[综合信息]
HC 32F003 ADC操作函数
1586|25
gaoke231|  楼主 | 2020-3-25 20:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使能NVIC中ADC中断
static void AdcEnableNvic(IRQn_Type enIrqn)
    NVIC_ClearPendingIRQ(enIrqn);
    NVIC_EnableIRQ(enIrqn);
    NVIC_SetPriority(enIrqn, DDL_IRQ_LEVEL_DEFAULT);
gaoke231|  楼主 | 2020-3-25 20:32 | 只看该作者
除能NVIC中ADC中断
static void AdcDisableNvic(IRQn_Type enIrqn)
    NVIC_DisableIRQ(enIrqn);
gaoke231|  楼主 | 2020-3-25 20:35 | 只看该作者
ADC中断服务程序
void Adc_IRQHandler(uint8_t u8Param)
    if (TRUE == M0P_ADC->IFR_f.REG_INTF)
        if (NULL != stcAdcIrqCalbaks.pfnAdcRegIrq)
            stcAdcIrqCalbaks.pfnAdcRegIrq();
        M0P_ADC->ICLR_f.REG_INTC = 0u;
    if (TRUE == M0P_ADC->IFR_f.HHT_INTF)
        if (NULL != stcAdcIrqCalbaks.pfnAdcHhtIrq)
            stcAdcIrqCalbaks.pfnAdcHhtIrq();
        M0P_ADC->ICLR_f.HHT_INTC = 0u;
    if (TRUE == M0P_ADC->IFR_f.LLT_INTF)
        if (NULL != stcAdcIrqCalbaks.pfnAdcLltIrq)
            stcAdcIrqCalbaks.pfnAdcLltIrq();
        M0P_ADC->ICLR_f.LLT_INTC = 0u;
    if (TRUE == M0P_ADC->IFR_f.CONT_INTF)
        if (NULL != stcAdcIrqCalbaks.pfnAdcContIrq)
            stcAdcIrqCalbaks.pfnAdcContIrq();
        M0P_ADC->ICLR_f.CONT_INTC = 0u;
gaoke231|  楼主 | 2020-3-25 20:36 | 只看该作者
配置ADC中断
void Adc_ConfigIrq(stc_adc_irq_t* pstcAdcIrqCfg,
                   stc_adc_irq_calbakfn_pt_t* pstcAdcIrqCalbaks)
    if (TRUE == pstcAdcIrqCfg->bAdcIrq)
        if (NULL != pstcAdcIrqCalbaks->pfnAdcContIrq)
            stcAdcIrqCalbaks.pfnAdcContIrq = pstcAdcIrqCalbaks->pfnAdcContIrq;
    if (TRUE == pstcAdcIrqCfg->bAdcRegCmp)
        if (NULL != pstcAdcIrqCalbaks->pfnAdcRegIrq)
            stcAdcIrqCalbaks.pfnAdcRegIrq = pstcAdcIrqCalbaks->pfnAdcRegIrq;
    if (TRUE == pstcAdcIrqCfg->bAdcHhtCmp)
        if (NULL != pstcAdcIrqCalbaks->pfnAdcHhtIrq)
            stcAdcIrqCalbaks.pfnAdcHhtIrq = pstcAdcIrqCalbaks->pfnAdcHhtIrq;
    if (TRUE == pstcAdcIrqCfg->bAdcLltCmp)
        if (NULL != pstcAdcIrqCalbaks->pfnAdcLltIrq)
            stcAdcIrqCalbaks.pfnAdcLltIrq = pstcAdcIrqCalbaks->pfnAdcLltIrq;
gaoke231|  楼主 | 2020-3-25 20:37 | 只看该作者
获取ADC中断状态
void Adc_GetIrqState(stc_adc_irq_t* pstcAdcIrqState)
