[其他ST产品] stm32 FSMC-TFTLCD显示
1600|51
 楼主| 自动化陈稳 发表于 2022-9-29 11:09 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:10 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:11 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:12 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:13 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:15 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:19 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:23 | 显示全部楼层
 楼主| 自动化陈稳 发表于 2022-9-29 11:24 | 显示全部楼层
  1. void TFTLCD_gpio_init()
  3.     GPIO_InitTypeDef gpiod =
  4.     {
  5.         GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15,
  6.         GPIO_Speed_50MHz,
  7.         GPIO_Mode_AF_PP
  8.     };
 楼主| 自动化陈稳 发表于 2022-9-29 11:38 | 显示全部楼层
  1.    GPIO_InitTypeDef gpioe =
  2.     {
  3.         GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15,
  4.         GPIO_Speed_50MHz,
  5.         GPIO_Mode_AF_PP
  6.     };
  7.     GPIO_InitTypeDef gpiog =
  8.     {
  9.         GPIO_Pin_0 | GPIO_Pin_12,
  10.         GPIO_Speed_50MHz,
  11.         GPIO_Mode_AF_PP
  12.     };
  13.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOG, ENABLE);
  14.     GPIO_Init(GPIOD, &gpiod);
  15.     GPIO_Init(GPIOE, &gpioe);
  16.     GPIO_Init(GPIOG, &gpiog);
  17. }
 楼主| 自动化陈稳 发表于 2022-9-29 11:39 | 显示全部楼层
  1. void FSMC_init()
  3.     FSMC_NORSRAMInitTypeDef fsmc = {0};
  4.     FSMC_NORSRAMTimingInitTypeDef FSMC_ReadWriteTimingStruct = {0};
  5.     FSMC_NORSRAMTimingInitTypeDef FSMC_WriteTimingStruct = {0};
 楼主| 自动化陈稳 发表于 2022-9-29 11:40 | 显示全部楼层
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
  1.     FSMC_ReadWriteTimingStruct.FSMC_AddressSetupTime = 0x01; //ADDSET建立时间=2个HCLK时钟周期
  2.     FSMC_ReadWriteTimingStruct.FSMC_AddressHoldTime = 0x00; //模式A未用到
  3.     FSMC_ReadWriteTimingStruct.FSMC_DataSetupTime = 0x0f; //DATAST保持时间=16个HCLK时钟周期
  4.     FSMC_ReadWriteTimingStruct.FSMC_BusTurnAroundDuration = 0x00;
  5.     FSMC_ReadWriteTimingStruct.FSMC_CLKDivision = 0x00;
  6.     FSMC_ReadWriteTimingStruct.FSMC_DataLatency = 0x00;
  7.     FSMC_ReadWriteTimingStruct.FSMC_AccessMode = FSMC_AccessMode_A; //访问模式A
 楼主| 自动化陈稳 发表于 2022-9-29 11:41 | 显示全部楼层
  1. FSMC_WriteTimingStruct.FSMC_AddressSetupTime = 0x0f;     //ADDSET建立时间=16个HCLK时钟周期
  2.     FSMC_WriteTimingStruct.FSMC_AddressHoldTime = 0x0f;
  3.     FSMC_WriteTimingStruct.FSMC_DataSetupTime = 0x05;
  4.     FSMC_WriteTimingStruct.FSMC_BusTurnAroundDuration = 0x00;
  5.     FSMC_WriteTimingStruct.FSMC_CLKDivision = 0x00;
  6.     FSMC_WriteTimingStruct.FSMC_DataLatency = 0x00;
  7.     FSMC_WriteTimingStruct.FSMC_AccessMode = FSMC_AccessMode_A;
 楼主| 自动化陈稳 发表于 2022-9-29 11:42 | 显示全部楼层
  1. fsmc.FSMC_Bank = FSMC_Bank1_NORSRAM4;
  2.     fsmc.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  3.     fsmc.FSMC_MemoryType = FSMC_MemoryType_SRAM;
  4.     fsmc.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  5.     fsmc.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  6.     fsmc.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
  7.     fsmc.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  8.     fsmc.FSMC_WrapMode = FSMC_WrapMode_Disable;
  9.     fsmc.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  10.     fsmc.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  11.     fsmc.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  12.     fsmc.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; //扩展模式使能
  13.     fsmc.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  14.     fsmc.FSMC_ReadWriteTimingStruct = &FSMC_ReadWriteTimingStruct;
  15.     fsmc.FSMC_WriteTimingStruct = &FSMC_WriteTimingStruct;
  16.     FSMC_NORSRAMInit(&fsmc);
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE); //使能存储块1 NOR/PSRAM 4
robertesth 发表于 2022-10-1 13:06 | 显示全部楼层
可否直接用FSMC驱动4.3寸的TFT屏
1988020566 发表于 2022-10-1 13:19 | 显示全部楼层
用STM32的FSMC驱动TFT LCD在速度上有多大的优化空间
lihuami 发表于 2022-10-1 13:46 | 显示全部楼层
ILI9225 支持哪几种通信?
