发新帖我要提问
返回列表
[STM32F0]
STM32使用M/T法检测单路脉冲
楼主: 范德萨发额
范德萨发额|  楼主 | 2022-12-29 23:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览
void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
        if(TIM3 == htim->Instance)
                switch(capture_Cnt){
                        case 1://捕获到第一个上升沿
                                ExPulse_Input = 1;
                                HAL_GPIO_WritePin(LED2_GPIO,LED2_GPIO_PIN,GPIO_PIN_SET);
                                htim3.Instance->CNT = 0;
                                htim5.Instance->CNT = 0;
                                HAL_TIM_Base_Start(&htim4);//
                                HAL_TIM_Base_Start(&htim8);//
//                                HAL_TIM_IC_Stop_IT(&htim3,TIM_CHANNEL_1); //停止捕获
                                HAL_TIM_Base_Start_IT(&htim8);
                                capture_Cnt++;
                                MSpeed_capture_Buf[0] = HAL_TIM_ReadCapturedValue(&htim3,TIM_CHANNEL_1);
                        __HAL_TIM_SET_CAPTUREPOLARITY(&htim3, TIM_CHANNEL_1, TIM_INPUTCHANNELPOLARITY_FALLING);//开启下降沿捕获
                                break;
                        case 2://捕获到第二个上升沿,用来进行低速的测量,目前测试效果不好,可以不用管这一段
                                ExPulse_Input = 2;
                                MSpeed_capture_Buf[1] = HAL_TIM_ReadCapturedValue(&htim3,TIM_CHANNEL_1);
//                                __HAL_TIM_DISABLE_IT(&htim3,TIM_IT_UPDATE);
                                capture_Cnt++;
                                MSpeed_capture_Buf[2] = TIM3_CNT;
                                break;
                        case 3://计数时间到时捕获到的最后一个上升沿  2
                                ExPulse_Input = 3;
//                                capture_Buf[1] = HAL_TIM_ReadCapturedValue(&htim16,TIM_CHANNEL_1);//闁兼儳鍢茶ぐ鍥亹閹惧啿顤呴柣銊ュ瀹曠喖鎳㈤敓????????????????????.
                                HAL_TIM_IC_Stop_IT(&htim3,TIM_CHANNEL_1); //闁稿绮嶉娑㈠箲閺囷拷?锟界??????????   闁瑰瓨锟????: __HAL_TIM_DISABLE(&htim5);
                                HAL_TIM_Base_Stop(&htim4);//閿燂??????????????閸氼垶鐝0鎴炴闁界喖顣堕敓锟??????
                                HAL_TIM_Base_Stop(&htim8);//閿燂??????????????閸氼垵绶崗銉ㄥ墻閸愯尪顓搁弫鏉挎珤
                                HAL_TIM_Base_Stop(&htim1);
                        HAL_TIM_Base_Stop(&htim3);
                        HAL_TIM_Base_Stop(&htim5);
                                HAL_GPIO_WritePin(LED2_GPIO,LED2_GPIO_PIN,GPIO_PIN_RESET);
                                capture_Cnt++;
                                capture_Buf[1] = htim4.Instance->CNT;//HAL_TIM_ReadCapturedValue(&htim3,TIM_CHANNEL_1);//闁兼儳鍢茶ぐ鍥亹閹惧啿顤呴柣銊ュ瀹曠喖鎳㈤敓????????????????????.
                                HIGHFRE_Buf[1] = htim8.Instance->CNT;//HAL_TIM_ReadCapturedValue(&htim4,TIM_CHANNEL_1);
                                if(ThighFre_CNT != 0)
                                        HIGHFRE_Buf[3] = ((ThighFre_CNT) * 65535 + HIGHFRE_Buf[1]);//*2.5;
                                        ThighFre_CNT = 0;
                                        CAL_HIGHFRE_Buf[1] = HIGHFRE_Buf[3];
                                else
                                        HIGHFRE_Buf[3] = HIGHFRE_Buf[1];// * 2.5;
                                        CAL_HIGHFRE_Buf[1] = HIGHFRE_Buf[1];
                                if(TExPulse_CNT != 0)
                                        capture_Buf[3] = ((TExPulse_CNT) * 65535 + capture_Buf[1]);//*2.5;
                                        TExPulse_CNT = 0;
                                        CAL_capture_Buf[1] = capture_Buf[3];
                                else
                                        capture_Buf[3] = capture_Buf[1] ;//* 2.5;
                                        CAL_capture_Buf[1] = capture_Buf[1];
                                break;
范德萨发额|  楼主 | 2022-12-29 23:32 | 只看该作者
                        case 1://捕获到第一个上升沿
                                ExPulse_Input = 1;
                                capture_Cnt++;
                                break;
                                ExPulse_Input = 2;
                                capture_Cnt++;
                                break;
                                ExPulse_Input = 3;
                                capture_Cnt++;
                                        ThighFre_CNT = 0;
                                else
                                        TExPulse_CNT = 0;
                                else
                                break;
范德萨发额|  楼主 | 2022-12-29 23:33 | 只看该作者
实验数据说明:
假设PULSE_CIRCLE =1就是一圈一个脉冲,T_SPEED 就是最终的测速结果,单位就是r/min。
在小于0.3HZ/S的频率下,误差较大,其他情况下,误差基本都很小了。
实验结束。