    pstcAdcIrqState->bAdcIrq = M0P_ADC->IFR_f.CONT_INTF;
    pstcAdcIrqState->bAdcRegCmp = M0P_ADC->IFR_f.REG_INTF;
    pstcAdcIrqState->bAdcHhtCmp = M0P_ADC->IFR_f.HHT_INTF;
    pstcAdcIrqState->bAdcLltCmp = M0P_ADC->IFR_f.LLT_INTF;
清除ADC CONT中断状态
void Adc_ClrContIrqState(void)
    M0P_ADC->ICLR = ~(1<<3);
gaoke231|  楼主 | 2020-3-25 20:38 | 只看该作者
清除ADC REG中断状态
void Adc_ClrRegIrqState(void)
    M0P_ADC->ICLR = ~(1<<2);
gaoke231|  楼主 | 2020-3-25 20:39 | 只看该作者
清除ADC HHT中断状态
void Adc_ClrHhtIrqState(void)
    M0P_ADC->ICLR = ~(1<<1);
清除ADC LLT中断状态
void Adc_ClrIrqLltState(void)
    M0P_ADC->ICLR = ~1;
gaoke231|  楼主 | 2020-3-25 20:41 | 只看该作者
ADC中断使能
void Adc_EnableIrq(void)
    M0P_ADC->CR0_f.IE = 1u;
gaoke231|  楼主 | 2020-3-25 20:42 | 只看该作者
ADC比较使能
void Adc_CmpCfg(stc_adc_irq_t* pstcAdcIrqCfg)
        M0P_ADC->CR1_f.REGCMP = 1u;
    else
        M0P_ADC->CR1_f.REGCMP = 0u;
        M0P_ADC->CR1_f.HTCMP = 1u;
    else
        M0P_ADC->CR1_f.HTCMP = 0u;
        M0P_ADC->CR1_f.LTCMP = 1u;
    else
        M0P_ADC->CR1_f.LTCMP = 0u;
    AdcEnableNvic(ADC_IRQn);
gaoke231|  楼主 | 2020-3-25 20:44 | 只看该作者
ADC中断除能
void Adc_DisableIrq(void)
    uint32_t u32Cr1;
    M0P_ADC->CR0_f.IE = 0u;
    u32Cr1 = M0P_ADC->CR1 | (1<<15);    // must write 1 to bit 15 to avoid clear ADC_result_acc
    u32Cr1 &= ~((1u<<12)|(1u<<13)|(1u<<14));
    M0P_ADC->CR1 = u32Cr1;
    AdcDisableNvic(ADC_IRQn);
gaoke231|  楼主 | 2020-3-25 20:45 | 只看该作者
ADC初始化
en_result_t Adc_Init(stc_adc_cfg_t* pstcAdcConfig)
    if (NULL == pstcAdcConfig)
        return ErrorInvalidParameter;
    M0P_ADC->CR0_f.CLKSEL = pstcAdcConfig->enAdcClkSel;
    M0P_ADC->CR0_f.SAM = pstcAdcConfig->enAdcSampTimeSel;
    M0P_ADC->CR0_f.SREF = pstcAdcConfig->enAdcRefVolSel;
    M0P_ADC->CR0_f.BUFEN = pstcAdcConfig->bAdcInBufEn;
    M0P_ADC->HT_f.HT = pstcAdcConfig->u32AdcRegHighThd;
    M0P_ADC->LT_f.LT = pstcAdcConfig->u32AdcRegLowThd;
    M0P_ADC->CR1_f.TRIGS0 = pstcAdcConfig->enAdcTrig0Sel;
    M0P_ADC->CR1_f.TRIGS1 = pstcAdcConfig->enAdcTrig1Sel;
    return Ok;
gaoke231|  楼主 | 2020-3-25 20:47 | 只看该作者
复位ADC
void Adc_DeInit(void)
    M0P_ADC->CR0_f.ADCEN = 0u;
    M0P_ADC->CR0_f.CLKSEL = 0u;
    M0P_ADC->CR0_f.SAM = 0x2u;
