FATFS 0.09 没法访问第二卷目录
224|0
各位大神,请教一个问题:
     使用SD卡和Flash做2个磁盘,将SD或flash做为卷0,程序都可以正常访问目录,文件,另外可以对卷1进行格式化,但是却访问不了卷1的目录;有没有知道什么问题的?
void ShowSDFiles(u8 index)
FILINFO finfo;
DIR dirs;
char path[100] = {""};
printf("
SD file system starting!
disk_initialize(index);
printf("f_mount %d
", f_mount(index, &fs));
printf("f_mkfs %d
", f_mkfs(index, 0, 512)); // SD 卡时为4096
printf("----------------------------------------------------
printf("f_opendir(&dirs, "/") = %d;
", f_opendir(&dirs, "/"));
if(f_opendir(&dirs, path) == FR_OK)
  while(f_readdir(&dirs, &finfo) == FR_OK)
   if(!finfo.fname[0]) break;
   if (finfo.fattrib & AM_ARC)
    printf("            file name is: %s    ", finfo.fname);
    printf("file size is: %d
", finfo.fsize);
    if(File_type_Check((u8 *)finfo.fname, "txt"))
     printf("file contex is:");
     res = f_open(&fsrc, finfo.fname, FA_OPEN_EXISTING | FA_READ);
     while(1)
      memset(buffer, 0, sizeof(buffer));
      if(f_gets(buffer, 512, &fsrc))
       printf("%s", buffer);
      else break;
     f_close(&fsrc);
   else
    printf("Path name is: %s
", finfo.fname);
    continue; //break;
  res = f_open(&fsrc, "armjishu.txt", FA_CREATE_ALWAYS | FA_WRITE);
  res = f_write(&fsrc, &armjishu, sizeof(text), &bw);
  f_close(&fsrc);
else
  printf(" err: f_opendir
f_mount(index, NULL);
