[其他]
华大EVB板驱动HT1621
727|0
前段时间华大烧写算法找不到了,今天终于解决了。
原来是MDK的问题
于是写了一个驱动HT1621的程序。
代码:
static void App_LedInit(void);
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           Gpio_ClrIO(GpioPortC, GpioPin1)
#define CS_1           Gpio_SetIO(GpioPortC, GpioPin1)
#define WR_0           Gpio_ClrIO(GpioPortC, GpioPin2)
#define WR_1           Gpio_SetIO(GpioPortC, GpioPin2)
#define DA_0           Gpio_ClrIO(GpioPortC, GpioPin3)
#define DA_1           Gpio_SetIO(GpioPortC, GpioPin3)
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
unsigned int i;
void delay(uchar x)
        for(i=0;i<x;i++);
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        delay(5);
        WR_0;
        delay(5);
        for(i=0;i<3;i++)        //???
                if((0x04<<i)&0x04)  DA_1;    //100
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<9;i++)        //?????
                if((comm<<i)&0x80)  DA_1;    //100
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        CS_1;
        delay(5);
void HT1621_Display(void)
        unsigned char i;
        CS_0;                        //??CS
        delay(5);
        WR_0;
        delay(5);
                if((0x05<<i)&0x04)  DA_1;
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<6;i++)                   //???
                if((20<<i)&0x20)    DA_1;  //20?? SEG??
                  else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<8;i++)                   //???
                if((DpyNum[5]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[4]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[3]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[2]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[1]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[0]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        CS_1;                          //??CS
        delay(5);
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
** \brief  Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    ///< LED端口初始化
    App_LedInit();
                LCD_Init();
                DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"?"
                DpyNum[1] = SegCode[1];
                DpyNum[2] = SegCode[3];
                DpyNum[3] = SegCode[5];
                DpyNum[4] = SegCode[7];
                DpyNum[5] = SegCode[9];
                HT1621_Display();               //??LCD
    while(1)
        ///< LED点亮
        Gpio_SetIO(EVB_LEDR_PORT, EVB_LEDR_PIN);
        delay1ms(1000);
        ///< LED关闭
        Gpio_ClrIO(EVB_LEDR_PORT, EVB_LEDR_PIN);
        delay1ms(1000);
    stc_gpio_cfg_t stcGpioCfg;
    ///< 打开GPIO外设时钟门控
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
    ///< 端口方向配置->输出(其它参数与以上(输入)配置参数一致)
    stcGpioCfg.enDir = GpioDirOut;
    ///< 端口上下拉配置->下拉
    stcGpioCfg.enPu = GpioPuDisable;
    stcGpioCfg.enPd = GpioPdEnable;
    ///< LED关闭
    ///< GPIO IO LED端口初始化
    Gpio_Init(EVB_LEDR_PORT, EVB_LEDR_PIN, &stcGpioCfg);
    ///< 端口上下拉配置->下拉
    stcGpioCfg.enPd = GpioPdDisable;
                Gpio_Init(GpioPortC, GpioPin3, &stcGpioCfg);
                Gpio_Init(GpioPortC, GpioPin2, &stcGpioCfg);
    Gpio_Init(GpioPortC, GpioPin1, &stcGpioCfg);
* EOF (not truncated)
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