    M0P_ADC->CR0_f.SREF = 0x3u;
    M0P_ADC->CR0_f.SEL = 0xFu;
    M0P_ADC->CR0_f.BUFEN = 0u;
    M0P_ADC->HT_f.HT = 0xFFFu;
    M0P_ADC->LT_f.LT = 0u;
    M0P_ADC->CR1_f.TRIGS0 = 0u;
    M0P_ADC->CR1_f.TRIGS1 = 0u;
gaoke231|  楼主 | 2020-3-25 20:52 | 只看该作者
ADC转换开始
void Adc_Start(void)
    M0P_ADC->CR0_f.STATERST = 1u;
    M0P_ADC->CR0_f.START = 1u;
gaoke231|  楼主 | 2020-3-25 20:58 | 只看该作者
ADC转换停止
void Adc_Stop(void)
    M0P_ADC->CR0_f.START = 0u;
gaoke231|  楼主 | 2020-3-25 21:00 | 只看该作者
ADC 配置普通转换模式
en_result_t Adc_ConfigNormMode(stc_adc_cfg_t* pstcAdcConfig, stc_adc_norm_cfg_t* pstcAdcNormCfg)
    if ((NULL == pstcAdcNormCfg) || (NULL == pstcAdcConfig))
    pstcAdcConfig->enAdcOpMode = AdcNormalMode;
    M0P_ADC->CR1_f.CT = 0u;
    M0P_ADC->CR0_f.SEL = pstcAdcNormCfg->enAdcNormModeCh;
    M0P_ADC->CR1_f.RACC_EN = pstcAdcNormCfg->bAdcResultAccEn;
    return Ok;
gaoke231|  楼主 | 2020-3-25 21:01 | 只看该作者
配置连续转换模式
en_result_t Adc_ConfigContMode(stc_adc_cfg_t* pstcAdcConfig, stc_adc_cont_cfg_t* pstcAdcContCfg)
    if ((NULL == pstcAdcContCfg) || (NULL == pstcAdcConfig))
    pstcAdcConfig->enAdcOpMode = AdcContMode;
    M0P_ADC->CR1_f.CT = 1u;
    M0P_ADC->CR0_f.SEL = pstcAdcContCfg->enAdcContModeCh;
    M0P_ADC->CR1_f.RACC_EN = pstcAdcContCfg->bAdcResultAccEn;
    if (pstcAdcContCfg->bAdcResultAccEn)
        M0P_ADC->CR1_f.RACC_CLR = 1u;
    M0P_ADC->CR2 = 1<<pstcAdcContCfg->enAdcContModeCh;
    M0P_ADC->CR2_f.ADCCNT = pstcAdcContCfg->u8AdcSampCnt;
    return Ok;
gaoke231|  楼主 | 2020-3-25 21:06 | 只看该作者
配置扫描转换模式
en_result_t Adc_ConfigScanMode(stc_adc_cfg_t* pstcAdcConfig, stc_adc_scan_cfg_t* pstcAdcScanCfg)
    if ((NULL == pstcAdcScanCfg) || (NULL == pstcAdcConfig))
    pstcAdcConfig->enAdcOpMode = AdcScanMode;
    M0P_ADC->CR2 = pstcAdcScanCfg->u8AdcScanModeCh;
    M0P_ADC->CR2_f.ADCCNT = pstcAdcScanCfg->u8AdcSampCnt;
    return Ok;
gaoke231|  楼主 | 2020-3-25 21:07 | 只看该作者
查询ADC转换状态
boolean_t Adc_PollBusyState(void)
    return M0P_ADC->CR0_f.START;
gaoke231|  楼主 | 2020-3-25 21:08 | 只看该作者
获取采样值
en_result_t Adc_GetResult(uint16_t* pu16AdcResult)
    if (NULL == pu16AdcResult)
    *pu16AdcResult = M0P_ADC->RESULT_f.RESULT;
    return Ok;
