[综合信息]
EVB板点亮LCD屏
2301|13
Cjy_JDxy|  楼主 | 2019-10-27 20:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天捣鼓了一下EVB板,点亮了屏。
删掉common组里的文件:
烧写算法选这个:
代码:
* Include files
#include "lcd.h"
#include "lpm.h"
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
* Local type definitions ('typedef')
* Local function prototypes ('static')
* Local variable definitions ('static')                                      *
* Function implementation - global ('extern') and local ('static')
void App_PortCfg(void);
void App_LcdCfg(void);
** \brief  主函数
** @param  无
** \retval 无
int32_t main(void)
    Sysctrl_ClkSourceEnable(SysctrlClkRCL,TRUE);            ///< 使能RCL时钟
    Sysctrl_SetRCLTrim(SysctrlRclFreq32768);                ///< 配置内部低速时钟频率为32.768kHz
    Sysctrl_SetPeripheralGate(SysctrlPeripheralLcd,TRUE);   ///< 开启LCD时钟
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);  ///< 开启GPIO时钟
    App_PortCfg();               ///< LCD端口配置
    App_LcdCfg();                ///< LCD模块配置
    Lcd_ClearDisp();             ///< 清屏
    Lcd_WriteRam(0,0x0f0f0f0f);  ///< 赋值寄存器LCDRAM0
    Lcd_WriteRam(1,0x0f0f0f0f);  ///< 赋值寄存器LCDRAM1
    while(1)
** \brief  初始化外部GPIO引脚
** \return 无
    Gpio_SetAnalogMode(EVB_LCD_COM0_PORT, EVB_LCD_COM0_PIN);  //COM0
    Gpio_SetAnalogMode(EVB_LCD_COM1_PORT, EVB_LCD_COM1_PIN);  //COM1
    Gpio_SetAnalogMode(EVB_LCD_COM2_PORT, EVB_LCD_COM2_PIN);  //COM2
    Gpio_SetAnalogMode(EVB_LCD_COM3_PORT, EVB_LCD_COM3_PIN);  //COM3
    Gpio_SetAnalogMode(EVB_LCD_SEG0_PORT, EVB_LCD_SEG0_PIN);  //SEG0
    Gpio_SetAnalogMode(EVB_LCD_SEG1_PORT, EVB_LCD_SEG1_PIN);  //SEG1
    Gpio_SetAnalogMode(EVB_LCD_SEG2_PORT, EVB_LCD_SEG2_PIN);  //SEG2
    Gpio_SetAnalogMode(EVB_LCD_SEG3_PORT, EVB_LCD_SEG3_PIN);  //SEG3
    Gpio_SetAnalogMode(EVB_LCD_SEG4_PORT, EVB_LCD_SEG4_PIN);  //SEG4
    Gpio_SetAnalogMode(EVB_LCD_SEG5_PORT, EVB_LCD_SEG5_PIN);  //SEG5
    Gpio_SetAnalogMode(EVB_LCD_SEG6_PORT, EVB_LCD_SEG6_PIN);  //SEG6
    Gpio_SetAnalogMode(EVB_LCD_SEG7_PORT, EVB_LCD_SEG7_PIN);  //SEG7
    Gpio_SetAnalogMode(EVB_LCD_VLCDH_PORT, EVB_LCD_VLCDH_PIN);  //VLCDH
    Gpio_SetAnalogMode(EVB_LCD_VLCD3_PORT, EVB_LCD_VLCD3_PIN);  //VLCD3
    Gpio_SetAnalogMode(EVB_LCD_VLCD2_PORT, EVB_LCD_VLCD2_PIN);  //VLCD2
    Gpio_SetAnalogMode(EVB_LCD_VLCD1_PORT, EVB_LCD_VLCD1_PIN);  //VLCD1
** \brief  配置LCD
** \return 无
    stc_lcd_cfg_t LcdInitStruct;
    stc_lcd_segcom_t LcdSegCom;
    LcdSegCom.u32Seg0_31 = 0xffffff00;                              ///< 配置LCD_POEN0寄存器 开启SEG0~SEG7
