[MM32软件]
【MM32 eMiniBoard测评报告】+ 3、TN9
564|0
今晚搞了一下TN9,红外体温计模块。
Data:PC13
CLK:PC14
ACK:PC15
代码:
#include "delay.h"
#include "sys.h"
#include "led.h"
#define uchar unsigned char
#define uint unsigned int
void ACK_0() { GPIO_ResetBits(GPIOC,GPIO_Pin_15);}  //
void ACK_1() { GPIO_SetBits(GPIOC,GPIO_Pin_15);}
#define DATA            GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13)
#define CLOCK           GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_14)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
unsigned int a,b;
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
void TN_IRACK_EN(void)
        ACK_0();
        Delay(1);
void TN_IRACK_UN(void)
        ACK_1();
        Delay(1);
void InitIO(void)
                GPIO_InitTypeDef  GPIO_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA|RCC_AHBPeriph_GPIOB|RCC_AHBPeriph_GPIOC, ENABLE);  //¿ªÆôGPIOA,GPIOBʱÖÓ
                GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_13 | GPIO_Pin_14;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
void TN_ReadData(unsigned char Flag)
        unsigned char i,j,k,BitState=0;
        for(k=0;k<7;k++)
                for(j=0;j<5;j++)
                        for(i=0;i<8;i++)
                                while(1)
                                  if(CLOCK==0)
                                    break;
                                  Delay(1);
                                Delay(1);
                                if(DATA==1)
                                  BitState=1;
                                else
                                  BitState=0;
                                ReadData[j]= ReadData[j]<<1;
                                ReadData[j]= ReadData[j]|BitState;
                                Delay(1);
                                while(1)
                                  if(CLOCK==1)
                                    break;
                                  Delay(1);
                if(ReadData[0]==Flag)
                        k=8;
        TN_IRACK_UN();
float TN_GetData(unsigned char X)
        //Ack_Clk_Data_init;
        InitIO();
        TN_ReadData(X);
        Temp=(ReadData[1]<<8)|ReadData[2];
        Temp=(float)Temp/16.00-273.15;
        return Temp;
float TN_GetTemp(unsigned char mode)
        float T;
                TN_IRACK_UN();
                TN_IRACK_EN();
                if(mode==0)
                        T=TN_GetData(0x4c);
                else
                        T=TN_GetData(0x66);
        return T;
**º¯ÊýÐÅÏ¢ £ºmain(void)
**¹¦ÄÜÃèÊö £º
**ÊäÈë²ÎÊý £ºÎÞ
**Êä³ö²ÎÊý £ºÎÞ
int main(void)
    delay_init();
    LED_Init();
    while(1)              //ÎÞÏÞÑ­»·
        Temp1=TN_GetTemp(0);
        Temp2=TN_GetTemp(1);
        a=((unsigned int)(Temp1*10));
                                b=((unsigned int)(Temp2*10));
        delay_ms(500);
效果图:
a是体温,b是环境温度
332表示33.2度,214表示21.4度。
工程:
TN9.rar (327.75 KB)
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
