[STM32F1]
系统里默认是哪组呢
380|11
spark周|  楼主 | 2020-7-4 21:03 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
我看好多例程里面都没有显式配置NVIC_PriorityGroupConfig(),那系统默认是哪组呢,以stm32f103为例
spark周|  楼主 | 2020-7-4 21:26 | 显示全部楼层
确实默认为0,
#define NVIC_PriorityGroup_0         ((uint32_t)0x700) /*!< 0 bits for pre-emption priority
                                                            4 bits for subpriority */
#define NVIC_PriorityGroup_1         ((uint32_t)0x600) /*!< 1 bits for pre-emption priority
                                                            3 bits for subpriority */
#define NVIC_PriorityGroup_2         ((uint32_t)0x500) /*!< 2 bits for pre-emption priority
                                                            2 bits for subpriority */
#define NVIC_PriorityGroup_3         ((uint32_t)0x400) /*!< 3 bits for pre-emption priority
                                                            1 bits for subpriority */
#define NVIC_PriorityGroup_4         ((uint32_t)0x300) /*!< 4 bits for pre-emption priority
                                                            0 bits for subpriority */
#define IS_NVIC_PRIORITY_GROUP(GROUP) (((GROUP) == NVIC_PriorityGroup_0) || \
                                       ((GROUP) == NVIC_PriorityGroup_1) || \
                                       ((GROUP) == NVIC_PriorityGroup_2) || \
                                       ((GROUP) == NVIC_PriorityGroup_3) || \
                                       ((GROUP) == NVIC_PriorityGroup_4))
我在里面看到了
spark周|  楼主 | 2020-7-4 21:32 | 显示全部楼层
比如有两个中断,一个中断分组为Group_1,抢占式优先级设置为2,响应优先级设置为1,一个中断分级为Group_0,响应优先级设置为0或2时,这两个中断同时产生中断请求时,系统要处理哪个呢?
spark周|  楼主 | 2020-7-4 21:54 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家,结贴了哈
