电阻屏组件数据手册-全新
 楼主| Go_PSoC 发表于 2012-2-9 01:53 | 显示全部楼层 |阅读模式
PSoC Creator 组件数据手册
特性
    Supports 4-wire resistive touchscreen interface Supports the Delta Sigma Converter for both the PSoC 3 and PSoC 5 devices
  • Supports the ADC Successive Approximation Register for PSoC 5 devices
    符号图
概述
This resistive touchscreen component is used to interface with a 4-wire resistive touch screen. The component provides a method to integrate and configure the resistive touch elements of a touchscreen with the emWin Graphics library. It integrates hardware-dependent functions that are called by the touchscreen driver supplied with emWin when polling the touch panel.
rfvwer 发表于 2012-2-9 22:34 | 显示全部楼层
电阻屏好像不是cy主推的吧?
yanghaoren 发表于 2012-2-11 17:49 | 显示全部楼层
cy还有电阻屏的呢
 楼主| Go_PSoC 发表于 2012-2-11 21:21 | 显示全部楼层
也可以做电阻屏控制器,电容屏控制器有专门的系列truetouch
nihao123456 发表于 2012-2-12 18:25 | 显示全部楼层
wsgcs 发表于 2012-2-13 21:24 | 显示全部楼层
