[STM32F1]
求问STM32F103C8T6S使用DMA_Channel5,TIM2_CH1 实现PWM输出的问题
743|1
xxh0201|  楼主 | 2020-1-21 10:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
目的: 使用使用DMA_Channel5,TIM2_CH1。DMA读取buffer里面数据,填充TIM2的OC1的CCR1寄存器,输出不同占空比的PWM。
但,实际,输出是不正常的,不知什么原因。
如果改用 DMA1_Channel2、TIM2_UP,输出就正常,见下面代码中红色的地方是改动的。
原代码如下:
uint16_t LED_BYTE_Buffer[600];
void Timer2_init(void)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef       TIM_OCInitStructure;
    GPIO_InitTypeDef        GPIO_InitStructure;
    DMA_InitTypeDef         DMA_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        /* GPIOA Configuration: TIM2 Channel 1 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        TIM_TimeBaseStructure.TIM_Period = 90-1;     //自动重装载寄存器周期的值为:90
        TIM_TimeBaseStructure.TIM_Prescaler = 0;     //分频
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        /* PWM1 Mode configuration: Channel1 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = LED_BYTE_Buffer[0];
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC1Init(TIM2, &TIM_OCInitStructure);
        /* configure DMA */
        /* DMA clock enable */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* DMA1 Channel6 Config */
        DMA_DeInit(DMA1_Channel5);
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&TIM2->CCR1;
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LED_BYTE_Buffer;                // this is the buffer memory
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                                // data shifted from memory to peripheral
        DMA_InitStructure.DMA_BufferSize = 600;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                        // automatically increase buffer index
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                                        // stop DMA feed after buffer size is reached
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel5, &DMA_InitStructure);
                /* TIM3 CC1 DMA Request enable */
        TIM_DMACmd(TIM2, TIM_DMA_CC1, ENABLE);
        //TIM_DMACmd(TIM2, TIM_DMA_Update, ENABLE);
void PWM_send(uint8_t (void)
        uint16_t buffersize= 600;        // number of bytes  bytes
                DMA_SetCurrDataCounter(DMA1_Channel5, buffersize);         // load number of bytes to be transferred
                DMA_Cmd(DMA1_Channel5, ENABLE);                         // enable DMA channel 5
                TIM_Cmd(TIM2, ENABLE);                                                 // enable Timer 2
                while(!DMA_GetFlagStatus(DMA1_FLAG_TC5)) ;         // wait until transfer complete
                TIM_Cmd(TIM2, DISABLE);         // disable Timer 2
                DMA_Cmd(DMA1_Channel5, DISABLE);                         // disable DMA channel 5
                DMA_ClearFlag([DMA1_FLAG_TC5);                                 // clear DMA1 Channel 5 transfer complete flag
mmuuss586| | 2020-1-22 09:29 | 只看该作者
