我用PICkit 2 DEBUG,发现U2RXREG始终是0.但是用示波器观察电脑发送的数据已经到接收脚,PIN18脚。
然后就是进不了中断,程序等在while(!DataAvailable);这里了。
请帮忙看看是哪里出了问题,谢谢!
- #include "p24fj64ga002.h"
- //#include<uart.h>
- //此程序适用I2C1 ,SDA1,SCL1 (备用口)
- //_CONFIG1(ICS_PGx1&FWDTEN_OFF)
- _CONFIG2(FNOSC_FRC&FCKSM_CSDCMD&I2C1SEL_SEC)//fast RC oscillator;clock switching and Fail-Safe clock monitor are disable
- void cUART2(void);
- void UART2INT(void);
- void configUART2(void);
- unsigned char DataAvailable;
- unsigned char Txdata[]= "hello";
- unsigned char Rxdata[10];
- void __attribute__ ((interrupt,no_auto_psv)) _U2TXInterrupt(void)
- static unsigned char i=0;
- IFS1bits.U2TXIF = 0;//clear flag
- if(Txdata[i]!='\0')
- while(U2STAbits.UTXBF);
- U2TXREG = Txdata[i++];
- else
- while(!U2STAbits.TRMT);
- //DisableIntU2TX;
- IEC1bits.U2TXIE = 0;
- void __attribute__ ((interrupt,no_auto_psv)) _U2RXInterrupt(void)
- static unsigned char j=0;//why set to static?
- IFS1bits.U2RXIF = 0;
- if(U2STAbits.OERR)
- {U2STAbits.OERR = 0;}
- while(!U2STAbits.URXDA);
- Rxdata[j++] = U2RXREG;
- DataAvailable=1;
- void uart(void)
- asm volatile (
- "MOV #OSCCON, W1 \n"
- "MOV #0X46, W2 \n"
- "MOV #0X57,W3 \n"
- "MOV.b W2, [W1] \n"
- "MOV.B W3, [W1] \n"
- "BCLR OSCCON,#6"
- //Assign U2RX to pin RP9
- RPINR19bits.U2RXR = 9;
- //assign U2TX to pin RP4
- RPOR2bits.RP4R = 5;
- asm volatile (
- "MOV #0X57,W3 \n"
- "BSET OSCCON,#6"
- //Close UART2
- cUART2();
- /*Enable UART intruupts*/
- UART2INT();
- /*UART initialized to 9600 baudrate @BRGH=0, 8bit,no parity and 1 stopbit,interrupt is set on RST transfer,making the receive full*/
- configUART2();
- /* Data Transmit and receiving the data using interrupts*/
- //IFS1bits.U2TXIF = 1;//what is this used for?
- while(!DataAvailable);/*wait till data is received*/
- DataAvailable=0;
- cUART2();
- void main(void)
- OSCCONbits.COSC=0;
- CLKDIV=0;
- TRISBbits.TRISB15= 0; //P1B5 is output
- LATBbits.LATB15 = 0;
- uart();
- if(Rxdata[0]== 1)
- LATBbits.LATB15 = 1;
- else
- // while(1)
- void cUART2(void)
- U2MODEbits.UARTEN = 0;
- IEC1bits.U2RXIE = 0;
- IEC1bits.U2TXIE = 1;
- IEC1bits.U2RXIE = 1;
- IPC7bits.U2TXIP = 1;
- IPC7bits.U2RXIP = 2;
- U2MODEbits.UARTEN = 1;
- //U2STAbits.UTXEN = 1;
- U2STAbits.URXISEL = 0;
- U2BRG = 25;
