烧录器代码求解
914|3
爱情海玩偶|  楼主 | 2020-11-16 18:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
static const uint32_t flash_code[] = {
    0xE00ABE00, 0x062D780D, 0x24084068, 0xD3000040, 0x1E644058, 0x1C49D1FA, 0x2A001E52, 0x4770D1F2,
    0x4603B510, 0x4C442000, 0x48446020, 0x48446060, 0x46206060, 0xF01069C0, 0xD1080F04, 0x5055F245,
    0x60204C40, 0x60602006, 0x70FFF640, 0x200060A0, 0x4601BD10, 0x69004838, 0x0080F040, 0x61104A36,
    0x47702000, 0x69004834, 0x0004F040, 0x61084932, 0x69004608, 0x0040F040, 0xE0036108, 0x20AAF64A,
    0x60084930, 0x68C0482C, 0x0F01F010, 0x482AD1F6, 0xF0206900, 0x49280004, 0x20006108, 0x46014770,
    0x69004825, 0x0002F040, 0x61104A23, 0x61414610, 0xF0406900, 0x61100040, 0xF64AE003, 0x4A2120AA,
    0x481D6010, 0xF01068C0, 0xD1F60F01, 0x6900481A, 0x0002F020, 0x61104A18, 0x47702000, 0x4603B510,
    0xF0201C48, 0xE0220101, 0x69004813, 0x0001F040, 0x61204C11, 0x80188810, 0x480FBF00, 0xF01068C0,
    0xD1FA0F01, 0x6900480C, 0x0001F020, 0x61204C0A, 0x68C04620, 0x0F14F010, 0x4620D006, 0xF04068C0,
    0x60E00014, 0xBD102001, 0x1C921C9B, 0x29001E89, 0x2000D1DA, 0x0000E7F7, 0x40022000, 0x45670123,
    0xCDEF89AB, 0x40003000, 0x00000000
const program_target_t flash_algo = {
    0x20000021,  // Init
    0x20000053,  // UnInit
    0x20000065,  // EraseChip
    0x2000009F,  // EraseSector
    0x200000DD,  // ProgramPage
    // BKPT : start of blob + 1
    // RSB  : address to access global/static data
    // RSP  : stack pointer
        0x20000001,
        0x20000C00,
        0x20001000
    0x20000400,  // mem buffer location
    0x20000000,  // location to write prog_blob in target RAM
    sizeof(flash_code),  // prog_blob size
    flash_code,  // address of prog_blob
    0x00000400,  // ram_to_flash_bytes_to_be_written
flash_code[]里面的这些数组是怎么得来的,也不太像是地址。我在另一份代码里面看到过代码生成这串数字,但是还不太懂。如果我要手动去写,该怎么找呢
for(cnt=0;cnt<Flash_Algo_Length;cnt++)
                f_lseek(&file,60+cnt*4);//设置读取文件数据起始位置
                memset(Read_Buff,0x00,4);
                f_read(&file,Read_Buff,4,&fnum);//读取数据Flash算法
                flash_code[cnt]=        (
        Read_Buff[0]<<24        |        Read_Buff[1]<<16        |
        Read_Buff[2]<<8        |        Read_Buff[3]                );
flash_algo 这个结构体里面的数据是手册里面看到的吗?是烧录目标芯片的flash参数数据吗。
我看到好像说是什么flash算法得到的。不太懂,求大佬解答
zzz3265| | 2020-11-17 13:27 | 只看该作者
意思应该是把 flash_code 这些输入烧录到flash里面去,  flash_algo 应该是某个库提供的接口, 可以设置多个指令, 然后再按设置的指令动作, 看上面有初始化, 擦除, 烧录等
爱情海玩偶|  楼主 | 2020-11-17 14:05 | 只看该作者
zzz3265 发表于 2020-11-17 13:27
意思应该是把 flash_code 这些输入烧录到flash里面去,  flash_algo 应该是某个库提供的接口, 可以设置多个 ...
我已经找到了,这个就是keil里面的烧录算法提取出来的
qmzn2333| | 2021-11-25 13:55 | 只看该作者
请问【0xE00ABE00, 0x062D780D, 0x24084068, 0xD3000040, 0x1E644058, 0x1C49D1FA, 0x2A001E52, 0x4770D1F2】这一段代码是什么作用?在哪里可以找到相关说明
