkt=(char *)malloc(1000*sizeof(char));
        udppkt = strcpy(udpkt,(char *)pkt);
        printf("receive udp packet\n");
        while(flag){
                end = memchr(udppkt, '\n', (size_t)len);
                if( *end != '\n')
                        end = memchr(udppkt, '\r', (size_t)len);
                if (end == NULL) {
                        if (len == 0)
                                return;
                        end = udppkt + len;
                        newline = 0;
                linelen = min((end - udppkt) + newline, MAX_LINE);
                memcpy(line, udppkt, linelen);
                if (linelen < MAX_LINE)
                        line[linelen] = '\0';
                /* prepare the mem vars for the next call */
                len -= (end - udppkt) + newline;
                udppkt += (end - udppkt) + newline;
                lineno++;
                start = lskip(rstrip(line));
loop:
            if (*start && *start != ':' && *start != '[' && *start != '#') {
                /* Not a comment, must be a name[=:]value pair */
                        end = find_char_or_comment(start, '=');
                        if (*end != '=')
                                end = find_char_or_comment(start, ':');
                        if (*end == '=' || *end == ':') {
                                *end = '\0';
                                name = rstrip(start);
                                value = lskip(end + 1);
                                end = find_char_or_comment(value, ';');
                                if(*end == ';'){        //batch cmd
                                        *end = '\0';
                                        end = find_char_or_comment(value, '\0');
                                        rstrip(value);
                                        /* Strip double-quotes */
                                        if (value[0] == '"' &&
                                                   value[strlen(value)-1] == '"') {
                                                value[strlen(value)-1] = '\0';
                                                        value += 1;
                                         * Valid name[=:]value pair found, call handler
                                        strncpy0(prev_name, name, sizeof(prev_name));
                                        printf("start %d line:%s %s\n",lineno, name, value);
                                        if (inifile_handler(section, section, name, value) &&
                                             !error){
                                                start = ++end;
                                                goto loop;
                                        else
                                                error = lineno;
                                else{
                                        rstrip(value);
                                                        value += 1;
                                        printf("start %d line:%s\n",lineno, value);
                                        if (!inifile_handler(section, section, name, value) &&
                                             !error)
                                                        error = lineno;
                        else if (!error){
                                /* No '=' or ':' found on name[=:]value line */
                                error = lineno;
                else if ((*start == ':' && start[1] == ':') || *start == '#') {
                         * Per Python ConfigParser, allow '#' comments at start
                         * of line
#if CONFIG_INI_ALLOW_MULTILINE
                else if (*prev_name && *start && start > line) {
                         * Non-blank line with leading whitespace, treat as
                         * continuation of previous name's value (as per Python
                         * ConfigParser).
                        if (!inifile_handler(section, section, prev_name, start) && !error)
                                error = lineno;
#endif
                else if (*start == '[') {
                        /* A "[section]" line */
                        end = find_char_or_comment(start + 1, ']');
                        if (*end == ']') {
                                *end = '\0';
                                strncpy0(section, start + 1, sizeof(section));
                                *prev_name = '\0';
                        } else if (!error) {
                                /* No ']' found on section line */
                                error = lineno;
                if(error){
                        printf("error= %d\n", error);
                        break;
                printf("%d line done\n", lineno);
        free(udpkt);
        udpkt = NULL;
        if ( error ){
                Upgrade_flag = UPGRADE_FAILED;
                TftpNetReStartCount = 10;
        else{
                Upgrade_flag = UPGRADE_SUCCESS;
                TftpNetReStartCount = 11;
* restart the current transfer due to an error
* @param msg        Message to print for user
static void restart(const char *msg)
        printf("\n%s; Net starting again\n", msg);
#ifdef CONFIG_MCAST_TFTP
        mcast_cleanup();
#endif
        NetStartAgain();
static void
ICMPHandler (unsigned type, unsigned code, unsigned dport,
                 unsigned sport, unsigned len)
                if (type == ICMP_NOT_REACH && code == ICMP_NOT_REACH_PORT) {
                        UdpTimeoutMSecs = 5000UL;
                        NetSetTimeout (UdpTimeoutMSecs, UdpTimeout);
 楼主| xiaoqizi 发表于 2019-7-9 10:54 | 显示全部楼层
static void
UdpTimeout (void)
        if (++UdpTimeoutCount > UdpTimeoutCountMax) {
                if ( ++TftpNetReStartCount > TftpNetReStartCountMax ){
                        return;
                switch(UdpTimeoutMSecs){
                        case 5000:
                                buzzer_notify(200, 1);
                                restart("UDP server died");
                                break;
                        case 20000:
                                buzzer_notify(200, 2);
                                restart("GetPacke Retry count exceeded");
                                break;
                        default:
                                buzzer_notify(200, 3);
                                restart("Retry count exceeded");
                                break;
        } else {
                puts ("T ");
                UdpSend ();
void
UdpStart (void)
        char *ep;             /* Environment pointer */
         * Allow the user to choose UDP blocksize and timeout.
