发新帖我要提问
返回列表
[应用相关]
STM32 串口DMA发送+DMA接收+硬件双缓冲区切换功能实现
楼主: qcliu
qcliu|  楼主 | 2021-7-7 11:00 | 只看该作者 回帖奖励 |倒序浏览
stm32f7xx_it.h
/* USER CODE BEGIN Header */
  * @file    stm32f7xx_it.h
  * @brief   This file contains the headers of the interrupt handlers.
  * @attention
  * <h2><center>&copy; Copyright (c) 2020 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32F7xx_IT_H
#define __STM32F7xx_IT_H
#ifdef __cplusplus
extern "C" {
#endif
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Exported types ------------------------------------------------------------*/
/* USER CODE BEGIN ET */
/* USER CODE END ET */
/* Exported constants --------------------------------------------------------*/
/* USER CODE BEGIN EC */
/* USER CODE END EC */
/* Exported macro ------------------------------------------------------------*/
/* USER CODE BEGIN EM */
/* USER CODE END EM */
/* Exported functions prototypes ---------------------------------------------*/
void NMI_Handler(void);
void HardFault_Handler(void);
void MemManage_Handler(void);
void BusFault_Handler(void);
void UsageFault_Handler(void);
void SVC_Handler(void);
void DebugMon_Handler(void);
void PendSV_Handler(void);
void SysTick_Handler(void);
void DMA1_Stream5_IRQHandler(void);
void DMA1_Stream6_IRQHandler(void);
void USART2_IRQHandler(void);
/* USER CODE BEGIN EFP */
/* USER CODE END EFP */
#ifdef __cplusplus
#endif
#endif /* __STM32F7xx_IT_H */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
呐咯密密| | 2021-7-7 11:04 | 只看该作者
原理在contex -M内核上大部分都适用,只是不同的芯片可能寄存器不一样,或者库函数不一样
