[STM32F1]
TIM1重映像到PE引脚不出波形,使用默认引脚时有波形
452|9
supernan|  楼主 | 2020-11-3 23:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOE,&GPIO_InitStructure);
zhuww| | 2020-11-3 23:17 | 只看该作者
如果不做REMAP是否能正常输出呢?
chenho| | 2020-11-3 23:22 | 只看该作者
注意stm32f1系列的TIM1 的 Full remap 仅限于100脚和144脚封装;
happy_10| | 2020-11-3 23:27 | 只看该作者
另外 请注意TIM1的时钟是APB2 以及需使能其MOE.
supernan|  楼主 | 2020-11-3 23:30 | 只看该作者
不做REMP能输出我用的是STMF103VET6 100引脚的
supernan|  楼主 | 2020-11-3 23:34 | 只看该作者
void TIM1_GPIO_Configuration(void)
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_TIM1,ENABLE);
//        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
//        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
//        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
//        GPIO_Init(GPIOA,&GPIO_InitStructure);
void TIM1_MODE_Configuration(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
        TIM_TimeBaseInitStructure.TIM_Period=14399;
        TIM_TimeBaseInitStructure.TIM_Prescaler=0;
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
        TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse=0;
        TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
        TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
        TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
        TIM_OC1Init(TIM1,&TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_OC2Init(TIM1,&TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_OC3Init(TIM1,&TIM_OCInitStructure);
        TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
//        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
//        TIM_OCInitStructure.TIM_Pulse=125;
//        TIM_OC4Init(TIM1,&TIM_OCInitStructure);
//        TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel=TIM1_UP_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
        TIM_BDTRInitStructure.TIM_OSSRState=TIM_OSSRState_Disable;
        TIM_BDTRInitStructure.TIM_OSSIState=TIM_OSSIState_Disable;
        TIM_BDTRInitStructure.TIM_LOCKLevel=TIM_LOCKLevel_OFF;
        TIM_BDTRInitStructure.TIM_DeadTime=0;
        TIM_BDTRInitStructure.TIM_Break=TIM_Break_Disable;
        TIM_BDTRInitStructure.TIM_BreakPolarity=TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_AutomaticOutput=TIM_AutomaticOutput_Enable;
        TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
        TIM_ARRPreloadConfig(TIM1,ENABLE);
        TIM_Cmd(TIM1,ENABLE);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
renyaq| | 2020-11-3 23:43 | 只看该作者
记得开启AFIO时钟, RCC_APB2ENR_AFIOEN
supernan|  楼主 | 2020-11-3 23:46 | 只看该作者
问题解决了,是REMAP函数位置放错了。
morrisk| | 2020-11-3 23:50 | 只看该作者
放到哪里了
supernan|  楼主 | 2020-11-3 23:54 | 只看该作者
嗯,预料中的结果,多谢大家啦
