An error has occurred - no valid devices were found ...的解决方案!
394|0
无幻|  楼主 | 2018-10-4 13:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VMware安装linux,建立分区时提示:
An error has occurred - no valid devices were found on which to create new file systems please check your hardware for the cause of this problem。
解决方法:
在建立虚拟机的时候选择custom,然后在选择硬盘的时候选择ide(默认是scsi),原因是scsi需要驱动才能正常读取硬盘。