    LcdSegCom.stc_seg32_51_com0_8_t.seg32_51_com0_8 = 0xffffffff;   ///< 初始化LCD_POEN1寄存器 全部关闭输出端口
    LcdSegCom.stc_seg32_51_com0_8_t.segcom_bit.Com0_3 = 0;          ///< 使能COM0~COM3
    LcdSegCom.stc_seg32_51_com0_8_t.segcom_bit.Mux = 0;             ///< Mux=0,Seg32_35=0,BSEL=1表示:选择外部电容工作模式,内部电阻断路
    LcdSegCom.stc_seg32_51_com0_8_t.segcom_bit.Seg32_35 = 0;
    Lcd_SetSegCom(&LcdSegCom);                                      ///< LCD COMSEG端口配置
    LcdInitStruct.LcdBiasSrc = LcdExtCap;                          ///< 电容分压模式,需要外部电路配合
    LcdInitStruct.LcdDuty = LcdDuty4;                              ///< 1/4duty
    LcdInitStruct.LcdBias = LcdBias3;                              ///< 1/3 BIAS
    LcdInitStruct.LcdCpClk = LcdClk2k;                             ///< 电压泵时钟频率选择2kHz
    LcdInitStruct.LcdScanClk = LcdClk128hz;                        ///< LCD扫描频率选择128Hz
    LcdInitStruct.LcdMode = LcdMode0;                              ///< 选择模式0
    LcdInitStruct.LcdClkSrc = LcdRCL;                              ///< LCD时钟选择RCL
    LcdInitStruct.LcdEn   = LcdEnable;                             ///< 使能LCD模块
    Lcd_Init(&LcdInitStruct);
* EOF (not truncated)
效果图:
martinhu| | 2019-10-28 09:55 | 只看该作者
这个板子应该是L072 的板子吧,楼主应用L07x的flash download文件比较好,用136的文件不一定完全匹配
Cjy_JDxy|  楼主 | 2019-10-28 10:09 | 只看该作者
martinhu 发表于 2019-10-28 09:55
这个板子应该是L072 的板子吧,楼主应用L07x的flash download文件比较好,用136的文件不一定完全匹配 ...
找不到那个flash download文件
martinhu| | 2019-10-28 16:45 | 只看该作者
【STEP1】打开【我的电脑】 ; 【STEP2】在地址栏输入地址 ftp://HdscCustomer:HdscGuest2019!@ftp.hdsc.com.cn/ 即可直接访问进入FTP后,可以拷贝对应的SDK,里面有驱动库样例,这那里面可以找到对应的FLM文件,然后把这个文件拷贝到KEIL安装目录下的ARM内的flash文件夹内。
Cjy_JDxy|  楼主 | 2019-10-28 19:48 | 只看该作者
martinhu 发表于 2019-10-28 16:45
【STEP1】打开【我的电脑】 ; 【STEP2】在地址栏输入地址 ftp://HdscCustomer:HdscGuest2019!@ftp.hdsc.c ...
谢谢
Cjy_JDxy|  楼主 | 2019-10-29 22:09 | 只看该作者
我把FlashHC32L07X_128K.FLM拷到C:\Keil_v5\ARM\Flash文件夹内,可是烧写算法里没有对应的算法。
martinhu| | 2019-10-30 20:43 | 只看该作者
原来那个可能有问题,你用这个试试
FlashHC32L07X_128K.zip
5.32 KB
Cjy_JDxy|  楼主 | 2019-10-30 21:06 | 只看该作者
martinhu 发表于 2019-10-30 20:43
原来那个可能有问题,你用这个试试
谢谢!
tfqi| | 2019-11-12 15:47 | 只看该作者
非常感谢楼主分享
wiba| | 2019-11-12 15:58 | 只看该作者
非常感谢楼主分享
zljiu| | 2019-11-12 16:17 | 只看该作者
非常感谢楼主分享
waveforms| | 2019-11-17 18:39 | 只看该作者
点亮之后显示数字应该很简单了吧
比神乐| | 2024-9-20 15:36 | 只看该作者
当然啦
shenxiaolin| | 2024-9-29 10:45 | 只看该作者
不错的DEMO
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
