[技术问答]
N9H20K51 w25q246 spi操作
623|2
probedog|  楼主 | 2021-1-8 16:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
官方例程只有读写操作, flash 写之前要擦出,官方例程没有做处理
所以想问下各位有没有做spi flash这部分的,如果有处理过的写之前擦出的例程,请发一下参考。谢谢
jcky001| | 2021-3-5 09:54 | 只看该作者
spiFlashInit();
        sysprintf("Erase all SpiFlash\n");
        spiFlashEraseAll();
        sysprintf("\tWrite SpiFlash\n");
        spiFlashWrite(0, TEST_SIZE, (UINT32 *)pSrc);
        sysprintf("\tRead and Compare SpiFlash\n");
        spiFlashRead(0, TEST_SIZE, (UINT32 *)pDst);
twjiang| | 2021-3-25 14:31 | 只看该作者
参考:https://github.com/OpenNuvoton/N9H20_emWin_NonOS/tree/master/Tools/MassProduction_Tools/SpiWriter
int usiEraseSector(UINT32 addr, UINT32 secCount)
    int volatile i;
    if ((addr % (64*1024)) != 0)
        return -1;
    if(!g_4byte_adderss)
        if(addr & 0xFF000000)
            Enter4ByteMode();
            g_4byte_adderss = TRUE;
            PRINTF("SPI 4 Byte Address Mode Enable (R)\n");
        else if ((addr+secCount*64*1024-1) & 0xFF000000)
            Enter4ByteMode();
            PRINTF("SPI 4 Byte Address Mode Enable (W1)\n");
    for (i=0; i<secCount; i++)
        usiWriteEnable();
        outpw(REG_SPI0_SSR, inpw(REG_SPI0_SSR) | 0x01);  /* CS0 */
        /* erase command */
        outpw(REG_SPI0_TX0, 0xd8);
        spiTxLen(0, 0, 8);
        spiActive(0);
        /* address */
        outpw(REG_SPI0_TX0, addr+i*64*1024);
        if(g_4byte_adderss)
            spiTxLen(0, 0, 32);
        else
            spiTxLen(0, 0, 24);
        spiActive(0);
        outpw(REG_SPI0_SSR, inpw(REG_SPI0_SSR) & 0xfe);  /* CS0 */
        /* check status */
        usiCheckBusy();
    return Successful;
int usiEraseAll(void)
    usiWriteEnable();
    outpw(REG_SPI0_TX0, 0xc7);
    spiTxLen(0, 0, 8);
    spiActive(0);
    /* check status */
    outpw(REG_SPI0_TX0, 0x05);
    spiTxLen(0, 0, 8);
    spiActive(0);
    /* get status */
    outpw(REG_SPI0_TX0, 0xff);
    spiTxLen(0, 0, 8);
    spiActive(0);
    if (((inpw(REG_SPI0_RX0) & 0xff) & 0x01) != 0x01)
        return 0;       /* ready */
    else
        return 0xFF;    /* busy */