         * UDP protocol has a minimal timeout of 1 second.
        if ((ep = getenv("udptimeout")) != NULL){
                printf("udptimeout = %d\n", UdpTimeoutMSecs);
                UdpTimeoutMSecs = simple_strtol(ep, NULL, 10);
        if (UdpTimeoutMSecs < 20000) {
                printf("UDP timeout (%ld ms) too low, "
                        "set minimum = 20000 ms\n",
                        UdpTimeoutMSecs);
                UdpTimeoutMSecs = 20000;
        UdpServerIP = NetServerIP;
#if defined(CONFIG_NET_MULTI)
        printf ("Using %s device\n", eth_get_name());
#endif
        UdpTimeoutCountMax = 5;
        UdpTimeoutCount = 0;
        NetSetHandler (UdpHandler);
        NetSetIcmpHandler(ICMPHandler);  //NO server
        UdpServerPort = 75;
        UdpOurPort = getenv("ourport");
        /* zero out server ether in case the server ip has changed */
        memset(NetServerEther, 0, 6);
        UdpSend ();
3、tftp.c的完善:
 1)增加了服务器不在的处理
static void
IcmpHandler (unsigned type, unsigned code, unsigned dport,
                        TftpTimeoutMSecs = 3500UL;
                        NetSetTimeout (TftpTimeoutMSecs, TftpTimeout);
 楼主| xiaoqizi 发表于 2019-7-9 10:55 | 显示全部楼层
 2)限制了NetStartAgain()的次数,超过次数终止接收数据报
在net.c中定义int TftpNetReStartCount = 0;  int TftpNetReStartCountMax  = 3;
在net.h中定义extern int TftpNetReStartCount;         extern int TftpNetReStartCountMax;
3)超时处理函数的修改
        mcast_cleanup();
#endif
        NetStartAgain();
static void TftpTimeout (void)
        if (++TftpTimeoutCount > TftpTimeoutCountMax) {
                        return;
                switch(TftpTimeoutMSecs){
                        case 3500:
                                restart("TFTP server died");
                                break;
                        case 3000:
                                break;
                        default:
                                break;
        } else {
                puts ("T ");
                TftpSend ();
 楼主| xiaoqizi 发表于 2019-7-9 10:56 | 显示全部楼层
4、对一开始就没插网线情况的处理:
在u-boot-2010.06\drivers\net\hisfv300的net-drv.c中的int eth_init(bd_t * bd)函数中修改。
在u-boot-2010.06\drivers\net\higmacv300的higmac.c中的int eth_init(bd_t * bd)函数中修改。
5、在各个平台指定环境变量的地址和大小
1)hi3520dv300、hi3521a、hi3531a:
#define CONFIG_ENV_OFFSET        0x50000      /* environment starts here */
#define CONFIG_ENV_SIZE                0x10000    /*include ENV_HEADER_SIZE */
2)除了hi3520dv300、hi3521a、hi3531a之外其他的可以在u-boot-2010.06\include\configs中各自的.h中修改:
#define CONFIG_ENV_OFFSET          0x80000      /* environment starts here */
#define CONFIG_ENV_SIZE            0x40000    /*include ENV_HEADER_SIZE */
六、编译uboot
1、在u-boot-2010.06\arch\arm\comfig.mk中修改交叉编译器路径
2、make clean
3、make ARCH=arm hi3520d_config
4、make
 楼主| xiaoqizi 发表于 2019-7-9 10:57 | 显示全部楼层
如果需要压缩uboot的话加上这5、6步
5、cd arch/arm/cpu/hi3520d/compressed
6、make     //第4步和这步生成压缩之后的u-boot.bin(这时uboot还没有对寄存器的初始化,烧写到板子是跑不起来的),不过可以tftp到板子然后用go命令跑
7、cp u-boot.bin ../u-boot.tools
8、sh make.sh   //生成20D.bin(这时的uboot可以烧写进flash了),hi3520d用fastBoot烧录,hi3521a、hi3531a和hi3510dv300(烧录时选21A芯片)用HiTool工具烧录
wangjiahao88 发表于 2019-7-9 14:50 | 显示全部楼层
U-boot 是利用网络做数据的更新吗?flash更新吗?
 楼主| xiaoqizi 发表于 2019-8-6 12:47 | 显示全部楼层
不好意思 我也不是很清楚这个问题
